Re audio MX 15'' !!!!!
se vinde una bucata re audio mx 15''.......
timp de functionare max 50h pret catalog....28mil pret vanzare.....20 neg |
Re: Re audio MX 15'' !!!!!
up!!!.....
Electrical Q Value -Qes: 0.561
Mechanical Q Value -Qms: 3.098 Total Speaker Q Value -Qts: 0.475 Free Air Resonance -Fs: 20.775 Hz Equivalent Compliance -Vas: 166.25 liters One-Way, Linear Excursion -Xmax: 22 mm Efficiency -SPL 1W/1m: 86.113 dB SPL Effective Piston Area -Sd: 810 cm^2 DC Resistance -Re: 1.4 ohm Nominal Impedance -Znom: Dual 1/2 ohm Thermal Power Handling -Pe: 1500 W Force Factor -Bl: 14.56Made in USA Dual Composite 2-piece Cone • Rubber Surround • Integrated Gasket • Cast Aluminum Basket • Tork-Tite Terminal• 4" 4-layer Aluminum Voice Coil • FEA Optimized Motor Structure • Powerful Neo Magnet • Dual Progressive Spiders • Integrated Tinsel Lead MX SERIES T/S Parameters UP!!! |
Up, ca nu imi place sa raman dator ;-)
hai sus!!!
pret nou.....19mil....accept si euro:D
UP!!!
Valabil..............:D
nimeni nu vrea?
UP!!! |
18mil....SUS!!!
sus!
se accepta si variante...dvd 1din, amplif, etc! |
17 mil
sus! |
salut, accepti un schimb cu un laptop MSI L735 Gaming Series? Este in perfecta stare, windows vista preinstalat, ruleaza jocuri precum NFS undercover, Prototype fara probleme.
http://www.epravalie.ro/calculatoare.../msi/msi-l735/ |
merci ptr oferta, dar nu ma intereseaza, schimburi car-audio sau bani ca e criza:sad:
Valabil....
| All times are GMT +2. The time now is 18:39. |
