Vand router wireless Buffalo G54
Routerul este nou,a fost desigilat doar pentru a fi probat. are toate accesoriile de la producator, cabluri, cd instalare si de folosire. pretul este de 200ron neg.
Product Description From the manufacturer The Wireless-G MIMO Performance Router & Access Point with High Gain Antenna combines the High Power wireless performance with Buffalo’s AirStation One-Touch Secure System (AOSS). Uniquely equipped with a built-in signal amplifier, the WHR-HP-G54 produces a true 60% increase in wireless transmit power over a standard 802.11g wireless router. WHR-HP-G54 extends the range of standard 802.11g client devices by up to 70% and improves overall performance by up to 50%. This Smart Router automatically detects and configures your Cable or DSL internet connection. Security features include WPA, WEP, Privacy Separator, Intrusion Detector, and SPI firewall. In addition to fast wireless performance, WHR-HP-G54 features a built-in external switch between wireless router and wireless access point modes. The combination of speed, security, and push-button setup of wireless connections and internet, makes the Buffalo AirStation G54 High Power Wireless Cable/DSL Smart Router the perfect choice for your wireless network. Features Built-in Amplifier Improves Wireless Performance and Extends Range 802.11g Wireless 125 High- Speed Mode Transfer Rates When Used with 125 High-Speed Mode Adapter (Turbo G) Simple Web Browser Configuration Supports WDS To Increase Coverage With Optional Repeater External Switch To Instantly Change Between Wireless Router and Wireless Access Point Easy Setup with AirStation One-Touch Secure System (AOSS) Automatic Channel Support Selects Best Available Wireless Networking Channel Supports WPA-PSK (TKIP, AES) and 128/64-bit WEP Security Includes NAT and SPI Firewall and Intrusion Detector Dynamic Packet Filtering Built-in DHCP Server Built-in 10/100 4-Port Auto-Sensing Switch Optimized High-Speed Routing, up to 5 Times Faster than Standard Routers Great Value. Higher Performance than Standard 802.11g at Comparable Prices RP-SMA to MC coupler required for use with the WLE-DA2, WLE-HG-NDR and WLE-MYG antennas. Coupler not included. Works seamlessly with Nintendo DS mai multe detalii pe prv msg sau la mail [email protected] |
Re: Vand router wireless Buffalo G54
sus cu el
s-a dat, se poate inchide
| All times are GMT +2. The time now is 07:11. |
