Ce Baterie imi trebuie
Sal mi-am achizitionat si eu de curand niste boxe si inpreuna cu amplificatoare pentru fiecare si as vrea sa stiu ce baterie sa imi iau si ce alternator boxele si amplificatoarele ar fi astea
Jbl CS60.4 * amplificator auto 4/3/2 canale, MOSFET * putere: o 4 ohmi: 4 x 60 W RMS o 2 ohmi: 4 x 80 W RMS o 4 ohmi, in punte: 2 x 160 W RMS * raspuns in frecventa 10 Hz - 27 kHz * bass boost variabil 0-6 dB la 45 Hz * filtre low pass si high pass variabile 30 - 320 Hz (12 dB) * nivel semnal intrare maxim 6 V * selector mod de functionare 4/3/2 canale * dimensiuni: 337 x 260 x 56 mm JBL T696 Limited * difuzoare coaxiale pe 3 cai * dimensiune: 15 x 24 cm (6"x9") * putere: 150W RMS (450W max) * raspuns in frecventa: 35Hz - 20kHz * Sensibilitate (SPL): 93dB * impedanta: 4 ohmi JBL GTO 6583C # sistem de difuzoare pe 3 cai # diametru woofer: 16,5 cm # putere: 80W RMS / 240W max # sensibilitate (2.83V @ 1m): 92dB # raspuns in frecventa: 50Hz - 21kHz # tweeter My-Ti (Mylar/titaniu) # tweeter I-Mount (kit de accesorii pentru instalarea in orice locatie) # Plus One™ woofer cone # impedanta 2 ohmi JBL GTO 6538 # difuzoare coaxiale pe 2 cai # diametru 16,5 cm # putere: 60W RMS (180W max) # raspuns in frecventa: 50Hz - 21 kHz # SPL (2.83V @ 1m): 92dB # woofer Plus One™ # tweeter My-Ti (Mylar/titaniu) # impedanta 2 ohmi JBL GT5-A402 * Canale: 2 * Tip: Class AB * Putere iesire (RMS, <1% THD+N, 4 Ohms): 2 x 40W * Putere iesire (RMS, <1% THD+N, 2 Ohms): 2 x 60W * Putere iesire (RMS, <1% THD+N, 1 Ohms): - * Putere totala (Peak): 240W * Crossover Type (12dB/Oct., 32-320Hz; Front): LP/HP/Flat * Crossover Type (12dB/Oct., 32-320Hz; Rear): - * Crossover Type (12dB/Oct., 32-320Hz; Sub): - * Signal-to-Noise (@ 1W): 85dBA * Iesiri auxiliare: No * Backlit JBL logo: Yes * Bass Boost (+6dB @ 50Hz): Yes, switch * Dimensiuni (LxWxH): 191x235x54mm JBL CS60.2 * putere: o 4 ohmi: 2 x 60 W RMS o 2 ohmi: 2 x 80 W RMS o 4 ohmi, in punte: 1 x 160 W RMS * bass boost variabil 0-6 dB la 45 Hz * filtre low pass si high pass variabile 30 - 320 Hz (12 dB) * raspuns in frecventa 10 Hz - 27 kHz * nivel semnal intrare 100mV - 6 V * dimensiuni: 225 x 260 x 57 mm si subwoofer cu amplificator ALPINE MRP-500 * amplificator 1 canal * clasa D, MOSFET * putere maxima totala 1100W * putere RMS: o 1 x 300W (4 ohmi) o 1 x 500W (2 ohmi) * raspuns in frecventa: 20Hz - 200Hz (+/-3dB) * raport semnal/zgomot: 100dBA (la putere maxima) * domeniu semnal intrare: 0.2 - 4V * modul control regim termic * filtru subsonic 15Hz * Bass EQ 0 - 12dB (la 50Hz) * crossover LPF 50 - 200Hz 24dB/oct * protectie suprasarcina * led albastru indicator power / status * conectori auriti * intrare High-level * iesire RCA non-fading * dimensiuni: 270 x 60 x 242mm * greutate: 3.7Kg. HIFONICS B12SQD4 : * Subwoofer 30 cm patrat * Putere RMS: 600W * Putere maxima: 1200W * Con din polipropilena * Membrana cusuta pentru cursa lunga * Bobina 2x4 Ohmi * Magnet 100 Oz. * Fir leonic din pladbanda impletita * Spider din Nomex. |
Re: Ce Baterie imi trebuie
Ce difuzoare vin puse pe ce amplificatoare, din cele enumerate de tine?
Ce masina primeste instalatia? |
si pe mine mar interesa aceelasi lucru care te`a int si pe tine sau inca te int in legatura cu bateri asi alternatorul dak ma poti ajuta si pe mine ms ff mult
| All times are GMT +2. The time now is 14:09. |
