SCHIMB cu GUME
Statie Orion Cobalt 300.2 si woofer Blaupunkt GT
Product Description Blaupunkt GT-Series GTt 1200 - car subwoofer Product Type Car subwoofer Dimensions (WxDxH) 48.4 cm Dimensions - Diameter 32.8 cm Speaker Type Passive Speaker Diameter 300mm Nominal (RMS) Output Power 200 Watt Max Output Power 650 Watt Response Bandwidth 35 - 500 Hz Input Impedance 4 Ohm Connectivity Technology Wired Speaker System Details Car subwoofer - 300mm - 200 Watt - 35 - 500 Hz - 4 Ohm Colour Black Statie Orion Cobalt 300.2 Performance RMS Power Output (Watts x Channels) 60 x 2 Peak Power Output (Watts x Channels) 150 x 2 Power at 2 Ohms (Watts x Channels) 80 x 2 Bridged Power (Watts x Channels) 150 x 1 Minimum Impedance Bridged 4 Minimum Impedance Unbridged 2 Best Frequency Response 20-30k Hz THD at Rated RMS Power 1% Signal to Noise Ratio 75 dB Input Voltage 14.4v Features Amplifier Class AB Low-Pass Crossover Frequency 50-500 Hz Low-Pass Slope (dB/octave) 12 dB/oct High-Pass Crossover Frequency 50-500 Hz High-Pass Slope (dB/octave) 12 dB/oct Bass Boost 0 dB, 6 dB, or 12 dB Bass Boost Frequency 42 Hz Fan Cooled No Fuse Rating 25 x 1 Speaker Level Inputs Harness Preamp Outputs No LED Power Indicator Yes Width (inches) 8 Height (inches) 2-1/8 Depth (inches) 8-1/8 SCHIMB cu gume 205/40/17 daca are cineva :D |
Re: SCHIMB cu GUME
vandabil
Re: SCHIMB cu GUME
am nevoie de 2 gume 205/40/17 si 2 gume 225/40/17
Re: SCHIMB cu GUME
nimeni cu 2 gume 225/40/17 ?
Re: SCHIMB cu GUME
se poate inchide.
| All times are GMT +2. The time now is 11:12. |
