Ruf RK Spyder 2006
engine All Aluminum Opposed-6 w/Dry Sump Lubrication
position Mid Longitudinal aspiration Natural valvetrain DOHC, 4 Valves per Cyl w/VarioCam fuel feed Sequential Multi-Point Fuel Injection displacement 2687 cc / 164.0 cu in bore 85.5 mm / 3.37 in stroke 78 mm / 3.07 in power 313.2 kw / 420 bhp @ 7000 rpm hp per litre 156.31 bhp per litre torque 450 nm / 331.9 ft lbs @ 5500 rpm front brakes Brembro Discs rear brakes Brembro Discs rear tire size Not AvailableZR 17 f suspension McPherson Struts w/Transverse & Longitudinal Arms, Coil-Over-Dampers r suspension McPherson Struts w/Transverse & Longitudinal Arms, Coil-Over-Dampers transmission 5 or 6-Speed Manual w/Optional TipTronic 5-Speed top speed 286.5 kph / 178 mph 0 - 60 mph 4.4 seconds Pot spune doar ca seamana izbitor de mult cu porsche boxster ;) |
Re: Ruf RK Spyder 2006
din fata zici ca este carerra GT .....:D
ma,ce bine arata!:shock:
imi plac,in special,jantele,evacuarea si farurile.:-P |
super smecher e spatele sincer imi place evacuarea si stopurile
si jantele sunt super |
Asta arata misto... chiar este facuta cu gust chiar daca este copiata dar mie i-mi place si asa..
CE ARE? ASA NU AS PUTEA SA MERG CU EA??? |
Zici ca e porche...dar e frumoasa :D
| All times are GMT +2. The time now is 23:01. |
