diferente evo VII - IX
Evo VII GSR
The Evo VII was the first of the CT9A models and shared the same basic chasis as the VIII, VIII MR, IX and IX MR. In keeping with Mitsi's traditional Evo line up, the top of the range model (in terms of "luxury" options) was the GSR. Evo VII RS As VII GSR, less: Air con; AYC; Electric windows; Electric folding mirrors; Brembos; Boot carpet; Enkeis alloy wheels. plus: shorter gearing. GSR deleted items could be added back as options. Evo VII RSII As VII GSR, less: Rear wash wiper Climate control Electric folding mirrors plus: air con UK Models Evo VII FQ300 As VII RSII, plus: Power Engineering exhaust (not all models) Carbon FQ300 dash inserts FQ300 carbon inserts in spoiler uprights FQ badging (not carbon) on centre console & boot Model # on Slam panel Foglight in rear cluster Ralliart panel air filter Recaro seats (various options) Evo VII GTA As VII GSR, plus: Low spoiler with LED brake light (large spoiler or no spoiler options) No bonnet vents INVECS-II Sport Mode 5A/T transmission GTA Badging 15GK compressor housing 9.0 turbine housing Slightly detuned engine (272 bhp) Revised front bumper Centrally located number plate Vibration dampening steel oil pan Steel intercooler piping Electric wing mirrors Automatic headlights Chokepipe in back box HIDs + fog lamps Clear indicator lenses Clear rear lights (inc. indicator lense) White instrument dials with revised layout including drive selected Mitsubishi steering wheel incl. mounted shift selector Centre console incl. auto gear stick Blue pearl dashboard trim, shift selector & window switch panel Blue stitching in seats, gear knob & hand brake Larger seats Adjustable arm rest with cupholders Sound insulation in dashboard, floor console, door trim & floor carpet Lower sash weather strip added to improve door sound insulation Altered suspension geometry & steering Matt finish wheels Leather seats optional Available in [Colours] Evo VIII (Chasis number CT9A 020 XXXX for GSR, CT9A 030 XXXX for MR) UK Models Evo VIII 260 2 cats (1 in down pipe, 1 in "normal" position) 5 speed gear box 9.8T housing (some with single flapper wastegate) Slightly modified Evo VII ECU (four plug with two different pins - Earth?) Euro Style Recaro interior c/w rear adjustable headrests - Leather / Suede option at cost Non-folding electric wing mirrors 8 MR pistons & head gasket No rear wash jet or wiper Small spoiler with brake light incorporated No SAS System UK style Number Plates Integrated Fog lamp in rear light cluster Single Din dash Kenwood 6 speaker CD / Radio system Large Battery Bridgestone Potenza tyres Non HID Headlights ISOfix points in rear seating 3x3 Point Rear Seat Belts Evo VIII FQ 300 as 260 plus: Upgraded blue/black interior incl. narrower seats HKS Superdragger turbo elbow back exhaust 3 Plug ECU Secondary Air System (SAS) More aggressive cams Folding electric mirrors Double Din stereo slot Climate Control Fog light in bumper Japanese-style front number plate holder Only one catalytic converter HKS Hardpipe kit HKS panel filter 6 speed gear box Yokohama Advan A046 tyres Rear brake light in windscreen Larger carbon spoiler (body colour paint on outer uprights) NB: There is confusion over which engine internals are shared between the VIII 260 and the FQ range. Evo VIII FQ 330 As VIII FQ 300 plus: upgraded black alcantara/leather interior piggy back ecu restrictor pipe connected to wastegate actuator smart nav. Evo VIII MR FQ 300 As VIII FQ 300 plus: 10.5T (single flap) housing upgraded cams MR seats and door cards carbon effect dash inserts dark brushed steel steering wheel Bilstein shock absorbers aluminium used in roof and side door beams Team Dynamic (gunmetal) alloys black background to front and rear lights slightly bigger oil cooler (more layers) twin boost solonoid optimization and reinforcement of the oil channels in the pistons uprated 5-ply head gasket added tension in piston rings, v shaped groove in second land of pistons reduced weight S-AYC diff (alu casing), higher strength hypoid gears, operates even when ABS is activated. Does not have: HKS Superdragger exhaust Available in gunmetal grey, not available in black, yellow or blue. Evo VIII MR FQ 320 As VIII MR FQ 300 plus: HKS Superdragger exhaust HKS panel filter HKS hardpipe kit Evo VIII MR FQ 340 As VIII MR FQ 320, plus: Piggy back ECU Black leather/alcantara interior Optional sat nav Evo VIII MR FQ 400 As VIII MR FQ 320, plus: Forged engine Limited edition of 100 Custom built Garrett GT Dual Ball bearing turbocharger Owen Developments custom manufactured cast s/s exhaust manifold & elbow Omega forged pistons HKS forged con rods HKS 680cc injectors Zytec ITP116 high pressure fuel pump HKS 1.6mm steel head gasket Motec M800 OEM ECU HKS iridium spark plugs Jan Speed High Flow Sports Cat Alcon competition derived 240mm high clamp mode, HD clutch with Cera-metallic 6 paddle sprung centered drive plate; HKS High Strength Head and Big End Bolts Alcon Mono6 Brake Kit with Monobloc 6 pot road caliper & 343mm curved vein disc, aluminium bell, Ferodo DS2500 pads Ralliart Aero Mirrors Carbon fibre front lip Carbon fibre rear vortex generator PIAA High Performance light & wiper upgrade Half leather and FQ400 Logo in Seats optional extra Gloss black Team Dynamics lightweight alloy wheels Import models Evo VIII GSR As UK VIII FQ 300 less: HKS Superdragger exhaust Foglight in bumper FQ Badges HKS Hardpipe kit Evo VIII RS As Evo VIII GSR plus: 5 speed box Stronger rear diff less: Air Con Alloy wheels Recaro seats Electric windows GSR deleted items available as optional extras. Evo VIII MR As Evo VIII GSR plus: 10.5T (single flap) housing Upgraded cams MR interior Bilstein shock absorbers Aluminium roof BBS alloys Black background to front and rear lights Available in gunmetal grey, not available in black, yellow or blue. Evo VIII MR RS As Evo VIII MR plus: 5 speed box Stronger rear diff Silver backed lights less: Air Con Alloy wheels Recaro seats Electric windows GSR deleted items available as optional extras. Evo IX (Chasis number: CT9A 040 XXXX) Import models Evo IX GSR As VIII MR plus: Mivec; Larger Compressor housing diffuser (16G6C) No spacesaver spare tyre Gloss black backing to front and rear lights Rear diffuser bumper Restyled front bumper with twin oval air inlets Different size rear oil return to block Plastic spoiler uprights Evo IX Enkei Alloys. Available in Cool Silver, Flame Red, Electric Blue, Frost White, Amethyst Black and Solar Yellow. Evo IX GT As IX GSR plus: Magnesium Compressor wheel Titanium turbo shaft 5 speed gearbox GT interior RS Front Diff Set Up Improved drive train Less?: Air conditioning (Optional Extra?) Electric Windows (Optional Extra?) Remote Central Locking (Optional Extra?) Evo IX MR As IX GSR plus: Self-levelling headlights No additional alarm fob (built into key); Ralliart Wing Mirrors (on some models) Carbon front lip New turbo with titanium aluminium alloy turbo fins and reduction in compressor inlet diameter (15.5) 17in, 11-spoke Speedline Turini alloy wheels Privacy glass Lowered Eibach coil springs 10mm front / 5mm rear Aluminium door sill plates Piano black dash inserts Available in Gunmetal Grey, not available in Black, yellow or blue. Evo IX MR RS As IX MR plus: RS Front Diff Set Up 5 speed gearbox Improved drive train Available in Solid White or Solid Red. Less: Air conditioning (Optional Extra?); Electric Windows (Optional Extra?); Remote Central Locking (Optional Extra?); Recaro Seats; IX Enkei alloys (comes with steel wheels). Evo IX RS As IX MR RS plus: ... Only available in Solid White? UK models Evo IX FQ 300 As IX GSR plus: Foglight PIAA lights and wipers FQ badges HKS panel filter Evo IX FQ 320 As FQ300 plus: HKS Superdragger exhaust HKS hardpipe kit Keyless entry Ralliart sports pedals Puncture repair kit Evo IX FQ 340 As IX FQ 320 plus: Smart Nav Ralliart Leather/alcantara seats Remap Evo IX FQ 360 As IX FQ 340 plus: Race Cat Ecutek remap Speedline 5 spoke alloys Triple Gauge Din Unit: battery voltage, Oil temperature and Boost (reads up to 1.5bar) Uprated 225 l/ph fuel pump Carbon vortex generator Carbon front splitter "By HKS" badge on boot Evo IX MR FQ 360 As IX MR plus: Race Cat Triple Gauge Din Unit: battery voltage, Oil temperature and Boost (reads up to 1.5bar) Ecutek remap Leather and Alcantara seats with IX MR logo (leather delete option) Carbon Vortex Generator 6 Speakers fitted as standard (excluding audio head unit) [SAYC changed to give increased torque differential across rear axle]??? Uprated fuel pump "By HKS" badge on boot Available in Cool Silver, Gunmetal Grey, Flame Red, Pearl White, not available in Black, yellow or blue. |
Re: diferente evo VII - IX
diferente intre Evo VI & Evo VI TME
front bumper dash clocks Seats Suspension (Front struts, front springs, rear shocks, rear springs, front lower arms) exhaust Turbo Colour (The TME Red,& Canal Blue,)only get with TME AYC pump |
| All times are GMT +2. The time now is 05:03. |
