AMPLIFICATOR SUBWOOFER PENTRU SPL SI NU NUMAI!!
amplificatorul este un MNC S3000 ( http://www.cauti.ro/produs--Amplific...--3330978.html http://www.hififutar.hu/images/39628.jpg )
merge dayli use si in 0.5 ohm !!!! cateva specificatii: Hurricane S3000 Output power To 4 ohm load 1 x 1200W (distortion <0,5%) To 2 ohm load 1 x 2100W (distortion <0,2%) To 1 ohm load 1 x 3000W (distortion <0,2%) 2 ohm bridged mode 1 x 6000W (distortion <0,5%) Low-pass filter 20Hz-400Hz (24dB / octave) Bass boost 45Hz (0-18dB) High-pass filter 80Hz-1,5kHz Subsonic filter 20Hz-400Hz Frequency response 10Hz - 500Hz "A" weighted S/N ratio >90dB Input sensitivity 200mV - 6V Input impedance 22 Kohm Supply voltage DC12V (negative grounded) Speaker impedance 4ohm (in stereo mode) Dimensions: 267 x 65 x 530 mm 1800ron negociabil in limita bunului simt... tel: 0746450092 sau ym: teddyb2002002 |
Re: AMPLIFICATOR SUBWOOFER PENTRU SPL SI NU NUMAI!!
valabil!!!
| All times are GMT +2. The time now is 10:40. |
