-   LANCIA (https://forum.4tuning.ro/178-lancia.html)
-   -   Detalii technice LANCIA {toate modelele} (https://forum.4tuning.ro/178-lancia/145197-detalii-technice-lancia-modelele.html)
ME.Beast 27-09-09 14:36
Cred că toţi posesorii de Lancia ar dorii să ştie aceste date, pentru unii mai mult, pentru alţii mai puţin importante. Vi le pun şi voua la îndemână, eu am stat ceva timp să le caut...!
* 1.6 i.e., (SPI) 78 HP, 124 Nm, 1581 ccm, 4 cylinders, 1108 kg, 170 km/h, 1989–1992
* 1.6 i.e., (SPI) 75 HP, 125 Nm, 1581 ccm, 4 cylinders, 1100 kg, 167 km/h, 1992–1994
* 1.6, (MPI) 90 HP, 127 Nm, 1581 ccm, 4 cylinders, 1140 kg, 180 km/h, 1994–1997
* 1.6 16V, (MPI) 103 HP, 145 Nm, 1581ccm, 4 cylinders, 1175 kg, 186 km/h, 1998–1999
* 1.8 i.e., (MPI) 105 HP, 143 Nm, 1756 ccm, 4 cylinders, 1200 kg, 187 km/h, 1989–1993
* 1.8 i.e., (MPI) 90 HP, 133 Nm, 1756 ccm, 4 cylinders, 1200 kg, 180 km/h, 1993–1994
* 1.8, (MPI) 101 HP, 145 Nm, 1756 ccm, 4 cylinders, 1200 kg, 185 km/h, 1994–1996
* 1.8 16V, (MPI) 113 HP, 157 Nm, 1756 ccm, 4 cylinders, 1235 kg, 195 km/h, 1996–1997
* 1.8 16V, (MPI) 131 HP, 167 Nm, 1756 ccm, 4 cylinders, 1255 kg, 203 km/h, 1996–1999
* 2.0 i.e., (MPI) 113 HP, 159 Nm, 1995 ccm, 4 cylinders, 1180 kg, 195 km/h, 1989–1994
* 2.0 automatic, (MPI) 115 HP, 162 Nm, 1995 ccm, 4 cylinders, 1210 kg, 190 km/h, 1992–1997
* 2.0 16V, (MPI) 139 HP, 185 Nm, 1995 ccm, 4 cylinders, 1260 kg, 210 km/h, 1994–1996
* 2.0 16V integrale, (MPI) 139 HP, 185 Nm, 1995 ccm, 4 cylinders, 1395 kg, 195 km/h, 1994–1997
* 2.0 turbo i.e., (MPI) 165 HP, 285 Nm, 1995 ccm, 4 cylinders, 1245 kg, 215 km/h, 1991–1994
* 2.0 i.e. integrale, (MPI) 172 HP, 275 Nm, 1995 ccm, 4 cylinders, 1345 kg, 215 km/h, 1991–1994
* 1.9 turbo ds, 92 HP, 194 Nm, 1929 ccm, 4 cylinders, 1200 kg, 180 km/h, 1989–1993
* 1.9 tds, 92 HP, 194 Nm, 1929 ccm, 4 cylinders, 1240 kg, 180 km/h, 1993–1999
Rog un moderator să facă threadul sticky dacă se poate.
Mulţumesc.
ME.Beast 27-09-09 15:27
Re: Detalii technice LANCIA {toate modelele}
2.4 20V
* 2446 cc, straight-5, DOHC, 4 valves per cylinder, 175 PS (129 kW; 173 hp) @ 6100 rpm & 230 N·m (170 lb·ft) @3750 rpm
* fitted with V.I.S
* slightly modified in 1999
[edit] 3.0 V6 24V
* 2959 cc, V6, DOHC, 4 valves per cylinder, 205 PS (151 kW; 202 hp) @ 6300 rpm & 270 N·m (200 lb·ft) @4500 rpm
* not fitted with V.I.S
2.4 Turbo DS/JTD
* originally a distributor-pump turbodiesel refitted with common rail in 1998 and hence referred to as JTD engine
* TDI - 2387 cc, turbodiesel straight-5, SOHC, 2 valves per cylinder, 124 PS (91 kW; 122 hp) @ 4250 rpm & 246 N·m (181 lb·ft) @2250 rpm
* JTD - 2387 cc common rail turbodiesel straight-5, SOHC, 2 valves per cylinder, 136 PS (100 kW; 134 hp) @ 4250 rpm & 304 N·m (224 lb·ft) @2000 rpm
* not available with automatic transmission or in the Coupé
florynvl (X29 ZMT) 28-09-09 09:42
eu am pe lancie motorul de 1.9 tds si am 59 kw (80 cai), 172 Nm, 1929 cmc, 1130 kg, 4 cilindrii ,1986.(eu am ajuns la 170 km/h)
ME.Beast 28-09-09 13:11
Eu am pus ceea ce s-a declarat ca fiind de fabrică. Daca şi-a mai pierdut din cuplu sau putere, e partea 2-a :-)
florynvl (X29 ZMT) 28-09-09 13:41
asa a iesit din fabrica, si asa scrie si in talonul masinii.a mea e din 1986, tu ai aratat acolo din 1989-1993.
semecristian 29-09-09 07:50
Eu am motorul 834F.2000 , de 148kW ( 201 CP) pe Thema , e 2.0i 16V TURBO seria 3, si nu l-ai trecut acolo. Eu zic sa ceri mai multe pareri pana sa incerci sa faci o analogie a motoarelor Lancia.
KoKozula 29-09-09 21:59
eu am 834F1.000 si 834F2.000 ... si nu apar acolo ....dar pana la urma care e ideea cu datele astea?
Eu stiu si cati cilindri am si cand a fost fabricata masina mea si si ce greutate are...
Deci?
ME.Beast 30-09-09 12:06
Deci?
Eu am pus ce am gasit, poate tu ai stiut, poate este cineva care are nevoie si vrea sa afle..te incurca cu ceva acest thread?
diddy 05-10-09 12:15
1998cmc 20v 5cilindri 114kw 1996-2001 si 107kw 1995-1996 m:838 1A
motronic bochs
Hooliganu`#1 15-10-09 11:44
Da...nici motoarele de pe Integrale care au inceput a fi facute din 89-91 si Evo 91-94 nu sunt puse...de 200cp(144 kw) si respectiv Evo 1-205 sau 210 cp si Evo 2-215 cp...bine, ca-s la fel ca ala de 200 ca au catalizator si nu mai stiu ce... :D Oricun, ajuta si astea.
GxGxG 18-11-09 18:07
asta e a mea....dar iti GARANTEZ ca sare de 180 km/h ...a mea sa dus ultima data 195 ;)
KoKozula 18-11-09 18:20
S-a dus la 195 km/h... pe bord... nu? Tu oricum nu ai 195 km/h chiar daca pe bord iti apare ca ai avea ...
GxGxG 19-11-09 06:14
sunt constient ca te pacaleste kilometrajul.....dar oricum sare de 180....
semecristian 21-11-09 13:59
LANCIA THEMA VIN ECHIPATE CU MOTOARELE:
SerieAn fabricaţiekW/HPCapacitateCod motorTipTonajPunţi
2000 i.e. 03/86 - 09/88 83/113 1995 834 B.048limuzina
2000 i.e. (834BV) 09/87 - 05/92 85/115 1995 834 B.146limuzina
2000 i.e (834AB) 09/88 - 05/9286/117 1995 834 B1.000limuzina
2000 i.e. (834B) 11/84 - 09/8888/120 1995 834 B.000limuzina
2000 i.e. 16V (834AI) 02/89 - 05/92 104/141 1995 834 B2.246limuzina
2000 i.e. 16V (834AA) 05/88 - 08/92 108/147 1995 834 B2.000limuzina
2000 i.e.Turbo (834CV) 07/86 - 05/90 110/150 1995 834 C.146limuzina
2000 16V (834FA) 08/92 - 12/93 112/152 1995 834 F1.000limuzina
2000 i.e. Turbo (834C) 11/84 - 12/87 122/166 1995 834 C.000limuzina
2000 i.e. 16V Turbo (834AL) 04/89 - 05/92 130/177 1995 834 C1.246limuzina
2000 16V Turbo (834AC) 12/88 - 06/90 133/181 1995 834 C1.000limuzina
2000 16V Turbo (834GC, 834FC) 10/92 - 07/94 148/201 1995 834 F2.000limuzina
2850 V6 i.e. (834AD, 834CD, 834BD) 06/88 - 05/92 108/147 2849 834 E.146limuzina
2850 V6 i.e. (834F) 11/84 - 09/88 110/150 2849 834 E.000limuzina
8.32 (834FS) 10/87 - 05/92 151/205 2927 F 105 L.046limuzina
8.32 (834F) 09/87 - 05/89 158/215 2927 F 105 Llimuzina
3000 V6 (834GD, 834FD) 08/92 - 07/94 126/171 2959 834 F.000limuzina
2500 Turbo D (834D) 11/84 - 09/88 74/101 2445 8144.91limuzina
2500 Turbo DS (834AE) 06/88 - 05/92 85/115 2499 8144.97limuzina
2500 Turbo DS (834AM) 05/88 - 07/92 77/105 2500 8144. 97Slimuzina
2500 Turbo DS (834FE, 834LE) 05/92 - 07/94 85/116 2500 8144.97 Ylimuzina
semecristian 21-11-09 14:01
LANCIA DELTA 09/79-01/91 VINE ECHIPATA CU MOTOARELE:
1.1 (831AB.015)01/86 - 12/90 47/64 1116 831 B8.000hatchback
1.3 (831AB.011)09/79 - 08/92 55/75 1301 831 A2.000, 831 B.000hatchback
1.3 09/83 - 08/92 58/79 1301 hatchback
1.5 (831AB.025)09/79 - 12/92 63/86 1498 831 A1.000, 831 B1.000hatchback
1.6 GT i.e. (831AB.010)05/87 - 08/92 66/90 1585 149 C2.000hatchback
1.6 GT11/82 - 04/86 77/105 1585 831 A4.000hatchback
1.6 GT i.e. (831AB.016)08/86 - 08/88 80/109 1585 831 B7.000hatchback
1.6 HF Turbo10/83 - 12/86 96/131 1585 831 A7.000hatchback
1.6 HF Turbo (831AB.020S)04/87 - 03/89 97/132 1585 831 B7.046hatchback
1.6 HF Turbo (831AB.020)08/86 - 08/88 103/140 1585 831 B3.000hatchback
1.6 HF Turbo08/86 - 05/93 122/166 1585 hatchback
1.8 S4 09/85 - 10/88 184/250 1759 hatchback
2.0 HF Integrale (831AB.019)11/86 - 08/88 122/166 1995 831 B5.000hatchback
2.0 HF Integrale (831AB.024S, 831AB.028)12/86 - 12/92 130/177 1995 831 C5.046hatchback
2.0 HF Integrale (831AB.024)10/87 - 02/89 133/181 1995 831 C5.000hatchback
2.0 16V HF Integrale (831AB.026)03/89 - 09/91 144/196 1995 831 D5.000hatchback
2.0 16V HF Evo Integrale (831AB.027)06/93 - 01/94 155/211 1995831 E5.000, 831 E5.046hatchback
1.9 Turbo DS (831AB.021)10/86 - 12/89 59/80 1929 831 D1.000hatchback
