cumpar amplificator auto pe 4 canale !!!!
cumpar amplificator auto pe 4 canale nu prea scump......ceva acceptabil.
astept oferte, multumesc |
Re: cumpar amplificator auto pe 4 canale !!!!
Vand statie DLS The Classic CA50. Nominal output of 4 x 50 Watts + 1 x 170 Watts on a mono sub channel.
Detalii tehince: - Mode : AB - Number of channels : 5 - Nominal power output in 4 ohm (0,1% THD) : 4 x 50 W - Maximum power output in 2 ohm (0,2% THD) : 4 x 100 W - Maxpower output mono channel in 4 ohm : 170 W - Max power output mono channel in 2 ohm : 280 W - Frequency range : 10 Hz - 30 kHz - S / N-ratio, A-weighted : > 100 dB - Damping factor : > 100 - Input impedance low level : > 10 kohm - Input impedance, high level : 100 ohm - Input sensitivity, variable : 0,25 - 5 V - High level input with auto start : Yes - Low level output : No - Filter channel A & B : HP: 15-500 Hz. LP: 50-500 Hz / 05 - 5 kHz (x10) - Filter channel C & D : HP: 15-500 Hz / 150 Hz - 5 kHz (x10). LP: 50-500 Hz - Filter channel E : LP: 50 - 500 Hz + subsonic 25 Hz - Phase control 0 - 180 degrees : No - Current draw, idle : 1,0 A - Fuse value : 3 x 30 A - Dimensions H x D x B : 51,5 x 400 x 290 mm Duce un sistem intreg, 4 boxe + 1 woofer. Putere si clariate la superlativ. Statia este noua, se face proba, factura + garantie 12 luni. Pret: 6 mil. negociabil Yahoo Messenger: sefu_misu Tel: 0721 33 11 55 |
utra drive uda 504
4ohm 30khz thd 1% 4* 150w 2ohm 30khz thd 1% 4* 180w 4ohm 1khz mono briged 2*300w sigurante 2*20a dimensiuni 345*260*50mm preul este 4,2 mil |
blaupunkt 4*75 watt +150 subwoofer pret 4 mil
statia blaupunkt postata tot p aici nou noutza tzipla 600 w RMS
pe 4 x cabale 4 x 140 W 5,5 mil |
pe 4 x cabale 4 x 140 W 5,5 mil 0726 191 323 |
poze cu ea
Am si eu ceva statii, dar mai bine spunemi la ce pret vrei ? si la ce vrei sa folosesti ? sau ce lada de bass sau tub ai ?
am mai multe firme: KENWOOD 4x150W LA 4,2 MIL KENWOOD 4x100W LA 3,5 MIL KENWOOD MONOBLOK DIGITAL KAC8152D 300W/4 OHMI SI 500W/2 OHMI LA 7,8 MIL SONY XPLOD 4x100w la 3,5 mil PYLE 1000W, 4x250W LA 3,6 MIL GELGARD INDY 480W 4x120W LA 2,9 MIL CRUNCH P4125 4x125W LA 4,2 MIL ... DACA VREI CEVA MAI BINE SUNAMA LA 0721.818.345 SAU ID MS sim_seba |
| All times are GMT +2. The time now is 19:59. |
