-   -   Maybach Excelero (https://forum.4tuning.ro/18-masini-tunate/14153-maybach-excelero.html)
Venom 09-03-06 10:24
Maybach Excelero
Imi pare rau dar nu va pot da niste date tehnice pt ca nu am gasit!
NWZeu 09-03-06 11:33
Maybach Excelero
:D masina suprema aproape. Detalii
Engine:
Construction: V-engine, 60° bank angle
Number of cylinders: 12
Cubic capacity (cm ³): 5908 cm ³
Bore x stroke (mm) 83.0 x 91.0
Compression: 9.1
Valves per cylinder: 3
Valve control: Roll-rocker arm over 1 camshaft per bank
Camshaft drive: Chain
Mixture preparation: Injection
Type of fuel: Super 100 octane
Performance (kW) 515
(Hp) 700
at revs/min 5000
Max. torque: (Nm) 1020
at revs/min 2500
Exhaust gas detoxification: CAT
Engine lubrication: Oil circulating lubrication
Dimensions and weights:
Dimensions:
Wheelbase: (mm) 3390
Length: (mm) 5890
Breadth: (mm) 2140
Height: (mm) 1390
Fuel tank of capacities: (ltr) 110
Weights:
Unladen weight: (kg) 2660
Permitted total weight: (kg) 2960
Maximum load: (kg) 300
Performance:
Maximum speed 351.45
Acceleration from 0 to 100 km/h (s) 4.4
Chassis:
Wheel mounting:
front: Double wishbone axle
rear: multi link rear axle
Tires: Fulda Carat Exelero
front: 315/25 ZR 23
rear: 315/25 ZR 23
Brakes: Internally ventilated disc brakes
Type front: 4x4 piston fixed caliper (2 calipers)
Diameter: (mm) 376
Type rear: 2 x4 piston fixed caliper
Diameter: (mm) 355
ABS: yes
ESP: yes
T H E L E G E N D L I V E S
Venom 09-03-06 11:37
Maybach Excelero
multumesc mult de completare!! :)
NWZeu 09-03-06 11:38
Maybach Excelero
inca 2 poze :D
Venom 09-03-06 11:43
Maybach Excelero
mie mi se pare absolut superba!
NWZeu 09-03-06 11:56
Re: Maybach Excelero
este SUPERBA , performanta, absolut FENOMENALA
RoSonic 09-03-06 12:19
Folositi va rog search-ul inainte de a posta topic nou!!!
https://forum.4tuning.ro/showthread.p...hlight=maybach
