-   Talcioc (https://forum.4tuning.ro/79-talcioc.html)
-   -   SISTEM SUPRAVEGHERE COMPLET (https://forum.4tuning.ro/79-talcioc/196302-sistem-supraveghere-complet.html)
sonyscorpion 27-06-10 21:20
TELEFON - 0723000222
PRET - 200 EURO DISCUTABIL
SISTEM SUPRAVEGHERE:CAMERA SUPRAVEGHERE EXTERIOR CU 24 LEDURI INFRAROSU – SUPER HAD COLOR CCD, WATERPROOF (IP66), 12 IR LED (distanta IR cca 15 m), 420 LTV, lentila 3.6mm, 0Lux (IR), 500x582 pixeli PAL, AWB AUTO, alimentare 12V, consum 300 mA, dimensiuni 55x60x115 mm, SUPORT SI SUNSHIELD INCLUS
CANTEK BNC TO VGA CONVERTER-CONVERTOR PENTRU MONITOR/TV-Support DVR by Monitor Out -Output Resolution Up to 1024×768@60Hz -Easy Installation -N/P Video System Auto Detection
RECORDER DVR:AVTECH AVC760ZA CU HDD 160GBProduct details
MPEG4 DVR • Technology: Provides a local MPEG4 compression format with clear images and real-time performance. In addition to remote web-MPEG4 for rapid transmission and image cleanup via network.
• Multiple operations: Allows live display, record, playback, backup, and network operations at the same time.
• Backup Function: Support network remote recording & backup
• Remote Surveillance: web surveillance supports 20 users simultaneously with licensed software AP, IE browser and Mozilla Firefox.
• Smart firing recorded by mobile: with advanced motion detection, you program the motion detection recording (4 different adjustable factors for motion detector sensitivity) and quick search, to achieve a customized security environment .
• The fire alarm recording will send alerts with images to e-mails and FTP address designated. Supports pre-alarm recording (8Mb)
• Convert Recording: A mask replaces the live image on a white screen and the monitor displays nothing but the recording still continues.
• Supports A / V: Support 1 audio input and an audio output to record sounds. Support VGA converter (optional)
• General: Supports SATA drives, supports OSD multilenguage; system auto recovery after power failure; davlight Supports recording function: supports manual recording / time / motion / alarm / network-it ensures authentication of recorded images with function Delicate. It supports network connections TCP / IP, PPPoE, DHCP and DDNS.
