PROBLEME ALFA155 1.8.TS
SALUT AM O ALFA 156 18 TS DIN 1999(AN DE FABRICATIE)DE APROXIMATIV TREI LUNI.PANA ACUM NU AM AVUT PROBLEME I-AM SCHIMBAT FILTRELE SHI ULEIUL,IAR DISTRIBUTIA MAI DUCE CAM 20 000 DUPA CARTEA TEHNICA UNDE AM REVIZIILE.PROBLEMA MEA S-A ACUTIZAT AZI DIMINEATZA.TIN SA SPUN K AM CITIT SHI ALTE MESAJE SHI M-AM CONFRUNTAT CU PROBLEME LA RALENTI INSA EVIT SA O SCOT PE LIBER LA VITEZE MARI SHI ASA NUMAI OSCILEAZA.MI-A PORNIT CU TREMURATURI DIMINEATZA DEOARECE NU AM ASTEPTAT CA SA ISI TRAGA BENZINA POMPA(SE AUDE UN ZUMZET 5 SECUNDE SHI DUPA AIA II DAI CHEIE) AM REZOLVAT SI ASTA.DAR AZI DUPA CE AM MERS CAM 20 DE MINUTE AM FACUT O PAUZA DE 10 SHI NU A MAI PORNIT..PROBLEMA E K MASINA PORNEA AVEA SCANTEIE INSA NU VENEA BENZINA IAR MARTORUL DE LA INJECTOARE (INIZIONE SPIA) RAMANEA APRINS.CARE DRAQ O FI PROBLEMA?????VREAU SA SPUN K AM REUSIT SA O PORNESC IN URMATORUL FEL>MARTORUL INCERCA SA SE STINGA,CHIAR CLIPEA O FRACTIUNE DE SECUNDA.IN ACEL MOMENT AM TINUT ACCELERATIA LA PODFEA SHI AM DAT CHEIA IAR MASINA A PORNIT.I-AM PUS APOI UN ADITIV DE CURATAT INJECTOARELE SHI FIGURA NU S-A MAI REPETAT.STIE CINEVA SA RASPUNDA?????MASINA ARE 13500 DE KM IAR BUJIILE AU FOST SCHIMBATE LA 90000
NICI UN RASPUNS???
AM POSTAT SHI IERI O INTREBARE...NU STIE NIMENI???DECI MI S-A APRINS IN BORD AVARIA LA INJECTIE SHI MASINA NU A MAI PORNIT. INAINTE AM MERS CAM CINCI KM SI AM FACUT O PAUZA DE VREO 20 MIN. AM PUS CONTACTUL I-AM DAT CHEIE SHI NIMIC.CURENT AVEAM DEOAREC MOTORUL SE INVARTEA.DIN DIFERITE DISCUTII AM CONSTATAT CA AR PUTEA FI TREI CAUZE
1.LIPSA SCANTEIE -BUJII 2.INJECTOR INFUNDAT-COMP DE BORD A PRELUAT EROAREA 3.EROARE COMP DE BORD-DEOARECE CRED CA ESTE POSIBIL FIIND GRABIT I-AM DAT CHEIE INAINTE CA SA SE STINGA INDICATORUL DE INJECTIE PROBLEMA ESTE K AM PORNITO IN URMATORUL MOD>INDICATORUL DE INJECTIE PENTRU O MIIME DE SECUNDA INCERCA SA SE STINGA SI IN ACEL MOMENT I-AM DAT CHEIE CU ACCELERATIA LA PODEA.MASINA A PORNIT DAR CU TREMURATURI CA SI CAND MERGEA IN TRE BUJII. POATE CINEVA SA IMI DEA O SOLUTIE SAU UN SFAT????? |
senzorul de turatie
Am descoperit problema!s-a imbacsit senzorul de turatie si de aceea numai porneste motorul.Acesta preia turatia de la arbore si o transmite la ecu.Daca este murdar shi nu are contactul perfect numai transmite informatia iar ecu numai comanda injectia.Mai ramane ca sa merg dupa craciun sa il curat
Re: NICI UN RASPUNS???
in general injectia se aprinde(eroarea) daca e dus debitmetrul,incearca sa faci o resetare
problema e de la releul de injectie am avut si eu la fel si am schimbat releul de la injectoare e undeva la motor un tablou cu relee si vezi acolo care e
