-   VERSUS AUDIO (https://forum.4tuning.ro/183-versus-audio.html)
-   -   ROCKFORD 501X vs DLS CA41 (https://forum.4tuning.ro/183-versus-audio/14683-rockford-501x-vs-dls-ca41.html)
Swat-Cat 18-03-06 20:51
e vb de 2 statii cu parametri asemanatori.....
*singurul lucru care ma deranjeaza ca nu gasest THD pt dls....
la rockford "THD .05 % "
*mai e o chestie... rockfordu are sigurante de 40A iar DLS-ul are 60A !!!
sunt curios ce stiti de dls...merge peste ROCKFORD???
DLS CA41
RMS output per channel at 13,8 volts
Mode : AB
Number of channels : 4
Power output in 4 ohm (0,1% THD) : 4 x 70 W
Power output in 2 ohm (0,2% THD) : 4 x 125 W
Power output in 4 ohm bridge mode : 2 x 200 W
Frequency range : 10 Hz - 35 kHz
S / N-ratio, A-weighted : > 100 dB
Damping factor : > 100
Input impedance low level : > 10 kohm
Input impedance, high level : 100 ohm
Input sensitivity, variable : 0,25 - 5 V
High level input with auto start : Yes
Low level output : Yes
Filter channel A & B : HP: 15-500 Hz. LP: 50-500 Hz / 0,5 - 5 kHz (x10)
Filter channel C & D : HP: 15-500 Hz / 150 Hz - 5 kHz (x10)
Grand bass adjustable frequency : 25 - 80 Hz
Grand bass adjustable level : 0-18 dB
Current draw, idle : 0,7 A
Fuse value : 2 x 30 A
Dimensions H x D x B : 67 x 354 x 250 mm (2,63 x 13,93 x 9,84 inch)
Weight : 4,2 kg ( 9,3 lb)
Rockford Fosgate 501X
65 watts RMS x 4 at 4 ohms
125 watts RMS x 4 at 2 ohms
250 watts RMS x 2 at 4 ohms in bridged mode
2-, 3-, or 4-channel output
4-ohm stable in bridged mode
Tri-Way capable
requires 8-gauge power and ground leads wiring and hardware not included with amplifier
front and rear switchable high-pass (120 Hz, 12 dB/octave) and low-pass (80 Hz, 12 dB/octave) crossovers
MOSFET power supply and output devices
Maximum Efficiency Heat Sink Application (MEHSA) mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ noise-killing differential inputs that eliminate 80% of ground loop noise
Transana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD advanced protection circuitry for "intelligent" shutdown protection
speaker- and preamp-level inputs
preamp outputs
dB_Flex 18-03-06 23:04
Re: ROCKFORD 501X vs DLS CA41
ROCKFORD FOSGATE ........eu asta as alege fara discutii dintre cele 2....8)
vpower16v 19-03-06 12:05
nu te lua dupa sigurante ....mergi cu RF sunt ff bune...dar d unde cumperi tu rf???k din cate am cautat eu nu se aduc la noi
Swat-Cat 19-03-06 16:21
intamplarea face sa am eu pe masina....si ma trecea gandu sa il schimb cu DLS
vpower16v 19-03-06 18:15
aham da mi am amintit.........vezi sa nu faci cumva greseala sa l dai ...
KGB 21-03-06 10:58
de unde iei ROCKFORD FOSGATE ?
vpower16v 21-03-06 12:08
cik mai importa falcon....sau mai bine zis mai au p stoc amplifuri ramase din seriile mai vechi ...care sunt super ok....incerca totusi cu un tel la ei sa vezi c au p stoc...
Mamut 21-03-06 23:14
iti spun din proprie experienta ca rockfordu nu are 65x4, categoric.
are mai mult...mai ales in punte
