Woofer.. un sfat pls.!
Am achizitionat si eu o tigaie de difuzor Woofer HiFi Carpower CRB-25HQ, de 25 cm, si as dori cateva sfaturi despre incinta.. cum sa o fac ... cu bass reflex sau inchisa,... aici mai jos sunt niste specificatii ale dif.. am luat si eu cateva prg de calculat incinte,,, dar ma depasesc, nu stiu cum sa le folosesc... in fine as dori si eu cateva pareri... si unele schite. (cel mai mult ma intereseaza dimensiuniile incintei). va multumesc..
Vad ca ei recomanda bass reflex. already possible in closed cabinets of 20 litres or in BR cabinets of approx. 35 litres (very recommendable). Technical Facts Speakers Impedance (Z)4Ω Resonant frequency (fs)33Hz Max. frequency rangef3-300Hz Music power500WMAX Power rating (P)200WRMS SPL (1W/1m)85dB Suspension compl. (Cms)0.20mm/N Moving mass (Mms)116g Mech. Q factor (Qms)5.56 Electr. Q factor (Qes)0.49 Total Q factor (Qts)0.45 Equivalent volume (Vas)27 l DC resistance (Re) 3.3Ω Force factor (BxL) 14.6Tm Voice coil induct. (Le)2.2mH Voice coil diameter Ø 38mm Voice coil former aluminium Linear excursion (XMAX)±5mm Eff. cone area (Sd)315cm2 Magnet weight 2.3kg Weight 5.6kg |
Re: Woofer.. un sfat pls.!
0728239934 Razvan
| All times are GMT +2. The time now is 07:08. |
