Vand amplificatoare:
1. Amplificator Magnat RX44 in stare perfecta,arata foarte bine, neumblat in el, de fapt are si sigiliu intact.
Are 4 canale, putere 4 ohmi, stereo: 4 x 125W RMS (4 x 250W max) 2 ohmi, stereo: 4 x 160W RMS (4 x 320W max) 4 ohmi in punte: 2 x 325W RMS (2 x 650W max) Raspuns in frecventa 5 Hz - 50 Khz THD < 0,05 % (1 kHz) filtre LPF si HPF variabile 40-300 Hz, 12 dB filtru subsonic 15 Hz, 12 dB Bass boost variabil 0-15 dB la 45 Hz dimensiuni 350 x 350 x 261 mm intrari / iesiri RCA aurite Constructie foarte solida: http://ampguts.realmofexcursion.com/Magnat_RX_44/ Pret: 450ron 2. Amplificator Coustic AMP 460u, 2x100w RMS @ 4ohm, 2x150w RMS @ 2ohm, 300w RMS x1 @ 4ohm, un amplificator foarte puernic, are 4 finali pe canal, in loc de 2 cum au o mare parte din amplificatoare, puterea e reala, siguranda de 40A, loudness. Arata destul de bine. Identic cu asta in interior: http://ampguts.realmofexcursion.com/Coustic_AMP-220/ Manual: http://www.coustic.com/support/pdfs/U-SERIES.PDF Pret: 350RON 3. Amplificator auto Sony Xplod 754, stare perfecta de funtionare, are cateva zgarieturi, 4x75w rms, are 2 moduri de lucru, high current pentru impedanta foarte mica 1ohm stereo sau 2 ohm bridge (1-2ohm stereo/mono) sau high voltage (2-4ohm stereo/mono), crossovere HPF si LPF reglabile, low boost, sig. 40A. Output Power at 14.4V (20Hz ∼ 20kHz): .High Current Mode: 4 x 35W @ 4 ohms (0.04% THD) 4 x 50W @ 2 ohms (0.1% THD) 2 x 100W @ 4 ohms bridged (0.1% THD) 1 ohm stereo / 2 ohms bridged stable .High Voltage Mode: 4 x 75W @ 4 ohms (0.04% THD) 4 x 100W @ 2 ohms (0.1% THD) 2 x 200W @ 4 ohms bridged (0.1% THD) THD: ≤0.005% (1kHz, 4 ohms) Freq. Response: 5Hz ∼ 50Khz (+.05/-.5 dB) Fuse: 40A Dimensions: 12.6" x 10.25" x 2" (32cm x 25.8cm x 5cm) Weight: 7.7 lbs. (3.5 kg.) Poze cu interior si specificatii: http://ampguts.realmofexcursion.com/Sony_XM-754HX/ Pret: 250ron 4. Amplficator CarSound PA-4010 , made in usa, 4x100w rms, intrare high level si low level, crossover LPF HPF, 2 sigurante de 20A. Amplificatorul nu areata bine, a fost vopsit albastru peste vopseaua originala, dar este in stare perfecta de functionare. http://ampguts.realmofexcursion.com/CarSound_PA-4010/ Pret: 200ron CONTACT: YM: adisloop Tel: 0742981568 |
Re: Vand amplificatoare:
ofer 300 ron pt Coustic AMP 460u
Sau intra pe mess sa vb! |
salut, te interseaza ceva la schimb de aici https://forum.4tuning.ro/358-zona-comerciala-rmn-valcea-bazar-servicii-talcioc/131768-vand-telefon-nokia-n93-doua-subwoofere.html pentru statia magnat rx 44 ?
Sony Xplod 754 vandut, restul valabile.
dai Magnat RX44 cu 400?
Si mai multe poze cu RX44 fiindca din cauza crizei oamenii sunt cam sceptici :)
Amplificator auto Concord CA75.2 Digital Reference Series
2x75w RMS 1x150w RMS in punte Crossover subwoofer Intrare high level Intrare low level Iesire medii-inalte neamplicata Dimensiuni aprox 30x20x5cm si 4 - 5kg. Impecabil atat optic cat si functional, nu are nici o zgarietura pe el macar, arata ca nou, am chiar si cutia. Un adevarat amplificator old school cu sunet foarte clar, detaliat si puternic si in acelasi timp nedistorsionat. FEATURES: * Stereo or Bridged Mono Operation * Active Subwoofer Crossover * Preamp and Speaker Level Inputs * Input Sensitivity Control * Fully Complimentary Audio Circuit * Direct Coupled Output Stage * Pulse Width Modulated Power Supply * Power Supply Noise Filtering * Four Way Circuit Protection System SPECIFICATIONS: Stereo: 75 Watts/Channel into 2 Channels less than 0.08%THD, from 20Hz-20 000Hz into 4ohms Mono: 150Watts into one Channel less than 0.2% THD, from 20Hz-20 000Hz into 4ohms Subwoofer Crossover Frequency: 100Hz Frequency Response: 15Hz - 40 000Hz Input Sensitivity Preamp Input: 300mV Input Sensitivity Speaker Input: 3V Intermodulation Distorsion: 0.05% maximum at rated output Signal-To-Noise-Ratio: more than 90db (A weighted) Input Impedance Preamp Input: 15 000 ohms Input Impedance Speaker Input: 300 ohms Maximum Power Input: 40A, 14.4V, full output Idiling Current: 0.8 Amp INFO: http://amp-performance.de/221-Concord-CA75-2.html Pret: 280ron |
sunt interesat de magnat rx44 ... astept pm cu ultimul pret...
Amplificator Magnat RX44 vandut
Amplficator CarSound PA-4010 vandut Valabile: - Amplificator Coustic AMP 460u pret 350ron; - Amplificator auto [b]Concord CA75.2 Digital Reference Series pret 280ron. |
RX 44 si carsound abia astept sa le fac proba luni
mersi foarte mult si bafta la vanzare up de la mine |
ai vreo statie cu 2 canale sa stie 2 ohm si sa aibe crosoover ? sa se auda doar inaltele
| All times are GMT +2. The time now is 05:35. |
