-   Alte anunturi Car-Audio (https://forum.4tuning.ro/561-anunturi-car-audio.html)
-   -   Vind Multimedia (https://forum.4tuning.ro/561-anunturi-car-audio/15574-vind-multimedia.html)
Sebb4u 08-04-06 09:16
Vind Multimedia
6 Attachment(s)
NUMAI LA COMANDA. 20% avans, termen de livrare max. 2 saptamani.
VPA-707N - Monitor cu dvd incorporat in tetiera (se potriveste la toate modelele de masini)
PRET 900 euro ( 2 buc, se vinde doar pereche ). Culoare neagra!!!
Monitoarele intra automat in tetiera (180 grade) cind inchizi masina. Fiecare monitor are emitator IR (2 canale) asa ca se poate viziona 2 filme diferite in acelasi timp, fiecare cu sunetul respectiv. Butoanele sint luminate si fiecare monitor are telecomanda.
SPECIFIKATIONER:
 7" 16:9 Wide Screen
 High Resolution
 Motorized Viewing Angle adjustable
 Universal headrest posts
 Night Vision keyboard
 3 A/V inputs
 1 A/V Output
 Dual Channel I/R Transmitter
 Built-In Speaker
 OSD and Remote Control
 Disc Loading:Motorized Slot
 MP3 Playback (ID3 TAG,HDCD,Hybrid SACD,SVCD)
 Resolution:480x234 pixels
 Brightness:500 nits
 Viewing Angle:Left/Right:60 degrees,Top:40 degrees,Bottom:60 degrees.
S3000-ALL Car PC
Pret: 600 euro
SPECIFIKATIONER:
 Via EPIA-M Mainboard w/C3 1 GHz CPU.
 Case+DC to DC Board+AC Adaptor+USB and FireWire Kit+Chassis Fan.
 40 G HDD+512M RAM
 System Memory:512M RAM upgradable up to 1GB.
 RJ-45 LAN port 1 pc.
 PS/2 Mouse/Keyboard Port:1+1
 LPT Paralell Port:1 pc.
 COM Serial Port:1 pc.
 USB 2.0 Port:2 Front/2 Rear.
 VGA Port:Via Castle Rock
 Audio Jack:Line In/Out/Mic.
 Front Audio Connector:1 pc.
 CD-Audio Connector:1 pc.
 CTR Connector (KBMS) 1 pc.
 STR Connector (IR) 1 pc.
 Wake-On LAN Connector:1 pc.
 PCI Slot:1 pc.
 IDE Connector:2 Ultra DMA,133/100/56.
 Floppy Connector:1 pc.
 RCA/S/PDIF or TV-Out. 1 pc.
 S-Video:1 pc.
 Firewire 1394 Connector 2 pcs.
 Dimension:195x251x57 mm.
 MB:Via Mini IT (Standard 17x17 cm.)
 DC Board:72W
 Accessories:Screws Set,ATX Cable,Power SW Cable,IDE PWR Cable,USB Cable.
 Power Source:110-220V Universal AC/DC Adapter DC 12V.
MVM080AA 8" LCD Monitor cu Touch Screen si PIP
PRET: 350 euro
SPECIFIKATIONER:
 Full function remote control
 High Resolution Display 1024x768
 VGA Input
 Touch Screen
 Easy Instal 3 in one cable
 Picture in Picture
 Application:Car PC,GPS Navigation,Game,DVD,IPC,POS,Security,Medical Equipment
 LCD Display:4:3
 Display Size:162.2x121.7 mm.
 Contrast Ratio:250:1
 Brightness W/O Touchscreen:400 cd/T
 Brightness W Touchscreen:340 cd/T
 Signal Connector:20 pin MCR
 Colors:262K
 IR Remote Control
 OSD:Auto-Adjustment,Contrast,Brightness,Clock,Phase,H-Position,V-Position,Dimmer,Default,PIP/POP
 Driver & Utillity:Win.95,98,ME,2000,XP.Win.CE,Linux,(Red Hat/Mandrake),iMAC.
 Power:10-16V/1.2A
TM-8680 8" TFT/LCD Monitor Touch Screen
PRET: 300 euro
SPECIFIKATIONER:
 8" TFT/LCD Monitor+VGA+Touch Screen
 Support 640x480/1024x768 (Native 640x480)
 VGA Jack for connect to PC/Laptop directly
 2 RCA Video input and 1 Audio Input.
 Touch Screen USB Interface (Stylus Included)
 NTSC/PAL Compatible
 Built-In Speaker
 Wide View Angle U/D45/60,L/R 70 Degree
 English OSD Menue
 Can use on DVD,VCD,GPS,PS2,Rear View Camera
 High Resolution:921600 pixels
 Contrast:300:1
 Brightness:400
 Power Input:12V DC
 Dimension:203x148x30 mm.
 Accessories:Full Function Remote Control,A/V and VGA Cables,Mounting Stand,Car Cigarette Adapter,Driver/Software CD (Compatible for Windows 98,ME,NT,2000,XP,MAC) 100-240V AC/DC Wall socket,English Operation Manual
Preturile nu sint negociabile.
Hondarul 14-04-06 09:37
Re: Vind Multimedia
suna interesant ce spui tu aici... UP !!! ;)
