-   Talcioc (https://forum.4tuning.ro/79-talcioc.html)
-   -   SISTEM SHUTTLE CPU, UNIC. (https://forum.4tuning.ro/79-talcioc/138697-sistem-shuttle-cpu-unic.html)
topalexandru 17-08-09 16:05
Shuttle PC model SD30G2
MOBO INTEL 945GC + ICH7 CHIPSET
800/533MHZ FSB LGA 775
DUAL CHANNEL DDR2 400/533/667 SUPPORT (1GB PER SLOT/ 2GB MAX)
INTEGRATED 7.1 CHANNELS HIGH DEF. AUDIO 4 x line out / 1 x line in ( Realtek ALC888 )
GIGABIT ETHERNET CONTROLLER / 10Base-T/100Base-TX/1000Base-T - RJ-45
INTEGRATED INTEL GMA 950 VIDEO CONTROLLER (400MHz Core) /W DYNAMIC VIDEO MEMORY TECHNOLOGY 3.0, MAX. SHARED 224MB
SATA 3GB/S INTERFACE
1 x IDE
PCI EXPRESS X16 SLOT + 1 x PCI SLOT
6 x Hi-Speed USB - 4 PIN USB Type A
1 x IEEE 1394 (FireWire) - 4 PIN FireWire
1 x serial - RS-232 - 9 pin D-Sub (DB-9)
Sursa 250W HIPRO
Cooling proccesor Shuttle Cooler I.C.E. Technology CPU heat-pipe
Cooling MOBO w/ XPC Fan/cooler
INTEL CORE 2 DUO CPU / 4400 @ 2GHZ
RAM 1GB (2 x 512mb 667)
VIDEO GPU nVidia 7100GS 512MB ( en7100gs512/128m/A) @PCI XPRESS
HDD HITACHI DESKSTAR 80GB/7200RPM 3.5` SERIES
DVD-ROM Sony NEC Optiarc DV-5800E-10
Dimensiuni: 300(L)x200(W)x185(H) mm / ~ 4-6kg
PC ultramodern, mic (de dimensiunile unei cutii de pantofi), puternic si silentios. Calitatea este de asemenea la superlativ, constructia carcaselor fiind in totalitate din aluminiu eloxat si inox, sistemul de racire este deosebit de inteligent, cu heatpipe-uri si turatie variabila... etc.
Pretul mediu ptr un asemenea sistem la ocazie pe internet este in jur de min/max200-250$ doar carcasa + plaza de baza + sursa. Pachetul meu contine tot ce ar trebuii sa aibe un PC.
Tin sa precizez ca produsul a fost adus din SUA in starea actuala, nefolosit, neatins.
Ocazie, ceva destul de unic.
*** windows xp licentiat.
Poze aici: edited.
Contact: [email protected] /pm ptr nr de tel.
Ptr. cine este interesat sa-l cumpere, 1100 ron usor negociabil.
Fac schimburi cu diferite DVD playere ptr masina/ -cu/fara- navigatie! :)
