DVD KENWOOD 1 DIN KVT-725 1500 RON URGEEEEEEEEENT!!!!
7 Attachment(s)
Aparatul este intr o stare ideala , ca NOU
NU prezinta nici cea mai mica zgarietura sau urma d uzura!! Se livreaza cu toate accesoriile de nou : cutie, rama, telecomanda, toc, hide box, cabluri, mufe,manuale,etc. KVT-725DVD main features: The Kenwood KVT-725DVD offers a complete touch-screen control centre for your car's multimedia system Enjoy watching DVD movies on the 7 inch TFT colour screen. Or add a rear screen and the kids can watch a movie while you listen to the radio or use navigation in the front (navigation computer optional extra) 7 inch (154 x 87 mm) widescreen TFT touch-control display (336,960 pixels) New fully-automatic "Z-action" open / close mechanism with motorised tilt angle adjustment through eight steps plus motorised backwards / forwards adustment through four steps Partially detachable TDF screen panel with DSI & security code anti-theft protection Video disc playback (DVD & V-CD compatible) MP3 (with ID-3 tag display) and WMA file compatible Dolby Digital DRC (dynamic range control : wide/ normal/ midnight modes) Equalisation (Bass / Treble / Q Factor / Gain Control) and Voltage / Current / Temperature / Fan speed display Rotary volume control. Red or green (switchable) button illumination Radio can be connected to factory-fitted remote controls and external dashboard displays on most cars (adaptor required) Compatible with current model Kenwood CD / MP3 changers (control for two changers or one changer and auxiliary input) One RCA AV Output (PAL or NTSC according to the source) One RCA AV Input (PAL / NTSC / Automatic format selection) Video 2 input signal has automatic detection mode (Normal / Auto) Rear-view camera connection ready (through AV Input) RGB input for compatible navigation systems Infra-red remote controller included DVD ± R/W, CD-R, CD-R/W compatible Display of CD text information from head unit or compatible CD changer Disc Name Preset allows names to be assigned to discs in optional CD changer. When disc is selected the name will appear on the radio's display Disc Name Preset Play allows you to select by name any disc in optional CD changer by remote control RDS (radio data system) & EON (extended other networks) tuner Full coverage of LW / MW / FM wavebands with 24 presets Display of radio text information 4 x 50 Watts max power (MOSFET) System Q preset sound control system BMS external amplifier control System E+ provides high-pass filter and bass boost with phase inversion for improved bass frequencies. Front and rear speakers can be individually adjusted Switchable dual-zone allows playing different sources to front and rear speakers simultaneously Three gold plated RCA preouts (5.0 volt) for connecting external amplifier 24 hour clock display Two way telephone / navigation mute Complete with full fitting and operating guide KVT-725DVD What's in the box? KVT-725DVD head unit and mounting sleeve Control box with mounting brackets Connecting bus cable for control box Primary power cable Secondary power cable Aerial extension lead & aerial adaptor Fascia trim Front panel carry case Remote control Removal keys Assorted fixing screws Owner's manual, radio passport & warranty card Pret: 17 mil Tel 0729898307 sau 0766329402 |
Re: DVD KENWOOD 1 DIN KVT-725 CU TOUCH IMPECABIL!!!!
UUUUUUUUPPPPPPP
super sculaaaa
valabil
uuuupppp!
CEL MAI TARE DVD DE P PIATA LA PRET BOMBA!
16,5 MIL UUPP!
valabil
UUUUUUUUUUUUUPPPPPPPPPPPPPP
iti pot oferi 15 mil cash astazi daca te intereseaza....
ai PM .
UPPPPPPPPP
valabil
schimb cu mp3ul meu te intereseaza?
nu merci, doar cash!
