Yamaha R6 Tuning
http://www.yamaha-racingparts.com/as.../bike_left.jpg
http://www.yamaha-racingparts.com/as...s/parts/66.jpg Part Number Description Price* 2C0-11181-70 0.40mm Cylinder head gasket € 67.00 2C0-11181-80 0.50mm Cylinder head gasket € 67.00 2C0-11181-85 0.55mm Cylinder head gasket € 67.00 2C0-MAINT-70 Maintenance set - including piston rings, gaskets and kit headgasket € 401.98 2C0-1351A-70 Throttle body clamp assembly € 132.18 2C0-A2460-70 Big radiator set - (by MB Motorsports) € 2252.25 2C0-A4600-70 Exhaust system - made by Akrapovic € 1590.00 5EB-A6321-72 Friction plate set € 74.24 2C0-A7400-70 Transmission set - All six gears € 2607.41 2C0-A7411-80 Optional 1st Gear set € 583.20 2C0-A7421-80 Optional 2nd Gear set € 370.37 2C0-17460-74 Drive sprocket 14T - fits 520 chain € 27.16 2C0-17460-75 Drive sprocket 15T - fits 520 chain € 27.16 2C0-17460-76 Drive sprocket 16T - fits 520 chain € 27.16 2C0-A7463-70 Sprocket nut - use with kit drive sprocket € 8.56 2C0-EG001-70 Spare engine assembly - includes throttle body € 4936.63 5VY-F37L0-2D 2D Datalogging basic set - for more information on 2D equipment please visit www.2d-kit-system.com € 1698.77 5VY-F37T0-2D Optional transmitter unit € 92.18 5VY-F37A0-2D Step 2 A/F sensor set € 740.74 5VY-F37M0-2D Step 3 memory unit set € 971.19 5VY-F37S0-2D Step 4 suspension & brake sensor set € 971.19 5VY-F37G0-2D Step 5 GPS sensor set € 788.48 http://www.yamaha-racingparts.com/as...s/parts/67.jpg Part Number Description Price* 2C0-A5491-70 Engine protector set € 101.05 2C0-C117G-70 Chassis protector set € 94.16 2C0-C1707-70 Oil catch tank set € 95.59 2C0-C3151-70 Front fork spring set - under development € 132.18 2C0-C3151-75 Front fork spring set € 132.18 2C0-C3151-80 Front fork spring set € 132.18 2C0-C3151-85 Front fork spring set € 132.18 2C0-C3495-70 Steering damper stay set - Ohlins 120mm stroke damper not included € 353.33 5SL-25445-70 Rear sprocket 45T - made by AFAM € 38.09 5SL-25446-70 Rear sprocket 46T - made by AFAM € 38.14 5SL-25447-70 Rear sprocket 47T - made by AFAM € 38.14 5SL-25448-70 Rear sprocket 48T - made by AFAM € 38.14 5SL-25449-70 Rear sprocket 49T - made by AFAM € 38.14 5SL-25450-70 Rear sprocket 50T - made by AFAM € 39.33 5SL-25451-70 Rear sprocket 51T - made by AFAM € 39.33 5SL-25452-70 Rear sprocket 52T - made by AFAM € 40.64 2C0-C6300-70 Throttle set - quick release and short stroke type € 534.16 5SL-26243-71 Tube, guide - also include in the throttle set € 101.40 2C0-C8350-70 Front stay set - made from carbon € 832.17 2C0-C7400-70 Back step set - footrest set € 914.06 2C0-C6100-70 Handle set - clip-on set € 376.53 2CO-25100-70 Front spare wheel - with bearing and spacer € 400.16 2CO-25300-70 Rear spare wheel - with bearing and spacer € 443.62 2C0-GK127-70 Front fork damper assembly - made by Ohlins € 1457.82 2C0-YA606-70 Rear shock - made by Ohlins € 952.07 2C0-SD100-70 Steering damper - made by Ohlins -120 mm damper € 261.52 http://www.yamaha-racing.com/assets/...engine_kit.jpg |
Re: Yamaha R6 Tuning
e kit-ul yec ?
adica.. e kit'ul facut de yamaha.. :)
sunt tare curios...
ce performante s-au inregistrat cu motorul facut cu acest kit si motorul stock...sa vdm si noi diferentele...daca poti sa faci rost... |
oricum si daca cumperi kit-ul asta tot mai trebuie facute niste chestii ca sa poata sa devina competitiva in supersport
Pai nu prea mai ai ce sa ii pui... Carene de carbon daca iti permiti si gata.. :D
da.o faci mai usoara.ar mai fi niste genti mai usoare si bla bla bla.oricum setarile sunt importante.din cate stiu eu orice team din supersport demonteaza morortul cu totul(unii si piesele le cantaresc,mai ales pistoanele)ca nu au voie sa le schimbe si cauta unele cu valori egale de greutate si mult conteaza gestiunea motorului daca am scris bine.din pacate exista honda si de 4 ani astia de la yamaha si-o cam iau de la ten kate.sper ca sti despre ce vorbesc si nu vorbesc degeaba.bafta
Ma.. Parerea mea este ca Yamaha este a 2-a din lume la performanta si calitate.. Prima este Suzuki uof cuorsss... :D Acum s-au cam facut de kk cu R6 2006 care la 17500 intra pe rosu dar defapt turometrul are o eroare de 9%.. Ata ete... :)
cam frumos :rolleyes2
off-topic: check this out also ;) e "de-a noastra" si a putut fi admirata la 4Tuning Day |
Ducati..? Frumusica mobra dar Ducati e un motor la care defiecare data ai cate ceva de reparat... Vorbesc din auzite... :D
Tazzy trimite si mie codu de la semnatura ta pls.
pe PM sau pe messenger [email protected] |
costa cam mult sa faci un motor racheta; dar macar in design merita sa bagi ceva banuti, si o toba ca nu se poate altfel
au probleme la electrica...magneti marelli nu sint ce-i mai buni la capitolul finisaje...fac totul foarte bine..dar lasa fire dezizolate...maruntisuri d-astea..dar..care sint detalii ce conteaza... Eu personal....nu mi`as lua altceva decat Ducati. merg intr-un fel anume... Daca aveti intrebari referitoare la DUCATI...nu ezitati sa intrebati. |
din cate am auzit,suzuki s-au cam falimentat
| All times are GMT +2. The time now is 09:17. |
