Nismo R34 Skyline GT-R Z-tune
Pentru pasionați.Enjoy ;-) https://www.youtube.com/watch?v=gv17vUgM0EM
Re: Nismo R34 Skyline GT-R Z-tune
16 Attachment(s)
Some pictures.
Si niște specificații tehnice ptr. pasionații de cifre:
Engine: RB26DETT Modified spec, "Z2" (Z-tune concept engine spec.2) Type: Water-cooled in-line 6 cylinder DOHC, Twin-Turbo Displacement cu in (cc): 169 (2771) Power bhp (kW) at RPM: 500 (368 kw) / 6800 Torque lb-ft (Nm) at RPM: 399 (540) / 5200 Bore & Stroke: 87mm x 77.7mm Compression Ratio: 8.5 : 1 Redline at RPM: 9,000 rpm Brakes & Rims ABS, vented disc/vented disc – LM GT4 GT500 Model Black Color 18 x 9.5J (Exclusive for Z-tune) Brakes F/R: Bremo: Front: 365mm dia, 2-piece, Ventilated Disc + Mono-block 6 piston Caliper. Rear: 355mm dia, 1-piece, Ventilated Disc + Forged 4 Piston Caliper Tires F-R: Bridgestone POTENZA RE01R (265/35-18) Driveline: All Wheel Drive (4×4) Exterior Dimensions & Weight Weight lb (kg): 3526 (1600) Acceleration 0-60 mph: 4.0 sec Top Speed mph (km/h): 180 Mph – Limited Fuel Economy EPA city/highway mpg (l/100 km): NA Base Price: USD: $170,000 |
Aici o adresă de internet cu mai multe specificații tehnice.
http://www.nismo.co.jp/Z-tune/ |
pacat ca e RHD only ...oricum, singura masina 4x4 pe care as da atatia bani ...extraordinara piesa
Sincer, dacă aș avea una, m-aș putea obișnui cu volanul pe dreapta.Cred că și tu ai putea,nu?;)
9 Attachment(s)
Încă câteva poze.
Link-ul nu mai merge așa că...
| All times are GMT +2. The time now is 12:22. |
