sony cdx-r3350
Aparatul se afla in stare perfecta de functionare,am si telecomanda,pretul este fix 200 roni, accept si unele schimburi.
Product Features and Technical Details Technical Details FM TUNER - Tuner Type: SSIR-EXA ABC (Automatic Bandwidth Control): YES BTM (Best Tuning Memory): YES RDS EON: YES TUNER STATION PRESETS: 18 FM, 6 MW, 6 LW CD PLAYER- Drive-S: YES CD-R Playback capability: YES CD-RW Playback capability: YES MP3 Playback capability: YES ID3 Tag display (Track, Artist, Album name): YES CD Text display: YES Title Scroll (CD Text): YES Repeat Play: YES Shuffle Play: YES AUDIO SPECIFICATIONS - Digital Filter: 8 fs D/A Converter: 1 bit Frequency Response (Hz): 10 - 20,000 Tolerance (dB): +/-1 Signal to Noise Ratio (dB): 120 AMPLIFIER - S-MOSFET Output Stage: YES Output Power, DIN 45324 at 4 ohm (W): 4 x 26 Max. Output Power, 1 kHz at 4 ohm (W): 4 x 50 EQ 3 (3 Band Equalizer): YES Pre-amp Output (stereo RCA): 1 Max. Pre-amp output level (V): 2 Sub Output (mono, RCA): NO Sub-Switch (rear out / sub out switchable): YES Selectable Low Pass Filter in Sub-mode: YES Sub Volume Control in Sub-mode: YES SAFETY COMMANDER INTERFACE - 3.5 mm Mini Jack: YES Infrared: NO OTHERS -:Display Type: 13 Segment Display Dimmer: YES Key Illumination: Red Sensor for IR Commander: YES Removable Front Panel: YES Integrated Clock: 24 h Telephone Attenuator: YES ISO Connector: YES Installation Angle (degrees): 0 - 45 SUPPLIED REMOTE CONTROL - IR Card Commander: RM-X151 OPTIONAL REMOTE CONTROL (INCL.) - Safety Commander: RM-X4S Product MPN MPN: CDXR3350 Key Features Player Type: CD MP3 Playback: MP3 Playback Anti-Theft Protection: Detachable Face Panel Amplifier / Speakers Built-In Power Amplifier: Yes Built-In Amplifier RMS Power: 4 x 26 Watts RMS Built-In Amplifier Power: 4 x 50 Watt Radio FM Presets: 18 AM Presets: 12 Tuner Type: FM / AM, RDS |
Re: sony cdx-r3350
vandut ! se poate inchide. ms.
| All times are GMT +2. The time now is 14:51. |
