Re: The official CRX pictures thread
Cateva poze si un filmulet care ar trebui sa faca parte din "cultura generala" a fiecarui honda enthusiast plus specificatiile buburuzei:
Power 230hp@8,100RPM Propulsion Custom 1841cc B16B SS Work's custom front mid-ship engine mounts Ported & polished cylinder head TODA Racing VTEC Killer camshafts TODA Racing valve springs JUN titanium retainers JUN Super connecting rods JUN (Cosworth) forged high-compression pistons JUN piston rings B18C crankshaft SS Work's special rocker arm SS Work's block brace/girdle SS Work's slide-type cam gears SS Work's FCR Special intake manifold SS Work's "FCR Carburetors" SS Work's stainless 70mm Racing Special exhaust SS Work's stainless 4-2-1 exhaust manifold SS Work's distributor Holly low pressure-type fuel pressure regulator Holly low pressure-type fuel pump NGK Iridium spark plugs Nagai Denshi spark plug wires SS Work's aluminum side-flow type 50mm radiator YS1 transmission Aderia 5-speed cross gear set ORC super light single clutch kit OS Giken Superlock 1.5-way LSD EG6 Civic driveshafts 1009 1989 CRX EF7 Interior View Stance Swift ID 60mm springs (12k front) Ennepetal (Bilstein) shocks Cusco carbon fiber rear shock tower bar Mugen suspension bushings Cusco suspension bushings SS Work's pillow tension rods SS Work's widened front lower control arms SS Work's widened front upper control arms SS Work's adjustable rear pillow arms SS Work's adjustable upper pillow arms SS Work's aluminum rigid stabilizer bushings SS Work's pillow stabilizer links Resistance SS Work's 4-pot front brake calipers SS Work's 300mm front brake rotors Seidoya GT600 front brake pads Seidoya SM400 rear brake pads Earl's brake hoses Wheels & Tires 15x8 Advan RG +25 offset (front) 225/50-15 Bridgestone Potenza 15x6.5 Rays TE-37 +35 offset (rear) 195/55-15 Bridgestone Potenza Exterior SS Work's light blue pearl paint w/GT line SS Work's FRP hood SS Work's FRP front fenders SS Work's F1-look front spoiler SS Work's rear diffuser SS Work's FRP doors SS Work's racing rear hatch ARC DTM -Type rear wing (originally made for Mitsubishi EVOIII) Mugen side skirts SS Work's/Elf graphics Interior Recaro SP-G seat SS Work's aluminum seat rail SS Work's one-off aluminum roll cage Nardi Classic 360mm steering wheel Electronics Nagai Denshi multi-mode meter Omori mechanical water temperature gauge Omori oil temperature gauge Omori oil pressure gauge Si un filmulet celebru (pt unii):https://www.youtube.com/watch?v=11OymdXbfFw "I'm a bit afraid of the more expensive cars behind me" ha ha ha |
stie cineva masina asta si care e povestea ei.... precizez ca amsina se afla in Bacau si e abandonata undeva ...:???:
6 Attachment(s)
Del Sol !
7 Attachment(s)
Inspiratie :D
:arrow:
