lotus exige s vs wrx sti vs evo 8 mr vs skyline
Nu stiu sa fac un poll, dar m-au uimit masinile astea.
Care credeti ca-s cele mai bune? lotus Type: Inline-4, Supercharged Displacement cu in (cc): 110 (1796) Power bhp (kW) at RPM: 218(163) / 7800 Torque lb-ft (Nm) at RPM: 159(215) / 5500 Redline at RPM: 8000 Brakes & Tires Brakes F/R: ABS, vented disc/vented disc Tires F-R: 195/50 R16 - 225/45 R17 Driveline: Rear Wheel Drive Exterior Dimensions & Weight Length × Width × Height in: 148.1 × 67.4 × 45.4 Weight lb (kg): 2057 (935) Performance Acceleration 0-60 mph s: 4.1 Top Speed mph (km/h): 148 (238) Fuel Economy EPA city/highway mpg (l/100 km): n.a. (9.1) |
Re: lotus exige s vs wrx sti vs evo 8 mr vs skyline
impreza
Type: Turbocharged Flat-4 Displacement cu in (cc): 150 (2457) Power bhp (kW) at RPM: 300(224) / 6000 Torque lb-ft (Nm) at RPM: 300(407) / 4000 Redline at RPM: n.a. Brakes & Tires Brakes F/R: ABS, vented disc/vented disc Tires F-R: 225/45 R17 Driveline: All Wheel Drive Exterior Dimensions & Weight Length × Width × Height in: 175.8 × 68.5 × 56.3 Weight lb (kg): 3351 (1521) Performance Acceleration 0-62 mph s: < 5.0 Top Speed mph (km/h): 155 (250) Fuel Economy EPA city/highway mpg (l/100 km): 18/24 (10.2) |
evo
Type: Inline-4, Turbocharged Displacement cu in (cc): 122 (1997) Power bhp (kW) at RPM: 405(302) / 6800 Torque lb-ft (Nm) at RPM: 355(481) / 5000 Redline at RPM: n.a. Brakes & Tires Brakes F/R: ABS, vented disc/vented disc Tires F-R: n.a. Driveline: All Wheel Drive Exterior Dimensions & Weight Length × Width × Height in: 175.1 × 69 × 56.6 Weight lb (kg): n.a. Performance Acceleration 0-62 mph s: 3.5 Top Speed mph (km/h): 175 (282) Fuel Economy EPA city/highway mpg (l/100 km): n.a. |
evo
skyline
Type: Inline-6, Twin-Turbo Displacement cu in (cc): 169 (2771) Power bhp (kW) at RPM: 500(368) / 6800 Torque lb-ft (Nm) at RPM: 399(540) / 5200 Redline at RPM: n.a. Brakes & Tires Brakes F/R: ABS, vented disc/vented disc Tires F-R: 265/35 R18 Driveline: All Wheel Drive Exterior Dimensions & Weight Length × Width × Height in: n.a. Weight lb (kg): 3526 (1600) Performance Acceleration 0-62 mph s: n.a. Top Speed mph (km/h): n.a. Fuel Economy EPA city/highway mpg (l/100 km): n.a. |
350z
Type: V6 Displacement cu in (cc): 214 (3498) Power bhp (kW) at RPM: 300(224) / 6400 Torque lb-ft (Nm) at RPM: 260(353) / 4800 Redline at RPM: 7000 Brakes & Tires Brakes F/R: ABS, vented disc/vented disc Tires F-R: 245/40 R18 - 265/40 R19 Driveline: Rear Wheel Drive Exterior Dimensions & Weight Length × Width × Height in: 169.8 × 71.5 × 52.1 Weight lb (kg): 3400 (1544) Performance Acceleration 0-62 mph s: n.a. Top Speed mph (km/h): 155 (250) - electronically limited Fuel Economy EPA city/highway mpg (l/100 km): 19/25 (n.a.) |
Am sa aleg skynileru ptr ca nissanurile mi se par niste masini fiabile si in plus ca din toate are performanta cea mai buna
o comparatie lipsita de sens...impreza si evo au cai putere in jurul valorii de 200,skyline-ul are 500,lotusul are 163...nu ti se pare cam aberant?
si in plus as vrea si eu sa stiu cand face un evo suta in 3.5 secunde? |
Chiar face, evo mr cauta u bine
tu cred ca nu stii ce spui...
am gasit la evo 9 4.7 secunde pana la suta si la evo 8 5 secunde... Tu cred ca nu stii ce inseamna sa iei suta in 3,5 secunde...lamborghini gallardo ia suta in 4 secunde si este de 3 ori mai scumpa ca mitsubishi evo si are motor aproape dublu...;) |
Este vorba de FQ400! Nu este evo normal!
POi ce , ala nu se cumpara?
Cam ciudat poll-ul, fara suparare,dar dupa cum am vazut in ultima vreme , orice e posibil pe 4tuning. :) Cred ca FQ si Skyline fac legea intre aceste masini (cu aceste motorizari).
Cam as e, ca au motoare mari
| All times are GMT +2. The time now is 11:17. |
