re: Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc
Up....
-Polizor trifazic(380V) dublu PD 500-----430ron
-Dulap metalic tip fiset-----------------230ron -Dulap metalic 2 usi--------------------350ron -Masina gaurit cu coloana(380V)-------1400ron -Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit-----400ron -Element filtru ulei avion(inoxidabil)---------------------------40ron -Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron -Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------370ron -Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg-----------175ron(pentru FREZA FUS22) -Placute Widia--------------------------------------------------5ron/buc -Reductor presiune oxigen---------------------------------------100ron -Trusa pentru sudura oxiacetilenica------------------------------350ron -Pompa picior(1cilindru)------------------------------------------12ron -Pompa picior(2cilindrii)-------------------------------------------22ron -Presostat compresor profesional(220v/10A;Pd-10bar:Pc-7bar------100ron -Manometru presiune0-250atm.--------------------------------------10ron -Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc -Cutite strung widia10x10----------------------------------------5ron/buc -Stativ magnetic ceas comparator--------------------------------120ron SCULE PROFESIONALE DRAPER-ANGLIA -Clichet Reversibil(Reversible Ratchet)250mm1/2''Stock no.34398----53 Eur Legenda: Stock no.303.......reprezinta numarul index din catalogul DRAPER 2008/2009 -Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. -Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)-----35ron,pret nou---30ron. Telef.0722.121.520 |
Buna. M-ar interesa cat ar costa un set de prese de arc (2 prese), si un suport hidraulic de cutie de viteza.
Presa arcuri nu mai este de actualitate si suport hidraulic de cutie de viteza,nu am.
poti sa aduci?
Nu....
-Dulap metalic tip fiset-----------------230ron -Dulap metalic 2 usi--------------------350ron -Masina gaurit cu coloana(380V)-------1400ron -Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit-----400ron -Element filtru ulei avion(inoxidabil)---------------------------40ron -Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron -Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------370ron -Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg-----------175ron(pentru FREZA FUS22) -Placute Widia--------------------------------------------------5ron/buc -Reductor presiune oxigen---------------------------------------100ron -Trusa pentru sudura oxiacetilenica------------------------------350ron -Pompa picior(1cilindru)------------------------------------------12ron -Pompa picior(2cilindrii)-------------------------------------------22ron -Manometru presiune0-250atm.--------------------------------------10ron -Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc -Cutite strung widia10x10----------------------------------------5ron/buc -Stativ magnetic ceas comparator--------------------------------120ron SCULE PROFESIONALE DRAPER-ANGLIA -Clichet Reversibil(Reversible Ratchet)250mm1/2''Stock no.34398----53 Eur Legenda: Stock no.303.......reprezinta numarul index din catalogul DRAPER 2008/2009 -Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. -Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)-----35ron,pret nou---30ron. Telef.0722.121.520 |
Up....
-Dulap metalic tip fiset-----------------230ron -Dulap metalic 2 usi--------------------350ron -Masina gaurit cu coloana(380V)-------1400ron -Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit-----400ron -Element filtru ulei avion(inoxidabil)---------------------------40ron -Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron -Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------370ron -Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg-----------175ron(pentru FREZA FUS22) -Placute Widia--------------------------------------------------5ron/buc -Trusa pentru sudura oxiacetilenica------------------------------320ron -Pompa picior(1cilindru)------------------------------------------12ron -Pompa picior(2cilindrii)-------------------------------------------22ron -Manometru presiune0-250atm.--------------------------------------10ron -Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc -Cutite strung widia10x10----------------------------------------5ron/buc -Stativ magnetic ceas comparator--------------------------------120ron SCULE PROFESIONALE DRAPER-ANGLIA -Clichet Reversibil(Reversible Ratchet)250mm1/2''Stock no.34398----53 Eur Legenda: Stock no.303.......reprezinta numarul index din catalogul DRAPER 2008/2009 -Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. -Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)-----35ron,pret nou---30ron. Telef.0722.121.520 |
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Reductor presiune oxigen------------------------------------100ron Trusa pentru sudura oxiacetilenica--------------------------350ron Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 500------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1300ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron Telef.0722.121.520 |
Up....
Up....
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Mandrina 20/B22-fixare pe con morse-----40ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Reductor presiune oxigen------------------------------------100ron Trusa pentru sudura oxiacetilenica--------------------------350ron Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 500------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1300ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron Telef.0722.121.520 |
Up....
| All times are GMT +2. The time now is 16:53. |
