db9 vs m6 vs rs4
db9
Type: V12 Displacement cu in (cc): 362 (5935) Power bhp (kW) at RPM: 450(331) / 6000 Torque lb-ft (Nm) at RPM: 420(570) / 5000 Redline at RPM: n.a. Brakes & Tires Brakes F/R: ABS, vented disc/vented disc Tires F-R: 235/40 - 275/35 ZR19 Driveline: Rear Wheel Drive Exterior Dimensions & Weight Length × Width × Height in: 183.2 × 73.1 × 51.4 Weight lb (kg): 3769 (1710) Performance Acceleration 0-62 mph s: 4.7 Top Speed mph (km/h): 186 (300) Fuel Economy EPA city/highway mpg (l/100 km): n.a. m6 Type: V10 Displacement cu in (cc): 301 (4941) Power bhp (kW) at RPM: 500(373) / 7750 Torque lb-ft (Nm) at RPM: 383(520) / 6100 Redline at RPM: 8250 Brakes & Tires Brakes F/R: ABS, vented disc/vented disc Tires F-R: 255/40 ZR19 - 285/35 ZR19 Driveline: Rear Wheel Drive Exterior Dimensions & Weight Length × Width × Height in: 190.0 × 72.3 × 53.7 Weight lb (kg): 3769 (1710) Performance Acceleration 0-60 mph s: 4.5 Top Speed mph (km/h): 155 (250) - electronically limited Fuel Economy EPA city/highway mpg (l/100 km): n.a. (14.8) rs4 Type: V8 Displacement cu in (cc): 254 (4163) Power bhp (kW) at RPM: 420(323) / 7800 Torque lb-ft (Nm) at RPM: 317(430) / 5500 Redline at RPM: 8250 Brakes & Tires Brakes F/R: ABS, vented disc/vented disc Tires F-R: 255/40 R18 Driveline: All Wheel Drive Exterior Dimensions & Weight Length × Width × Height in: 179.0 × 70.8 × 55.2 Weight lb (kg): 3637 (1650) Performance Acceleration 0-62 mph s: 4.8 Top Speed mph (km/h): 152 (250) Fuel Economy EPA city/highway mpg (l/100 km): 10/20 (13.7) |
Re: db9 vs m6 vs rs4
Nustiu...yo as prefera mai degraba un Aston Martin "Bijuteria Angliei" ptr ca e mai deosebita fata de celelalte cu un design mai atragator8)
P.S:Puteai sa fi pus si tu Aston Martin Vanquish S in locu lu DB9;) |
Mentionez ca rs4 face m6 la circuit
pozeeeee . . hai baga mare!!!
cARE E CEA MAI BUNA PE CIRCUIT, SI AVAND IN VEDERE CA DB9 COSTA CAT GALARADO, AM PUS SI CATEVA POZE CU ACESTA
http://www.rsportscars.com/foto/07/gallardose05_01.jpg http://www.rsportscars.com/foto/07/gallardose05_03.jpg http://www.rsportscars.com/foto/07/g...se05_inter.jpg sI CU F430 CA E RIVAL GALARADO http://www.rsportscars.com/foto/04/f43005_inter.jpg http://www.rsportscars.com/foto/04/f43005_09_1024.jpg http://www.rsportscars.com/foto/04/f43005_03.jpg dAR SA NU NE GRABIM,, SA FIM ON TOPIC |
Deci care e cea mai buna dintre on topic???????
orikare numa da`mi un pe gratis!!! :D
Nu mah, eu vorbesc serios acum, care e cea mai buna pe circuit, am vazut ca rs4 a scos peste m6, dar nush nimik de db9, poate sa raspunda cineva
nu chiar.
Foarte interesant e faptul ca amandoua au scos acelasi timp, M6 si RS4 pe nurburgring. 8:09 e timpul, dar NU CRED CA ESTE OFICIAL. Oricum is 2 timpi care i-am gasit, daca gasiti altii care au o credibilitate mai mare atunci nu mai contez pe astea doua. F430 e regele pe circuit dintre astea. |
DB9,DB9,DB9!aia da masina super sexy si super puternica!LUX!
mi se pare o comparatie putin stupida,cum poti compara un coupe,cu un sedan cu 4 usi sau coupe super sport?fiecare masina e creata pt un scop anume
oricum as dintre ele as alege rs4 |
RS4 nu are geamuri electrice spate standard,ca nu le vad?:):):):):):)
Eu unul as merge pe Aston , mai exclusivist...desti...si m6 si RS4...se stie ca sunt niste bijuterii...despre timpi nu stiu mare lucru dar sunt relativi,e clar |
| All times are GMT +2. The time now is 08:05. |
