STATIE AUTO ALPINE MRV-757
Vand statie ALPINE MRV-T757
Dual Channel With Bass Boost Bridgable Output Power at 12.0V (20Hz ∼ 20kHz): 2 x 150W @ 4 ohms (0.04% THD) 2 x 300W @ 2 ohms (0.3% THD) 1 x 600W @ 4 ohms Bridged (0.3% THD) Output Power at 14.4V (20Hz ∼ 20kHz): 2 x 200W @ 4 ohms (0.04% THD) 2 x 400W @ 2 ohms (0.3% THD) 1 x 800W @ 4 ohms Bridged (0.3% THD) THD at Rated RMS Power0.08 % Signal to Noise Ratio105 dB Frequency Response10 Hz - 50000 Hz High - Pass Frequency30 Hz - 200 Hz Low - Pass Frequency30 Hz - 200 Hz S/N Ratio: 105dBA (at rated power) Damping Factor: >500 MOSFET amp-Yes Fuse: 80A Dimensions: 38cm x 28cm x 6cm Weight: 5.2 kg PRET 500RON TEL 0723 583 411 |
| All times are GMT +2. The time now is 13:46. |
