se vinde piese pt bmw e30
-1 dif raport 4.10 - 100 ron
-1 set faruri stanga dreapta simple model 1 - 150 ron -1 set faruri pt faza scurta cu sticla claara si angel -100 ron -geamuri pt coupe- 50 ron buc , -oglinzi electrice -100 ron set -punte spate tamburi -50 ron - discuri duble ventilate + etrieri + placute - 200 ron st+ dr -fusta fata 90 + buza de sub ea - 200 ron -bara fata 90 + armantura + tampoane bata + semnale si bandouri -200 ron -bara spate 90 + ...................................- 150 ron -piese motor 2000 12 v jetronic motronic , motoare complete -panou spate 90 + stopuri -200 ron -roti rezerva tabla 35 ron buc -mocheta 90 impecabila pt coupe -100 ron -aeroterma -100 ron -instalatie electricacompleta urs cu check control- 150 ron -coaja bord impecabila - 100 ron -fete usi coupe piele neagra 100 ron set gri sobolan piele 100 ron set gri deschis piele + textil 100 ron set complete toate fata spate -tapiterie plafon cu trapa pt coupe - 100 ron -plastice de interior butoane fire mufe, 15 ron -caroserie coupe urs 90 impecabila -900 ron -bara fibra fata 90 -300 ron -bara fibra spate 90 -300 ron -1 jante borbet t 9 j et 30 noua 350 ron - instaltie electrica geamuri fata coupe - 200 ron set -pasaje spate urs noi , 150 ron set -porbagaj, capota urs , 100 ron amandoua -3 cutii viteza pt 6 cil , 100 ron buc -bascule st+ dr complete impecabile- 100 ron buc -debitmetru 2000 12v 150 ron - 1 cardan complet - 100 ron -bara stabilizatoare fata spate cu bielete 50 ron buc -usi coupe 100 ron -chedere geamuri luneta - 25 ron -1 baie ulei urs 18 m40 -100 ron -caseta servo -250 ron buc -caseta mecanica -100 ron -scaune recaro piele de honda pt urs 150 ron set -banchete spate urs 3 seturi , 50 ron set -ambreaje urs 6 cil , volante ,250 ron -piese e 36 caseta servo directie , bord, plastice , bara spate completa + alte piese intrebati pe forum sau id mess alexutzu_88_alex sau tel 0766741725 0728471116 din piese schimb cu urmatoarele de care am nevoie 2 cauciucuri 205 215 , 40 45 , 16 2 borbeturi 9 j , et 15 , 4 x100 diferential autoblocant rap 3 46 \3 64 volan m urs statii auto telefoane |
Re: se vinde piese pt bmw e30
saxofon e36 325 saxofon 525 e39 ,
finala e39 tampoane arc spate jug motor |
am o statie de 250w imi dai scaunele pe ea?
drace cand ai drum la buc adumi 2 jante de tabla ...
gata drace te sun inainte
O poza cu fetele de usi se poate ?!
diferentialul de 4.10 se potriveste pe E34?
pe mess iti dau poze cu fetele de usi cu toate , diferentialu merge doar dak ii pui tu capacu ala din spate de la al tau , ca are suportu ala de prindere altfel in rest merge
am vb pe pm, ramane sa ne auzim telefonic pentru diff, multumesc alexutzu.
dap te sun cand vin la buc vroiam sa vin acu joi dar imi e sila de restriciti de trafic ne auzim pe duminik lunii sal
SE >>>"VAND"<<< PIESE
:)) iincepea altfel dar sa schimbat anuntu :)) ce perspicace esti al dreaq u
uuupppppp
o baie de ulei in stare buna de M20 ai? daca da, da-mi un pret.
Mersi |
am dar a fost sudata dak te intereseaza 1 mil
| All times are GMT +2. The time now is 05:15. |
