-   Discutii generale moto (https://forum.4tuning.ro/571-discutii-generale-moto.html)
-   -   Yamaha YZF R6 2006... Un OZN setat pe viteza maxima... (https://forum.4tuning.ro/571-discutii-generale-moto/12148-yamaha-yzf-r6-2006-ozn-setat-viteza-maxima.html)
TazzY 26-01-06 15:00
10 Attachment(s)
MSRP* $9,499 (50th Anniversary Yellow/Black) Available from January 2006
$9,299 (Raven) Available from January 2006
$9,199 (Team Yamaha Blue/White) Available from January 2006
Engine
Type 600cc, Liquid cooled, 4-stroke, forward inclined inline 4 cylinder, DOHC, 16-titanium valves
Bore x Stroke 67.0 x 42.5mm
Compression Ratio 12.8:1
Carburetion Fuel injection w/ YCCT
Ignition TCI
Transmission 6-speed w/multi-plate clutch
Final Drive #525 V8 O-ring chain
Chassis
Suspension/Front 41mm inverted telescopic fork w/adjustable preload, separate high & low-speed compression damping, rebound damping; 4.7\" travel
Suspension/Rear Single shock w/adjustable preload, separate high & low-speed compression damping, rebound damping; 4.7\" travel
Brakes/Front Dual 310mm floating discs w/radial mount, forged 4-piston calipers
Brakes/Rear 220mm disc w/ single-piston caliper
Tires/Front 120/70-ZR17
Tires/Rear 180/55-ZR17
Dimensions
Length 80.3\"
Width 27.6\"
Height 43.3\"
Seat Height 33.5\"
Wheelbase 54.3\"
Rake (Caster Angle) 24°
Trail 3.8\"
Fuel Capacity 4.6 gallons
Oil Capacity (with oil filter change) 3.59 qts.
Dry Weight 357 lbs.
Other
Main Jet Not Applicable
Main Air Jet Not Applicable
Jet Needle Not Applicable
Needle Jet Not Applicable
Pilot Air Jet 1 Not Applicable
Pilot Outlet Not Applicable
Pilot Jet Not Applicable
Primary Reduction Ratio 85/41 (2.0731)
Secondary Reduction Ratio 45/16 (2.8125)
Gear Ratio - 1st Gear 31/12 (2.583)
Gear Ratio - 2nd Gear 32/16 (2.000)
Gear Ratio - 3rd Gear 30/18 (1.667)
Gear Ratio - 4th Gear 26/18 (1.444)
Gear Ratio - 5th Gear 27/21 (1.286)
Gear Ratio - 6th Gear 23/20 (1.150)
Warranty 1 Year (Limited Factory Warranty)
CobraArt 26-01-06 15:50
Varianta 1 mda...
AleXXL 26-01-06 17:49
avion :roll:
varianta 2 :D :D
bobbyadr 26-01-06 18:18
demna de toate laudele realizarea celor de la yamaha,eu am modelul anterior acestuia,si pot sa va spun ca aceasta este total imbunatatita,s-au intrecut pe ei insisi devenind astfel cea mai competitiva la clasa 600....
:twisted:
TazzY 27-01-06 19:42
shi eu sunt de aceeashi parere.... din vechiul R6 nu a ramas decat numele...
ono41 27-01-06 22:11
Super tare, la noi in Ro sau comandat deja cate-va dar preparate de LKM in germania.
TazzY 29-01-06 01:58
da ono dar motorul este mult prea nervos shi fara sa fie preparat... dar pentru cine vrea sa il prepare... TOT RESPECTUL.... acel motor chear merita
Eugen_TL 04-02-06 15:20
bine spui tu tazule! :) motorul e super si fara preparare ... care-l mai tuneaza nu are piulitzele toate in cap :P --- ce nu face omu sa iasa un pik in evidenta!
ono41 05-02-06 01:26
Re:
Baietii care le-au preparart sunt sportivi din campionat, daca nici macar pt curse atunci unde se merita sa se faca preparari?
TazzY 05-02-06 02:48
Banuiesc ca Pascota il prepara pe al lui.. nu .. ?
Gsx_18 05-02-06 11:01
ii aproape identica cu gsx-r 600 , aprox. aceasi putere, aceasi greutate, aceiasi technologie.... daca vrei ceva special de 600 alege kawasaki-ul
oricum ii superba si asta.
TazzY 11-02-06 16:37
nah ma ca am mers shi pe asta.. :D
paulik007 27-04-06 16:18
Re: Yamaha YZF R6 2006... Un OZN setat pe viteza maxima...
;P imi place dar the best is ..............:) BH 07 MDF:0 PT ALEXX
cosminlive 29-04-06 22:01
bijuterie.... OZN pe sistem cum ar zice Gutza :)
johnson 13-07-06 15:48
am vazut una neagra complet, modelul de anul asta la intalnirea moto de la Brasov. Arata criminal, nu cred ca este alt speed sa arate mai bine, la categoria ei de pret si cilindree.
