Vand/Schimb MTX 200w rms
CEA RMS Power : 2x 90W @ 2 Ohm, THD+N ≤1%
CEA RMS Power : 2x 60W @ 4 Ohm, THD+N ≤1% CEA RMS Power : 1x 180W @ 4 Ohm, THD+N ≤1% High pass x-over : 12dB/oct variable from 40 to 400Hz Low pass x-over : 12dB/oct variable from 40 to 400Hz Signal-to-Noise Ratio (1 watt) : > 80dB THD+Noise (Distortion) (1 watt) : ≤ 1% Frequency Response (±1dB) : 20Hz-30000Hz Maximum Input Signal : 6V Maximum Sensitivity : 100mV Dimensions : 310 x 180 x 55mm pret : 400 ron factura si garantie:) Accept si schimburi in special cu ampuri pe 2/4 canale nu pt subwoofere ... astept oferte ofer diferenta dupa caz :) |
| All times are GMT +2. The time now is 15:57. |
