Ceasuri Seiko, Citizen, Casio - originale - noi
Toate ceasurile sunt noi si nefolosite. Nu se accepta schimburi,decat cu bani.Preturile nu sunt discutabile(In medie sunt la jumatate fata de importator)
Ceasurile se livreaza din stoc. Pentru comenzi 0733054451 sau 0765054451 Casio Protrek PRG90T - 695 RON - Poza 1 Titanium band and Case Electro-luminescent backlight Full auto EL light, afterglow Solar powered Low-temperature resistant (-10 °C/14 °F) Digital compass Measures and displays direction as one of 16 points Measuring range: 0 ° to 359 ° Measuring unit: 1 ° 20 seconds continuous measurement Graphic direction pointer Bidirectional calibration and northerly calibration function Altimeter Measuring range: -700 to 10,000 m (-2,300 to 32,800 ft.) Measuring unit: 5 m (20 ft.) Auto memory measurements (up to 40 records, each including altitude, month, date, time) High Altitude / Low Altitude Memory Cumulative Ascent / Descent Memory Relative Altitude Display Altitude Tendency Graph Altitude Differential Graphic Altitude alarm *Changeover between meters (m) and feet (ft) Barometer Display range: 260 to 1,100 hPa (7.65 to 32.45 inHg) Display unit: 1 hPa (0.05 inHg) Atmospheric pressure tendency graph Atmospheric pressure differential graphic *Changeover between hPa and inHg Thermometer Display range: -10 to 60 °C (14 to 140 °F) Display unit: 0.1 °C (0.2 °F) *Changeover between Celsius ( °C) and Fahrenheit ( °F) Duplex LC display World time 29 time zones (30 cities), city code display, daylight saving on/off 1/100-second stopwatch Measuring capacity: 9:59''59.99'''' Measuring modes: Elapsed time, split time, 1st-2nd place times Countdown timer Measuring unit: 1 second Countdown range: 60 minutes Countdown start time setting range: 1 to 60 minutes (1-minute increments) Others: Auto-repeat, progress beeper Daily alarms 5 independent daily alarms Hourly time signal Battery power indicator Power save function (automatically disables LCD if the watch is left in the dark for approximately 60 to 70 minutes, and sensor measurements if the watch is left in the dark for six or seven days) Auto-calendar (to year 2099) 12/24-hour format Regular timekeeping: Hour, minutes, seconds, pm, month, date, day Accuracy: ±15 seconds per month Approx. battery operating time: 6 months on Rechargeable Battery (Operation period with normal use without exposure to light after charge) 21.5 months on Rechargeable Battery (Operation period when stored in total darkness with the Power Save function ON after full charge) Casio Protrek PRG200 - 765 RON Poza 2 •Cadran electroluminescent cu full auto-iluminare (dezactivarea automata a functiei de auto-iluminare daca este suficienta lumina si activarea ei automata in conditii de slaba luminozitatea sau intuneric; selectare durata iluminare; functie After-Glow inclusa) •Ecran duplex LCD •Baterie solara •Rezistent la temperaturi joase (-10°C/14°F) •Afiseaza ora pt. 31 de fuse orare (48 orase), cod oras, actualizare ora de vara on/off •Altimetru: un senzor de presiune detecteaza modificari ale presiunii aerului si transforma aceste date in altitudine; plaja masurata: -700 pana la 10000 m (-2300 pana la 32800 ft.); unitate: 5 m (20 ft.); masurari automate (pana la 25 de inregistrari, fiecare incluzand altitudinea, luna, data, ora); memorie pt. altitudine maxima/minima; memorie urcare/coborare totala; Alte functii: setari altitudine de referinta; grafic tendinta altitudine; grafic diferential altitudine; posibilitate schimbare metri (m)/feet (ft.) •Barometru: plaja afisata: 260 pana la 1100 hPa (7.65 pana la 32.45 inHg); unitate: 1 hPa (0.05 inHg); grafic tendinta presiune atmosferica; grafic diferential presiune atmosferica; posibilitate schimbare hPa/inHg •Termometru: plaja afisata: -10° la +60° Celsius; unitate: 0.1° C (0.2 grade F) •Afisare metri urcati: aceasta functie insumeaza numarul de metri urcati •Busola digitala: un senzor de directie detecteaza nordul magnetic; 16 puncte de masurare; masurare continua 20 sec.; grafic indicator directie; functie de calibrare bidirectionala si calibrare nordica; plaja masurata: 0 pana la 359 grade; unitate: 1 grad; corectie deviere magnetica •Afisare ora rasarit, apus: pt. o anumita data; daylight pointers •Cronometru cu sutimi de secunda 1/100 s - 24 ore •Timer (cronometrare inversa) 1/1 min. - 24 ore •Timer pr. iaht: Timerul pt. iaht este folosit pt. a da startul regatelor. Cronometrarea inversa poate fi setata pt. un interval de 1 pana la 10 minute, fiind emis un semnal acustic la fiecare 1 minut trecut, dupa care se emite la fiecare 1 secunda pt. ultimele 10 secunde ramase. •5 alarme zilnice independente, beep la ora fixa •Indicator nivel baterie •Power saving (dezactiveaza automat ecranul LCD daca ceasul este lasat in intuneric pt. aprox. 60-70 minute si senzorii de masura daca ceasul este lasat in intuneric timp de 6-7 zile) •Calendar perpetuu (pre-programat pana in anul 2099) •Afisare zi si data curenta •Afisare ora in format 12h sau 24h •Buton sunet operatii on/off •Geam din cristal mineral •Bratara din silicon •Rezistenta la apa (10 bar / 100m) Casio Sea Pathfinder SPF40T - 650 RON - Poza 3 Case: Titanium Band: Titanium bracelet with fold-over clasp Digital dial with silver-tone compass bezel Quartz movement Low temperature resistant Electro-luminescent backlight Auto light switch-Backlight goes on when the watch is tilted toward your face Digital compass: measures and displays in 16 directions, Measuring range 0 to 359 degrees, measuring unit: 1 degree. Memory capacity: 5 sets of measurement data with direction, month, date, and measurements time. Abnormal magnetic field detect function. Bi-directional calibration and northerly calibration function. Rotating direction bezel Barometer: Measuring range: 18.00 inHg to 32.45 inHg. (610 hPa to 1100 hPa), measuring unit 0.05 inHg (1 hPa), tendency graph display of atmospheric pressure. Changeover between inHg to hPa Thermometer: Measuring range: -14 degrees F to 140 degrees F. (-10 C to 60 C), measuring unit: 0.2F (0.1 C). Changeover between Celsius to Fahrenheit Yacht Race Timer Moon age display Tide graph display 1/100 second stop watch. Measuring mode: elapsed time, split time, 1st-2nd place time. Alarm chronograph Daily alarm Hourly time signal Regular time keeping: hour, minute, second, am/pm, month, date, day 12/24-hour format Auto calendar Stainless steel back 100 meters/330 feet water-resistant Seiko Atlas Compass SKZ223K1 - 700 RON Poza 4 Caliber: 7S36 (23 Jewels) Automatic Stainless steel With Map Meter: 1/50000 Calculate traveling distances and compass direction using classic technology. The left crown is used to trace distance on a map. Maps using the 1:50000 M scale can be read directly. Water Resistance: 200 m Case: 42 mm x 13 mm in thickness (w/o crown) Case: 55 mm x 13 mm in thickness (w/crown) Blue dial with rotating compass and luminous green hands Magnetic resistant Bi-directional rotating Compass Bezel Hardlex crystal Solid link SS bracelet with 2 pushed in safety lock Citizen Sailhawk JR4000-55L - 765 RON - Poza 5 Solar power Japan made Eco Drive Movement Digital Day & Date Display Time Display in Digital and Analogue Chronograph Stopwatch Measures up to 24 Hours in 1/100 Sec. Yacht Racing Timer Time & Calendar in 22 Time Zones (30 Cities) 99 Minute Countdown Timer 2 World Time Alarms Insufficient Charge Indicator Time Setting warning & Overcharging Prevention feature 330Ft (100m) Water Resistant Rotational Bezel with Elapsed Minutes Scale. Screw Lock Case-Back Stainless Steel case and bracelet |
Re: Ceasuri Seiko, Citizen, Casio - originale - noi
valabil
up - valabil
| All times are GMT +2. The time now is 07:10. |
