Thunder9922 Jack Hammer 22 subwoofer & Subwoffer Frate Nu Gluma
:shock: During the CES 2005 in Las vegas, the MTX team presented the most powerfull subwoofer ever made : 10000W, 22\", 150Kg, never done before
*The Thunder9922 Jack Hammer 22” subwoofer includes features like: -Carbon fiber and glass fiber dust cap with aluminum honeycomb center -Expanded polypropylene cone with mica filler for reduced mass and increased stiffness -FEA designed progressive roll spider with 10 AWG integrated tinsel leads woven in to allow for 2.5” of linear cone movement one way -900 ounce strontium ferrite magnet with extended magnetic field gap technology and aluminum shorting ring -6.5” voice coil with a flat wound, long-excursion design incorporating 2.5” of x-max and 17 AWG high temperature aluminum wire -Aluminum heatsink to maintain the optimum voice-coil temperature -6,000 RMS, 12,000 peak music power *The JackHammer SuperWoofer represents excess in every way and this enormous subwoofer lives for high SPL and window shattering bass. But, the T9922 is designed for sonic quality, and high SPL, what we call SQL. JackHammers are shipped in either the SPL mode, with dual 2Ω voice coils, or as the SQL model with dual 4Ω voice coils. A replaceable cone assembly is also available, for switching between \"every day\" listening (SQL), and competition (SPL). *Thunder9922 Subwoofer Specifications -Model T9922 - 44 -Description 22\" Subwoofer -Impedance Dual 4 Ω -Frequency Response 20Hz - 150 -RMS Power (Watts) 6,000 -Rec. RMS Amplifier Power (Watts) 3,000 - 6,000 -Voice Coil 6.5\" -Magnet Weight (oz.) 900 -Mounting Depth 20-3/4\" -Cut Out Diameter 20-1/4\" -Sealed Enclosure Net Volume 4.2ft3 -Vented Enclosure Net Volume 8.7ft3 -Port Dimensions (Slot Port) 24-1/8\"H x 3-3/16\"W x 10\" L -Speaker Displacement 1.8ft3 -Port Displacement .5ft3 -Tuning Frequency 32Hz -94dB sensitivity @ 2.83 volts Price: $5,999.95 *JackHammer is the most enormous, mind-blowing subwoofer ever created. You will literally not believe it until you see it. Standing in at 23” tall, 369 pounds, and with 12,000 watt peak music power handling, you will be hard-pressed to find something that will get in the ring with this heavyweight. :nosebleed eu am ramas mut cand l-am vazut pentru prima oara :shock: impresionant... nu am cuvinte :woowoo: |
Mda...intr-adevar...cu asta faci liniste :) :shock: :shock:
*JackHammer is the most enormous, mind-blowing subwoofer ever created. You will literally not believe it until you see it. Standing in at 23” tall, 369 pounds, and with 12,000 watt peak music power handling, you will be hard-pressed to find something that will get in the ring with this heavyweight. :idea: Alternativa! 8) - Ground Zero, Plutonium 15XQ :!: Thunder9922 Jack Hammer 22” 22inch Incinta Bas Reflex peste 220litri!!! Greutate... 150Kg! Wrms - 3-6.000! Peak power - 12.000! Price: $5,999.95 Ground Zero, Plutonium 15XQ 15inch Incinta Bas reflex 64 litri! Greutate... 35Kg! Wrms - 5.000! Peak power - 10.000! Price: $1,199.95 - in Romania SIAB 2005 Hala 103! |
waw
incredibil... aseara stateam linistit la tv... am avut supriza sa vad pe MTV Base la ora 00:00 Pimp My Ride unde am vazut un Buick Century 1985 (Jake's Buick)... la inceput am zis aaa... big deal... am mai vazut masini preparate... dar asta a avut ceva special... prima si singura masina pe care s-a montat un subwoofer Thunder9922 Jack Hammer 22” :yikes:
tot porbagajul acum este \"cutia\" difuzorului... iar difuzorul este montat cu magnetul catre parbriz si cu membrana cate portbagaj... ocupa tot locul din spate... am ramas socat cand am vazut ca au avut nevoie de o macara pentru monta difuzorul... 150kg.... waw... in portbagaj am vazut montate 5 amplificatoare din cea mai puternica clasa MTX http://www.mtx.com/caraudio/products...ampTA91002.jpg Thunder92001 iar la Specifications ne intereseaza doar partea asta 4Ω 4000w (Two Amps Strapped - wattage is combined power from both amps) adica in total ereau acolo vreo 10.000w... incredibil... aaa erea sa uit... si 6 condensatoare... nu am vazut exact ce ereau... dar ereau rosi si cu afisaj... si au mai pus o baterie sau parca 2 in plus.. in fine... dupa ce l-au montat... au facut si un mic test :lol: la testul asta tin sa precizez ca in biroul sefului WCC jaluzelele tremuraru, paharul cu apa i-a cazut de pe masa... ziceai ca e cutremur frate... am ramas fara cuvinte... Xzibit a spus: \"simt cum imi iese ceara din ureche...\" :dizzy: ce sa mai zic... a fost super episodul... iar tipul a cui erea masina... cand a venit sa o vada.... nu a crezut ca subul ala e real pana cand nu l-a auzit... azi o sa fac rost de mai mult poze din episod... poate chiar si de episod... wish me luck :twisted: http://www.thetrue22.com/images/MadMikeQuote.jpg http://www.thetrue22.com/images/XIBITQUOTE.jpg |
jack hammer
Jack Hammer este cel mai cel mai, eu inca nu am am vazut ceva mai puternic in viata mea. si eu am privit acest episod de la \"Pimp My Ride\", am ramas fara cuvinte... :D
Adevaraciune rau asta :yikes: Incinta lui cred ca ar trebui facut din beton ca sa ii faca fata :))
Am postat despre el pe forumuri acum vreo 4-5 luni... Dupa ce mi-a spus basicbv de el. :twisted: So....no news. Prea extrem ca sa fie o varianta valabila. Tipic american. De ce? Fiindca se poate. Fara nici un alt scop sau explicatie. Pe langa Plutonium-ul lui GZ adaug si eu SoloX-ul... Care ramane mama si tata lor. Sa auzim MTX-ul asta in teste comparative si mai vb. La performantele astea puteau sa-l puna la o cura de slabire. Cel putin greutatea nu e justificata. :wink:
PS: Oare sa le trimitem un mail si sa le spunem de magnetii de neodyum? :lol: |
Ahhh....am uitat de asta. Acum aprox 7 ani, intr-o fosta masina de paine ranforsata pe cat posibil. Spatiul de depozitare era camera de rezonanta si difuzorul facea presiune in cabina soferului. 10 KW din puteri Crown profesionale si generatoare externe de curent. 60 de inci, 150 db la 5 Hz si 180 db la 10 Hz. Masina a implodat la primele probe. A fost reconstruita dar sistemul nu a mai fost testat dupa aceea. Si ca sa vezi mirare....tot echipa tehnica de la MTX e in spatele acestei incercari. Se poate spune ca au antecedente. Desi Richard Clark (omul din poza), proiectantul si realizatorul \"monstrului\" nu mai activeaza la MTX de ceva vreme...
Check this out: :twisted: |
180db la 10hz? :shock: moama sa moara gigi frana asta sparge kpu la juma de bucuresti :twisted:
ps: o sa revin cu detali si poze despre jack hammer |
am facut rost de clipul de la Pimp My Ride cu Jack Hammer si un wallpaper cu PIMP :D
:shock: :twisted: :arrow: |
Re:
Ce lipsa mare de curent... :? La un moment dat Mike spune ca a atins 137 db... Asta ar trebui sa impresioneze? 8) Da copiilor jucarii mari.... :lol:
@ReLLaXX man! la PMR ideea nu a fost de a testa la maxim capacitatile unui jack hammer... chiar nu stiu la cat a fost dat casetofonul ala... poate nici macar la jumate nu erea atunci cand a atins 137db... nu am fost nici eu, nici tu acolo de fata... sa vedem cum sunt reglate statiile alea... dupa parerea mea... 3bateri deepcycle 6 condensatoare 5 statii imense si un difuzor imens ca ala... scoate lejer 150db... poate cine stie... in 2006 o sa vezi masini echipate cu asa ceva la concursurile de sound :twisted:
ReLLaXX impresionant este ca la 137db difuzorul ala se misca foate putin... si totusi in biroul sefului WCC erea cutremur de gradul 6 :lol: ti-am atasat mai jos un filmulet ... uite-te la el... si gandeste-te cati db ar masura aparatul ala daca jack hammer ar misca asa :shock: ps: pt care este interesat am acasa tot epsiodul... are vreo 180Mb... il urc sus? :) |
pune-l si u pls
Pimp My Ride - 4x07 - Buick Century.avi iz UP :!: Atentie 174MB :D
:arrow: |
| All times are GMT +2. The time now is 02:20. |
