-   Amplificatoare mono si multicanal (https://forum.4tuning.ro/387-amplificatoare-mono-multicanal.html)
-   -   salut (https://forum.4tuning.ro/387-amplificatoare-mono-multicanal/177797-salut.html)
_Bj_ 21-03-10 11:13
salut
ce parere aveti de Amplificator auto Peiying Alien PY-2H30R
Caracteristici generale
Producator Peiying
Clasa amplificator: AB
Putere totala (W): 1200
Putere RMS (W): 200
Numar canale: 1
Frecventa de raspuns (Hz): 20Hz
Lowpass (Hz): 45Hz - 300Hz
Highpass (Hz): 45Hz - 300Hz
Informatii suplimentare: RMS Power (4 ohms): 200W
RMS Power (4 ohms) chanels: x 2
RMS Power (2 ohms): 300W
RMS Power (2 ohms) chanels: x 2
Bridged RMS Power: 500W
Bridged RMS Power chanel: x 1
Minimum Impedance Unbridged: 2Ohm
Minimum Impedance Bridged: 2Ohm
Impedance imput: 15k Ohm
Fan Cooled: No
Signal to Noise Ratio: 90dB
Channel Separation: 50dB
Remote bass boost control: 0dB - +12dB
High-Pass filter: 45Hz - 300Hz
Bass Boost: 0dB - +12dB
Low-Pass filter: 45Hz - 300Hz
Fuse Rating: 30Ax2
Dimensiuni (L x l x i mm): 510 x 245 x 60
Greutate (Kg): 4.75
