Cumpar amplificator
Cumpar amplificator cu 2 canale chiar si 4... dar sa fie micut, vreau sa`l pun pe un difuzor de 150 w... Nu ma intereseaza firma... vreau doar sa`l pot folosii si sa fie ieftin :D
am zis chiar si 4 canale pentru ca ma gandesc sa`mi mai pun 2 boxe medii in spate... si sa le leg la amplificator deci un amp micut si ieftin? :D |
Re: Cumpar amplificator
amplificator Concord CA75.2
-------------------------------------------------------------------------------- Concord 75.2: SPECIFICATIONS: Stereo: 75 Watts/Channel into 2 Channels less than 0.08%THD, from 20Hz-20 000Hz into 4ohms Mono: 150Watts into one Channel less than 0.2% THD, from 20Hz-20 000Hz into 4ohms Subwoofer Crossover Frequency: 100Hz Frequency Response: 15Hz - 40 000Hz Input Sensitivity Preamp Input: 300mV Input Sensitivity Speaker Input: 3V Intermodulation Distorsion: 0.05% maximum at rated output Signal-To-Noise-Ratio: more than 90db (A weighted) Input Impedance Preamp Input: 15 000 ohms Input Impedance Speaker Input: 300 ohms Maximum Power Input: 40A, 14.4V, full output Idiling Current: 0.8 Amp Pret: 160 RON negociabil Contact: 0727572585, 0740302611 |
Salut,
Am 2 amplificatoare SONY XM-255EX Amplificator 2/1 canale Capacitate de încărcare 2 Ohmi Filtru trece-jos 50-200 Hz Intrare de nivel difuzor Sursa de alimentare MOSFET Ieşire Putere maximă: 2 x 120 W sau 1 x 300 W Putere de ieşire nominală: 2 x 55 W sau 1 x 140 W (4 Ohmi) Pret: 189RON Pioneer GM-620 Putere 2*35W Pret 110RON tel: 0765.417.834 YM: b_30_hzl |
| All times are GMT +2. The time now is 22:13. |
