-   Amplificatoare auto & stuff (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff.html)
-   -   RF POWER 750X (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff/163894-rf-power-750x.html)
Golf1 15-01-10 19:19
RF POWER 750X
Vand amplificator Rockford Foagate Power 750x in perfecta stare de functionare!
Am sa revin cu poze reale, cateva date despre amplificator din manualul de utilizare:
Continuous Power Rating (RMS) - Measured at 14.4 Battery Volts
4Ω Load Per Channel 150 Watts x 4
2Ω Load Per Channel 270 Watts x 4
4Ω Load Bridged (Mono) 525 Watts x 2
Dimensions: (with Endbell)
Height 2.4" (6.1cm) 2.4" (6.1cm)
Width 9.8" (24.89cm) 9.8" (24.89cm)
Length 13.35" (33.96cm) 18.35" (46.74cm)
Battery Fuse Rating (Amp) 60A
Signal-to-Noise Ratio >100dB A-weighted
Crossover Slope 24dB/octave Butterworth
Crossover Frequency variable from 50Hz to 250Hz
Frequency Response 20Hz to 20kHz ±0.5dB
Bandwidth 20Hz to 200kHz ±3dB
Damping Factor @ 4Ω (at output connector ) >200
Slew Rate 30 Volts/ms
IM Distortion (IHF) <0.05%
Acceptable Signal Voltage Range Variable from 250mV to 6V (RCA)
Protection NOMAD - Internal analog-computer output protection
circuitry limits power in case of overload. Thermal
switch shuts down the amplifier in case of overheating.
Equalization (45Hz Punch Bass) Rear Variable from 0dB to +18dB @ 45Hz
Input Impedance 20k ohms
kati 16-01-10 10:30
Re: RF POWER 750X
cati bani?
Golf1 16-01-10 13:11
Re: RF POWER 750X
300 euro
Golf1 20-01-10 00:29
Re: RF POWER 750X
anunt valabil!!!
Golf1 24-01-10 07:21
Re: RF POWER 750X
uppp!
Golf1 16-02-10 11:36
Re: RF POWER 750X
300 euroi...poze reale:
Golf1 13-03-10 12:16
Re: RF POWER 750X
negociabil
Golf1 24-03-10 18:24
Re: RF POWER 750X
upppp!!!!
Golf1 03-05-10 14:44
Re: RF POWER 750X
valabil
Golf1 17-06-10 06:23
Re: RF POWER 750X
valabil
Golf1 01-07-10 13:42
Re: RF POWER 750X
sus cu el!!!
Golf1 04-08-10 13:17
Re: RF POWER 750X
300 euro...
Golf1 17-08-10 12:03
Re: RF POWER 750X
UPPP! pret nou: 350 euro!
Golf1 07-10-10 11:19
Re: RF POWER 750X
amplificatorul iese de la vanzare, se poate inchide, multumesc 4T
Golf1 12-11-10 20:14
Re: RF POWER 750X
18 Attachment(s)
revine la vanzare, pret nou: 2000 lei
poze cu interiorul:
