-   Electrice si Electronica (https://forum.4tuning.ro/469-electrice-electronica.html)
-   -   Vand Bujii pe puls ! (https://forum.4tuning.ro/469-electrice-electronica/140760-vand-bujii-puls.html)
GapeMan 31-08-09 13:29
Vrei mai multa putere pentru motorul tau aspirat pe benzina la un pret mic?
Poti folosi bujiile pe puls Pulstar, ultima tehnologie in domeniu.
Maresc puterea, scad timpul de raspuns al motorului si consumul, si maresc semnificativ cuplul
Rezultate superioare oricarui chip tuning pe motoarele aspirate pe benzina, fara nici un risc si la un pret mai mic!
Functioneaza prin incarcarea cu energie si descarcarea ei intr-o fractiune din timpul normal, astfel scanteia fiind mult mai puternica (1MW varf)
How it works:
Electrical energy from the engine’s power coil is stored in the built-in capacitor.
At the exact moment needed, that energy is released in an amazingly powerful and quick (two nanosecond) high-energy pulse.
Results:
Increase 0-60 MPH acceleration and torque in your car!
Every car on the market has the option of increasing 0-60 MPH acceleration simply by replacing spark plugs with Pulstar™ pulse plugs.
How can changing such small part make such a big difference?
Engine horsepower is created from ignition velocity:
The piston comparison shown on the right demonstrates how a pulse plug directly increases torque by increasing cylinder pressure.
With increased cylinder pressure, the piston is pushed down with more force, which, in turn, generates more torque to the crankshaft, more liveliness to the throttle and more power to the wheels.
Of course, if you don't use this torque to go faster, the engine does its work with less effort resulting in better fuel economy.
Ignition velocity refers to the growth of the combustion flame front, the speed of which determines the amount of energy released from the fuel. The greater the amount of ignition energy, the larger the spark. The larger the spark, the more efficiently your engine can operate to produce horsepower or, inversely, better fuel economy.
Tests at an independent laboratory demonstrate how Pulstar pulse plugs burn fuel more efficiently than spark plugs, increasing fuel efficiency.
Comparatie live cu NGK Iridium: https://www.youtube.com/watch?v=RI3Pjpq2UeQ
Disponibile pentru diferite modele de masini, trimiteti exact modelul si anul pe pm si va spun dc este.
pret: 165lei/buc
sorcer 31-08-09 14:37
Re: Vand Bujii pe puls !
ba da totusi 165 lei / bucata
GapeMan 31-08-09 14:55
Un chip tuning cat te costa?
Si ai rezultate mai bune cu bujiile pe aspirate..
markizu 31-08-09 14:59
hmmm la mine nu sunt bune de nimic ...am alfa 1.8 ts 2 bujii pe cil
GapeMan 31-08-09 15:01
Eu am de vreo 2 ani pe Hyundai Coupe.
S-a simtit imediat ca a crescut cuplul, mai ales in turatii joase.
Si urca altfel in turatii..
sorcer 31-08-09 15:07
eu am o solenza si o remapare costa 200 lei ; castig vre-o 10 cai si cuplu nu mai stiu exact cat !
GapeMan 31-08-09 17:01
Pentru alte masini costa 200-250E remaparea, cu rezultate discutabile..
sorcer 31-08-09 17:03
Stii cum ii :cu cat ii mai scumpa masina , cu atat is mai scumpe piesele , si la fel si remaparea (cu toate ca daca te gandesti bine din punct de vedere al procedeului la majoritatea se procedeaza la fel in cazul remaparii).
Catalyn 31-08-09 17:42
Ti-am trimis PM.
GapeMan 05-09-09 21:29
Pret nou: 125 lei bucata
GapeMan 14-09-09 14:26
Up...
GapeMan 23-09-09 10:24
Up!!!
vacuul 26-09-09 17:04
Cat e durata de viata?
GapeMan 26-09-09 17:51
80.000km / 4ani
GapeMan 14-10-09 16:57
UP...
