Espero 1.8
Salut tuturor! Sunt nou pe forum asa ca o sa incep prin a prezenta masina mea... ca majoritatea dintre voi am 'inceput' si eu cu o masina mai ieftina un espero 1.8 ohc GLX (C18LE) din 1995 (geamuri electrice fata-spate, oglinzi electrice, AC) cumparata de mine la ~140000 km (teoretic...ca practic cred are 140 mii peste kilometrii dupa care se reseteaza contorul :))) cu instalatie de gaz pe care ulterior am dat-o jos.
Cateva poze cu ea cand am cumparat-o: https://img41.imageshack.us/img41/962/p1010839l.th.jpg https://img202.imageshack.us/img202/4372/p1020607.th.jpg https://img35.imageshack.us/img35/5540/p1020598n.th.jpg https://img504.imageshack.us/img504/3...020053v.th.jpg https://img62.imageshack.us/img62/7722/p1020609.th.jpg Momentan am inceput sa lucrez putin la interior pentru ca se imbibase miros de tigara si alte porcarii in ea, asa ca am decis sa schimb toata tapiteria cu una facuta de mine. La partea mecanica nu am "imbunatatit" cu nimic masina, am refacut tamburii la puntea spate si am schimbat 2 seturi de rulmenti, am schimbat parbrizul, am desfundat evacuarea(toba finala plus intermediara), am desfacut si curatat+vopsit rezervorul si cam atat. Cateva poze de la demontarea vechii tapiterii: https://img41.imageshack.us/img41/8836/p1030005u.th.jpg https://img98.imageshack.us/img98/2268/p1020817.th.jpg https://img194.imageshack.us/img194/5...020815f.th.jpg https://img197.imageshack.us/img197/1...020791l.th.jpg https://img196.imageshack.us/img196/3...020788g.th.jpg https://img29.imageshack.us/img29/1748/p1020786.th.jpg https://img16.imageshack.us/img16/3884/p1020730b.th.jpg https://img41.imageshack.us/img41/70/p1020728f.th.jpg https://img29.imageshack.us/img29/7144/p1020721g.th.jpg https://img41.imageshack.us/img41/1492/p1030444b.th.jpg https://img194.imageshack.us/img194/7...020817i.th.jpg Iar aici cateva poze cu elementele pe care le-am terminat de facut...(poza cu imitatia de lemn reprezinta ideea pe care o aveam in cap cand am inceput interiorul...dar m-am razgandit din cauza 'calitatii' autocolantului. Probabil cel de la 3M este mai rezistent la variatii de temperatura). Momentan inca mai lucrez la bord... https://img24.imageshack.us/img24/7525/p1030790bf.th.jpg https://img213.imageshack.us/img213/4...030531a.th.jpg https://img24.imageshack.us/img24/2645/p1030787u.th.jpg https://img30.imageshack.us/img30/9062/p1020742e.th.jpg https://img245.imageshack.us/img245/5...030791y.th.jpg |
Re: Espero 1.8
Bun venit si tie!;) de adimrat munca depusa de tine pt acest proiect!
mai ales daca ai facut toate operatiunile singur! imi place ca te-ai ingrijit de partea functionala si estetica! totusi ar trebui implicare si la cea mecanica... tuningul vine ulterior din proiecte indraznete, bani, timp si pasiune investite! Keep up the good work! :yes: |
Re: Espero 1.8
Re: Espero 1.8
Cat te-a costat racheta?
Re: Espero 1.8
... da' tuningu' unde e ? :shock:
Re: Espero 1.8
inceputul e bun asteptam sa vedem cum va evolua masina ta in timp ....ai grija sa masinuta si la cat mai multi km cu ea
Re: Espero 1.8
Ai inceput bine,ca parte mecanica cum se prezinta,gazul de ce lai dat jos?
Re: Espero 1.8
mad runner multumesc! andutu am dat jos instalatia pentru ca nu era omologata si pentru ca se compenseaza oarecum componentele care se strica in timp datorita gazului cu diferenta de pret intre gaz si benzina/motorina, mai ales pentru ca nu fac curse lungi cu ea prea des... In rest e ok la partea mecanica, probabil o sa ii fac o segmentare mai tarziu daca o sa mai scoata fum dupa ce i-am curatat toata evacuarea. Zilele astea termin cu interiorul si o sa-mi dau seama daca necesita sau nu segmentare. In rest e ok nu are rugina, motorul nu bate deloc, alte probleme nu am detectat inca. Succes si tie cu TCK-ul! |
Re: Espero 1.8
1700e prin februarie
l.e. scuze pentru dublu post, nu imi apare butonul de edit post la postul meu precedent |
Re: Espero 1.8
Salut si bine ai venit.
Felicitari ca te-ai apucat de partea tehnica si de interior. In primul rand masina trebuie sa fie in stare tehnica buna ca sa poti face "tuning" pe ea... Intrebare: cu ce ai tapitat interiorul si cum? ce ai folosit pt lipit, cum ai intins materialul? |
Re: Espero 1.8
Re: Espero 1.8
Esti rautacius Esperache :) E la inceput deabia... plus ca a inceput frumos cu interiorul...
Mai pune niste poze cu elementele de interior :) Tu le-ai facut singur? Mai da-ne detalii :) |
Re: Espero 1.8
https://img28.imageshack.us/img28/2508/p1030784k.th.jpg https://img24.imageshack.us/img24/6413/p1020833c.th.jpg https://img16.imageshack.us/img16/8847/p1020835s.th.jpg https://img30.imageshack.us/img30/4835/p1020837z.th.jpg https://img16.imageshack.us/img16/153/p1030453z.th.jpg https://img16.imageshack.us/img16/3845/p1030458y.th.jpg https://img16.imageshack.us/img16/6104/p1030499ff.th.jpg |
Re: Espero 1.8
Foarte frumos si inventiv, mai ales inlocuirea buretelui cu folie de parchet.
Dar ca idee, din citite (auzite), am inteles ca la lipirea cu prenandez e mai usor sa se dea un strat de prenandez pe fiecare piesa, adica fata de usa si pe spatele bucatii de piele, sa se lase 10-15 min sa se usuce cat de cat, dupa care sa se lipeasca una peste alta si sa se intinda... "cica" ar merge mai usor treaba. Si am mai auzit ca ar exista in magazinele mari de profil, gen bricostore, adezivi speciali, care ar face treaba mai buna decat prenandezul. Sunt curios la final cum se va vedea interiorul. Ce e de apreciat e ca le faci singur. E usor sa dai un ban si sa ceri "aia, aia, aia...", dar mai frumos sa ti le faci singur. |
Re: Espero 1.8
Bafta ! |
| All times are GMT +2. The time now is 19:52. |
