-   -   Hummer GT sau Camaro Tuning - Nebunie pe 4 roti ? (https://forum.4tuning.ro/18-masini-tunate/104366-hummer-gt-camaro-tuning-nebunie-4-roti.html)
CyberCSX 14-01-09 08:28
Prea multe nu s๎nt de scris aici.
Lista modificarilor (๎n egleza) cu siguranta va produce unora dureri de cap :D
Exterior Modification :
Custom Designed & Blueprinted Exterior by Signal Kustom Built, Full Custom Crafted Metal Hood and Front Bumper Assembly, Full Custom Crafted Metal Fenders, Full Custom Crafted Metal Rear Bumpers, Full Custom Crafted Metal Doors, Full Custom Crafted Metal Roof Assembly, Ford Mustang GT Rear Lights Assembly w/custom LED, Ford Mustang GT Fuel Cover, Custom HID Projector Head Lights, Custom LED Turn Signals Assembly, Custom Carbon-Fiber Side Mirrors With Camera Implants, Sparco Gianci Hood Pins, Custom Carbon-Fiber Front Grill, Custom Carbon-Fiber Rear Diffuser, Custom Carbon-Fiber Air Ducts, Custom Tow Eye & Hatch, Custom Made Windshields (F & R).
Chassis :
Custom Galvanized Steel 4mm Chassis Sub-frame, Custom Chassis Fabrication by Signal Kustom Built.
Undercarriage :
Chromed Undercarriage, Full Painted Under-Carriage Body.
Engine Modification :
350CID Small Block V-8, Custom Bored 5.7L – 5.9L, Black Forged Piston Set, Black Gapless Piston Rings,Comp Cams Racing Camshafts,Comp Cams Racing Lifter Kit, Custom 90-Degree vertical Straight Open Exhausts System, Edelbrock Polished Aluminum Cylinder Heads, Edelbrock Dual Carburetor (700cfm), Edelbrock Carburetor Calibration kit, Edelbrock Racing Valves w/Custom Valves Job, Edelbrock Roller Rocker, Edelbrock Racing Valve Springs, Edelbrock Water Pump, Edelbrock Nitrous Wet-Shot System, Weiand Supercharger 6-71, Trick Flows Push Rod, Sealed Power Main and Rod Bearings, Sealed Power High Performance Oil Pump, Summit Racing Street Scope Intake, Summit Racing CDI system package, Summit Racing High Performance 140A Alternator w/Custom Pulley, Summit Racing steel-braided coolant hose, ATI Engine Torque Dampener, Autolite Iridium Spark Plugs, Mallory Distributor, Mallory Promaster CDI Coil, Pertronix Complete Ignition System, Accel Spark Plug Wire Set, Power Master Torque Starter, Proform Timing Gear, Titan Copper Head Gasket, ARP Head Studs, ARP Chromemolly Rod bolts, FAL Aluminum Performance Radiator, FAL Twin High Output Cooling Fans, FAL Overflow Tank, B&M Chrome Steel Oil Pan, B&M Auto Trans. Megashifter, March Performance Billet Water Pump Pulley, March Performance Power Steering Pulley, March performance Billet Alternator & Power Steering Brackets, Billet Specialties Water Neck, Lokar Engine Dipstick, Lokar Transmission Dipstick, Lokar Throttle Cable, Lokar Kickdown Cable, Lokar Aluminum Pedals, Lokar Aluminum Handbrake, Fram High Capacity Oil Filter, Billet Specialties Oil Cap, Billet Specialties Breather Cap, Billet Specialties Radiator Cap, Billet Specialties Valves Cover, Russell Steel-Braided Hoses.
Fuel system :
Carter High Performance Fuel Pump, Edelbrock Dual Feed Fuel Lines, Holley Fuel Pressure Regulator, Aeromotive fuel Filter, Steel Braided Fuel Lines, Custom 40 Liter Gas Tank.
Drivetrain :
GM TH-400 Automatic Transmission, B&M Racing Torque Converter, B&M Racing Transmission Overhaul Kit, Ford 9” Rear Axle, Moser Engineering Drive Shaft, Moser Engineering Rear Axle Shaft, Moser Engineering Rear Axle Bearings, Summit Racing Transmission Cooler.
Color Spec :
House of Kolor Candy Tangerine Orange, Multi-layer Sikkens High-Solid P35 Clear-Coat, Custom Air Brush With Shadowing Effect, Custom Free-Hand Flamed Air Brush.
Interior :
Custom Re-Wrapped Recaro Classic, Recaro Double Locking Runner Rail, Schroth Profi III 6-points Harnesses, Ididit Steering Column, Waterfall Steering Wheel, Waterfall Steering Hub Adapter, Custom Harness Bar, Custom Differential Cut-Out Fabrication, Clayton Industry Signature Series Door Handles, Lokar Door Latch Cables, Mustang GT Chromed Air Vents, Custom Crafted Carbon-Fiber Door Panels, Custom Crafted Carbon-Fiber Dash, Custom Crafted Carbon-Fiber Monitor Pods, Custom Crafted Center Console Unit w/leather and Carbon-Fiber, Custom Crafted A, B, and C Pillars, Custom Leather Headliner, Custom Carbon-Fiber Grip Bar
Rolling Stock :
Mickey Thompson HR-1 18ื7 FR, Mickey Thompson HR-1 20ื16 RR, Mickey Thompson sportsman tires 28ื10-18 FR, Mickey Thompson sportsman tires 31ื18-20 RR
Brake and Suspension :
Wilwood 6-Pots Brake Kit (Front), Wilwood 4-Pots Brake Kit (Rear), Wilwood Polymatrix Hi-Temp Brake Pads, Unique Performance QA1 Competition Chromed Coilovers, Custom Chromed Finished Total Performance 4-link Suspension, Custom Chromed A-arm.
Electronics :
Dakota Digital Multilevel VFD Gauge Unit, Dakota Digital Vintage-Air Gen II Climate Controller, TPMS – Tire Pressure Monitor System Wireless Unit, Sanm Technologies Auto Water-proof Cameras (side mirrors), Kenwood CCD-2000 Universal Rear View Camera, 2” monitors w/ Custom Enclosure, Motorized Trunk Assembly, Keyless Entry Assembly.
ICE :
Kenwood Head Unit DDX8032BT, Kenwood DVD Receiver, Kenwood P202 4” Full Range Speakers (8 Units), Kenwood Mid Speakers KFC-S702P (2 Units), Kenwood 10” Subwoofers KFC-WPS1000F (2 Units), Kenwood GPS Navigation System KNA-G431, Kenwood 800W Multi-Channel Amplifier KAC-8452, Kenwood 1100W Subwoofers Amplifier KAC-8152D, Custom Build Sound Bar Enclosure.
Video cu el AICI si pozele mai jos:
aleks 14-01-09 08:47
Re: Hummer GT sau Camaro Tuning - Nebunie pe 4 roti ?
masina asta are un mare merit: le arata si baietilor cu tiunningu' la ce-s bune gaurile de le dau ei prin capote... :lol:
Mustang 15-01-09 10:28
O "corcitura" destul de impresionanta...
JunKer_hP 15-01-09 18:23
nebunie.....e putin zis:)
