MOTUL SI K&N
Distribuitor de MOTUL si K&N in Romania.
Orice fel de ulei inclusiv specific pentru fiecare marca de masina de la Motul. Filtre de aer normale sau kituri de putere de la K&N. Se castiga in jur de 15-20 de cai doar din filtrul de aer. Detalii aici: http://www.knfilters.com/cold_air_intakes.htm Oferta completa o puteti gasii la adresa www.deluo.ro/oferta.xls sau dand click pe semnatura mea. daca nu stiti ce tip filtru va trebuie: http://www.knfilters.com/search/appsearch.aspx si pt ulei http://www.ew2.lubesinfo.com/login.a...3&cookies=True |
Re: MOTUL SI K&N
ma intereseaza 7100 10w40 la 4l la ce pret e si un filtru k&n 303, mersi
Re: MOTUL SI K&N
filtrul costa 59 de lei |
Re: MOTUL SI K&N
salut,ma intereseaza si pe mne pretul la 57-0136 si 57-0164,cam cu cat ar mari puterea?merci
Re: MOTUL SI K&N
Our 57 Series FIPK and 63 Series Air chargers are built for many different vehicles and represent a dramatic improvement over a K&N O/E replacement filter alone; they use only non-metallic rotationally molded tubes that can reduce air temperature and decrease intake sound over a metal tube. The aerodynamically engineered tube drives a massive amount of air into an engine, which translates into POWER The third test historically overlooked by the entire disposable air filter industry is the amount of restriction created by the filter medium. Higher restriction means more engine effort is required to provide the engine with one of the four critical components of combustion. . Air! So how do you test something nobody ever cared enough about to even consider? In this area, once again, we had to invent the test. What we did was to largely follow a protocol that had been established for measuring the flow rates of cylinder heads and carburetors at a constant rate of restriction. We use a flow bench and increase the rate of airflow until restriction equals a pressure drop sufficient to displace 1.5 inches of a consistent quantity of water. (Give example of actual filter flow rate at 11/2 water vs. 11/2 mercury). Never get confused between restrictions measured by the displacement of mercury. Mercury is approximately 13 times heavier than water, so it would truly be an apples and oranges comparison. (Give example of actual filter flow rate at 11/2 water vs. 11/2 mercury). Of course it is in this test that the power of a K&N Air Filter reveals itself. Our filters flow substantially more air than a disposable air filter and that is where the horsepower and torque increase comes from. How much more? Consider this, using a Permeability test, a square inch of our filtration medium will flow 200 or even 300% more air than a standard disposable filtration medium. When translated into an actual air filter, this often means a K&N will flow as much as 30% to 70% more air. As a rule of thumb, a 5-10% increase from the amount of power your car makes, as delivered to you, is within the realm of safety. Nearly all engine components, regardless of the manufacturer, are designed with tolerances sufficient to withstand, on average, at least a 5-10% improvement in peak power. Mai multe informatii aici: http://www.knfilters.com/audio/audio_book_mp3.htm Pretul este: 57-0136 57i International Intake Kit BMW 320I E36 w/M-Tec 95 Eur + TVA 57-0164 57i International Intake Kit BMW 320 24V E36 80 Eur +TVA |
Re: MOTUL SI K&N
salut , pret pentru 57-0139 si 57-0265-1 Astept pm ms
Re: MOTUL SI K&N
salut, preturi pentru :
un kit curatare kn #99-5000 si ulei motul 6100 Synergie+ 10W-40 4l merci |
Re: MOTUL SI K&N
99-5000 Filter Care Service Kit Aerosol RECHARGER KIT; AEROSOL OIL Pret 16 EUR |
Re: MOTUL SI K&N
seat leon 1.4l 16v 55 kw an 2002, motor axp
filtru kn si kit curatare pret pe pm;) |
Re: MOTUL SI K&N
Buna seara,
Puteti sa-mi spuneti un prêt pentru urmatoarele produse ale dvs: - ulei motor Motul 300v Power Racing – 5w-30; - ulei cutie Motul Gear 300 – 75w-90; Masina este un Ford Ka, 2001, 1,3l, 44kw, tip motor J4s. O seara excelenta, |
Re: MOTUL SI K&N
mica completare, la ulei de motor vreau 5w-40
Re: MOTUL SI K&N
MOTUL 300V Power 5W-40 Oil for High Performance gasoline and Diesel 4 stroke engine: turbocharged or not, multivalve, carburettor or injection system, with or without catalytic converter. Ref.: SUBARU WRT, World Rally championship, Formula Renault Above existing standards bidon 2 litri 37 EUR. MOTUL Gear 300 75W-90 Gearbox and rear axle lubricant, ester based, fully synthetic, specially formulated for racing and high performance cars - standards: API GL4 and GL5 / MIL-L-2105D bidon 1 litru 19 EUR |
Re: MOTUL SI K&N
Salut!
Filtru K&N, 33-2031-2, la ce pret ai? Merci! |
Re: MOTUL SI K&N
Re: MOTUL SI K&N
57-1001 ??
| All times are GMT +2. The time now is 12:12. |
