Re: Vand/Schimb Cd playere auto
vrei pe blaupunkt un pioneer deh 2900mp? Da pm daca esti interesat.Stima!
alpine 9853 s-a dat!
A mai ramas Blaupunkt usor defect! 100 ron schimb cu amplificator auto |
deocamdata nu mai este nimik!
daca mai dai de vreunu cu iesire pr sub si reglaj sub... iti ofer un lg lac3800r si o mik diferenta
se adauga Alpine CDE-9881r- 300 ron
radio MP3 player, model 2007 compatibil CD-R / CD-RW / MP3 / WMA / AAC / CD text / ID3 tag conexiune Full Speed pentru iPod cautare rapida DAC stabilizat 1-Bit oprire volum pe 0 biti (0 Bit Mute) pregatit pentru controlul prin comenzile de pe volan (necesita adaptor) pregatit pentru intrare auxiliara (numai cu KCE-236B) putere: 4 x 50W 2 iesiri preamplificate rear / subwoofer control volum subwoofer afisaj LCD alb pe fundal negru cu 5x9 puncte iluminare duala:verde / portocaliu filtru HPF 80 / 120 / 160Hz reglaj frecventa centrala Bass/Inalte ajustarea largimii de banda bass tuner radio MaxTune volum rotativ telecomanda (optional) panou frontal detasabil conector ISO Vine cu rama plastic, Mufa iso Cablu |
alpine vandut!
Se adauga Pioneer DEH-P3600MP Affordable yet fully featured, the icy white display with CD Text feature on this CD tuner is just the start. The DEH-P3600MP is compatible with all popular digital audio formats such as WMA, MP3 and WAV. Add in D4Q for perfect radio reception and Pioneer's MOSFET 50 W x 4 power amp with EEQ for customised power sound. Connect amps and speakers to increase the audio experience by using the 2 RCA pre-outs or create an impressive in-car entertainment centre with a TV tuner, DVD player or multi-CD changer thanks to the multiple IP-Bus control. You can have it all. Specifications Key features DEH-P3600MP WMA / MP3 / WAV / CD / RDS playback D4Q digital AM//FM RDS tuner MOSFET 50 W x 4 amplifier EEQ Equaliser System BMX (bitmetric equaliser) Bright white LED display Wired remote input Pop-out rotary volume Main features DEH-P3600MP Display illumination WHITE Cellular telephone auto muting Yes iPod® adapter ready Yes No. of Radio Presets 24 Max. output power (watts) MOSFET 4 x 50 W RCA Preout 2 (F + R) Features - General DEH-P3600MP Multi-CD Control Yes CD Text Yes Source TV Control Yes DAB Tuner Control Yes Source DVD Control EXT External unit control via IP-Bus 2 AUX-In (with optional CD-RB20) Yes Hard-wired remote input Yes ISO Connector ready Yes Rotary volume Pop-out Front Panel Flap type (mechanical) Removable Front Panel Yes Flexible angle installation 0-60° Features - Tuner DEH-P3600MP Adaptive RDS (PI, PS, AF, TP/TA) Yes ARC FM D4Q BSA (Best TP Station Auto Search) Yes PNS (Pulse Noise Suppressor) Yes BSM (Best Stations Memory) Yes Features - CD player DEH-P3600MP Oversampling digital filter 8x D/A Converter 1- Bit Fast forward/reverse Yes/Yes Track Search/Scan/Repeat Yes/Yes/Yes Track/Manual search Yes/Yes Random Play Yes Last position memory Yes Disc Title Memory Yes CD Text Yes CD-R Playback Yes MP3 Yes Windows Media™ Audio Yes CD-RW Playback Yes WAV Yes Features - Audio / Amplifier DEH-P3600MP Continuous output power (DIN45324, +B=14.4 V) 4 x 27 W Max. preout voltage (V / Ohms) 2,2 EEQ Yes 5-mode preset equaliser Yes Custom preset equaliser Yes 3-band parametric equaliser Yes Source Equalisation Memory Yes Selectable Loudness Yes Selectable FIE (Front Image Enhancer) Yes Loudness Yes Source Level Adjuster Yes Fader Yes Specifications - FM DEH-P3600MP Frequency range 87,5 - 108 MHz Usable sensitivity (75 ohms) 8 (0,7) dBf/µV S/N ratio 75 dB Frequency response 30 - 15.000 Hz Stereo separation 45 dB Specifications - MW DEH-P3600MP Frequency range 531 - 1.602 kHz Usable sensitivity 18 µV Specifications - LW DEH-P3600MP Frequency range 153 - 281 kHz Usable sensitivity 30 µV Specifications - CD DEH-P3600MP Frequency Characteristics 5 - 20.000 Hz S/N ratio 94 dB/1 kHz Dynamic range 92 dB/1 kHz Specifications - General DEH-P3600MP Urme normale de folosire, nu sare, citeste cd-urile repede! Pret 150 ron, doar cd si mufa |
poza reala!!!
3600-130 ron!!!!
Pioneer 3600 vandut!
Se adauga un Blaupunkt Seattle 74, cd defect, merge rareori, fara capac - 70 ron Radio FM, MW, LW DigiCeiver MW interference suppression RDS-EON-PTY Radio Text Digital selectivity enhancement 36 presets CD features Playback of audio CDs/CD-ROMs CD-RW-compatible CD mix CD-Text Disk Management System (DMS) MD mix MD Text MP3 features MP3 playback from CD-ROM and CD-RW Display of up to 128 directories Filename display Display of ID3 tags up to 30 characters (V1) Supports variable bit rates (8-320 kbit) Mix Scan Convenient MP3 browsing Amplifier features 4 x 26 W RMS power 4 x 50 W Max. power DEQ Max EX: Digital parametric Digital fully-parametric self-adjusting 5-band equaliser Variable EQ slope AutomaticSound (GALA) Source-specific sound adjustment Auxiliary input Loudness (programmable) X-Bass 4-channel Preamp-Out (4 V), gold-plated Sub out Sound Presets Miscellaneous features Motorised Flip Release Panel Softkey operating concept Display brightnessngle adjustment Display out (via opt. interface) Clock (RDS) Demo mode Customisable power-on message Aux naming Telephone auto-muting TMC out FM Pre-equipped for telephone/navigation speech output Full-graphics DOT display Display colour white Night design red/orange/green switchable Front design in black Steering wheel remote control RC 10 (special accessory) |
Valabil:
JVC KD-G731 USB-150 ron(cd invarte de cateva ori si il ejecteaza) vine cu rama plastic si mufa iso!!! Sony CDX-A251C - 150 ron(arata acceptabil, functioneaza fara probleme) Se pot proba!!! Schimb cu GSM sau statie auto! |
Pune niste poze cu Sony CDX-A251C,schimburi cu ce telefoane accepti
poza!
de aceeasi valoare! |
JVC USB-120 ron!
Sony -150 ron |
Ofer 100 pe sony
JVC vandut
