Amplificator AUDISON LRX 6.1
Se vinde Audison LRX 6.1.Amplificatorul este super OK din toate punctele de vedere (optic si functional) si se da in cutie cu toate accesoriile.A fost folosit cu cea mai mare grija si foarte bine intretinut.Are 6 (sase) canale deci se pot folosi 6 difuzoare .....
Date tehnice Stereo @ 4 ohms 67 watts x 4 + 72 watts x 2 Stereo @ 2 ohms 112 watts x 4 + 134 watts x 2 Bridged @ 4 ohms 231 watts x 2 + 274 watts x 1 Channel C bridged @ 2 ohms 451 watts x 1 Output power @ 1%THD, 1kHz, 12.5 volts Stereo @ 4 ohms 67 watts x 4 + 72 watts x 2 Stereo @ 2 ohms 112 watts x 4 + 134 watts x 2 Bridged @ 4 ohms 231 watts x 2 + 274 watts x 1 Channel C bridged @ 2 ohms 451 watts x 1 Distortion at rated power, 1kHz, 14.4 volts 1.8% @ 4 ohms Input sensitivity 350mV to 2.98 volts Frequency response ( + 1dB) 3Hz - 45kHz S/N ratio (A weighted, below clipping, min gain) > 90dB Slew rate 13V/mS Damping factor @ 100Hz, 4 ohms 237 Idle current 1.6 amps Maximum current consumption, unclipped 114 amps @ 912 watts Efficiency at 1/3rd power lowest impedance 26% Efficiency at full power, 1%THD, lowest impedance 65.5% Crossover, Channel A Crossover slope 12dB/octave Crossover range, highpass 49Hz - 4.8kHz Crossover, Channel B Crossover slope 12dB/octave Crossover range, lowpass 290Hz - 5kHz Crossover range, highpass 53Hz - 1kHz Crossover, Channel C Crossover slope 12 and 24dB/octave Crossover range, lowpass 53Hz - 1kHz Subsonic Filter 21Hz and 30Hz at 24dB/octave Dimensions 19 1/4"(488mm)L x 7 3/4" (195mm)W x 2 1/4"(58mm)H Pret...600 euro Trimit oriunde in tara Nu accept schimb cu nimic Contact pe PM sau tel 0727336364 |
Re: Amplificator AUDISON LRX 6.1
UP>>>>>>>>>
UP..............
UP...............
Amplif deosebit
UP..........
UP....................
UP.................
UP................500 euro
UP>>>>>>>>>>>>>>
Nu ai ceva si pt perioada de criza? marefer la unul mai ieftin
UP>>>>>>>>>>>>>>
UP........................
| All times are GMT +2. The time now is 14:02. |
