-   -   Antas V8 Gt (https://forum.4tuning.ro/18-masini-tunate/16216-antas-v8-gt.html)
RoSonic 20-04-06 22:06
Antas V8 Gt
16 Attachment(s)
Antas V8 GT este proiectata si construita de "Carrozzeria Farallia & Mazzanti".
Motorul ce pune in miscare Antas-ul este un V8 Maserati, de 4719cmc alimentat cu ajutorul a patru carburatoare. Ca performante, acceleratia de la 0 la 100km/h se face in 5 secunde, iar viteza maxima este de 270km/h.
Pentru mai multe detalii, iata fisa tehnica:
MOTOR
Front length 8 cylinders at V of 90°
CYLINDER BORE x RUN
93,9 x 85 mm
CYLINDER
4719 cc
CURRENT
4 vertical carburettors with double body
TYPE
Weber 38DCNL5
DISTRIBUTION
4 camshafts in head; 2 valves per cylinder
POWER
310 CV A 6000 turns/min
MAX SPAN
43 Kgm at 3500 turns/min
BODY
Steel box frame
BODY
Berlinetta 2 + 2 in aluminium
FRONT SUSPENSION
The flexible transverse quadrilateral with spiral spring, telescopic shock absorbers and stabilising bar
REAR SUSPENSION
Rigid axle with telescopic shock absorbers and stabilising bar
BRAKES
Hydraulic disk - front 294 mm rear 285 mm
WHEELS
Front and rear 7J X 17"
TYRES
Front 205 / 50 X 17
Rear 225 / 55 x 17
TRANSMISSION
Rear traction
GEARS
Manual ZF 5 gears + RM
DIMENSIONS
length 4.750 mm length 1.780 mm capacity 2.750 mm height 1200 mm
TANK CAPACITY
80 litres
PERFORMANCE
Max velocity over 270 km/h
ACCELERATION
0-100 km/h in 5"
dexter_20 20-04-06 23:16
Re: Antas V8 Gt
Parca seamana a TVR oarecum....
Drako4Life 20-04-06 23:27
Re: Antas V8 Gt
Seamana...seamana....are esentza de TVR-u' combinata cu an old time car...cum erau prin anii 30'-40'. E dragutza cat de cat...nu pot zice ca nu.
andrei_1402 20-04-06 23:54
Re: Antas V8 Gt
Este o masina f spectaculoasa si aduce a TVR. Un prototip care va trece neobservat cu siguranta.
B-83-DAC 21-04-06 01:08
Re: Antas V8 Gt
misto jucarie...sper sa-mi aduca si mie iepurele una :).arata superb si are cate putin din trecut si prezent .
CarGoVroom 21-04-06 07:34
Re: Antas V8 Gt
spatele arata groaznic :sad:
mihai88 21-04-06 08:12
Re: Antas V8 Gt
spatele arata prea bine,au vrut sa faca o copie la o masina de prin 1900 toamna,mai ales cu aripioara aia din spate prinsa cu nituri,numa ca la masina de care zic io e din fata pana in spate(am un lapsus daca gasesc o poza va dau sa vedeti asemanarea),oricum nice car
isacfani 21-04-06 08:25
Re: Antas V8 Gt
masina despre care vorbesti, cred ca, este BUGATTI TYPE 57SC ATLANTIC din 1936.
mihai88 21-04-06 08:40
Re: Antas V8 Gt
cine stie cunoaste
uitate aici sa vezi asemanarea
nice car :D
CarGoVroom 21-04-06 08:40
Re: Antas V8 Gt
exact asta mi se pare ciudat...felul cum combina elementele moderne cu cele retro
Mishu-f 21-04-06 08:40
Re: Antas V8 Gt
dragutza masina ...... aduce a morgan aero 8 (are aceleasi forme) si stopurile sunt sigur k sunt de alfa romeo 147.......mi-ar place una :D
Eugen_TL 21-04-06 09:08
Re: Antas V8 Gt
e super fainutza! ca are performante de invidiat dar nici nu-ti trebuie mai mult :)
B-83-DAC 21-04-06 10:14
Re: Antas V8 Gt
arata prea bine masina chiar nu cred ca ai ce critica la ea
Lucianos 21-04-06 11:45
Re: Antas V8 Gt
Are unele elemente care o fac sa para de prin anii 50-60...Da' motoru' ala cam contrazice look-ul...interesanta pozitia stergatoarelor.Parca are unele elemente imprumutate de la Maserrati(si nu ma reer la motor...:))
MKE 21-04-06 12:37
Re: Antas V8 Gt
no comment....
