-   -   Dodge Razor 2002 (https://forum.4tuning.ro/18-masini-tunate/11118-dodge-razor-2002-a.html)
Hondarul 23-12-05 09:42
Dodge Razor 2002
Nu spun mai nimic aceste specificatii... Insa mie imi place cum arata masina asta... :wink:
http://www.carfolio.com/images/dbima...75/razor_2.jpg
http://www.carfolio.com/images/dbima...8375/razor.jpg
http://www.canadianautoreview.com/ra...arside-900.jpg
http://www.carstyling.ru/resources/c...ge_razor_1.jpg
Type 2S FHC
Designer
Number of doors 2
dimensions & weights
Wheelbase 2489 mm 98 in
Track front 1473 mm 58 in
rear 1524 mm 60 in
Length 3754 mm 147.8 in
Width 1748 mm 68.8 in
Height 1214 mm 47.8 in
Length:wheelbase ratio 1.51
Ground clearance
Kerb weight 1134 kg 2500 lb
Weight distribution
(Front)
Fuel capacity
aerodynamics
Drag coefficient
Frontal Area
Cx
engine
Code
Manufacturer Chrysler
Type S-4
DOHC
16 valves total
4 valves per cylinder
Main bearings
Construction
Bore × stroke
Bore/Stroke ratio
Displacement 2400 cc
(146.457 cu in)
Unitary capacity 600 cc/cylinder
Compression ratio
Fuel system
Aspiration Turbo
Compressor type
Intercooler Y
Catalytic Converter Y
Max. output 253.5 PS (250.0 bhp) (186.4 kW)
Max. torque 312.0 Nm (230 lbft) (31.8 kgm)
Maximum rpm
Coolant Water
Specific output 104.2 bhp/litre
1.71 bhp/cu in
Specific torque 130 Nm/litre
performance
Note: A value of -1 means that
the car cannot attain that speed.
0-50mph (80 km/h)
0-60mph
0-100km/h
0-100mph
80-120km/h
(50-70mph)
in top
0-Quarter-mile
0-Kilometre
Top speed
Fuel Consumption
CO2 Emissions
Power-to-weight 220.46 bhp/ton
Go to more manufacturers or other Dodge models
chassis
Engine location Front
Engine alignment Longitudinal
Steering
Turns
lock-to-lock
Turning circle
Suspension Front I.MS.
Rear I.MultiLi.CS.
Wheels F/R /
Tyres F
Tyres R
Brakes F/R
Brake ∅ F/R / mm
Braked area
Transmission 6M
Drive RWD
Top gear ratio
Final drive ratio
orlando 23-12-05 16:24
eu nu vad pozele :roll:
dexter_20 26-01-06 12:09
nashpaaaa.nu-mi place
