MTX REq-3 procesor de sunet
Typically all factory stereos, even premium systems, protect original equipment speakers by reducing bass output when the volume is turned up. That's acceptable in a factory system, but it hurts low-frequency performance if you want to upgrade your factory stereo by adding amplifiers and subs.
The MTX reQ bass restoration module senses the input level from the factory stereo, adding more bass at high volume levels, while keeping bass response balanced when the volume is low. Now you can truly improve your sound while keeping your factory stereo and your steering wheel controls in tact. The MTX re-Q connects to the speaker outputs of your factory stereo. Additionally, its stereo and subwoofer preamp outputs connect to your amplifiers. Included are individual gain controls for the right, left, and sub outputs, plus low-pass and subsonic filters to maximize your sub's performance. A bass enhancement switch lets you add some additional bump in your ride when needed. signal processor restores bass when adding amps to a factory system perfect when adding amplifiers and subwoofers to an OEM (original equipment manufacturer) factory sound system right, left, and subwoofer preamp outputs low-pass and subsonic filters Bass Enhance switch 4-3/4"W x 1-1/4"H x 3-3/4"D pret 270 lei usor negociabil bucuresti 0769775148 |
Re: MTX REq-3 procesor de sunet
valabil,pretul negociabil !
250 lei,valabil incontinuare
valabil
accept unele schimburi
Am fost sceptic inainte sa il iau insa pentru cei care vor sa pastreze din diferite motive player-ul stock al masinii este excelent,are un canal pentru woofer si 2 pt difuzoare,numai ai nevoie de LOC pentru a lua semnal,se leaga direct la iesiriile de la player,mareste voltajul de preamp,scoate limitele de bass din sistem iar claritatea semnalulul este imbunatatin.Eu il vand ca vreau un dvd 2 DIN,numai are rost sa il pastrez.
valabil
| All times are GMT +2. The time now is 07:23. |
