vand doua statii statii AEG Funky 50
Statii AEG Funky 50 pereche in 446 MHZ - PMR. Pret 100 RON
- au o raza de acoperire destul de mare,de 3 km. - odata incarcati,acumulatorii rezista si 3 zile ,in regim de vorbit 8-9 ore / zi. • 8 channels with 38 CTCSS sub-code function and scrambler function • Output power adjustable (500mW/200mW) • Up to 8 km range • Backlit LC-Display • Mosquito repel function • VOX function (Two-way speakerphone) • Dual watch – monitoring 2 channels • Scan channel function • 10 call-tone melodies • Electronic volume control with automatic level control • Stop watch function • Battery level display • Key tone and key lock • Headset jack • Removable belt clip Supplies: • 2 PMR • 2 headsets with PTT-button • 2 NiMH rechargeable batterie packs (each 700 mAh) incl. 2 charging adaptors am doar incarcator la ele... |
Re: vand doua statii statii AEG Funky 50
Salut,
Sunt interesat de statiile tale AEG. Ce vechime au statiile tale si de ce le vinzi ? Cat le tin acumulatoarele in mod real? nu cat zici tu acolo in descriere... |
0762 937 427
| All times are GMT +2. The time now is 18:54. |
