Re: Sistemul meu din casa
Baieti, daca voi nu veniti cu update-uri, vin eu.. 8)
Cutie MDF18mm 35L acordata la 38hz, Va rog, fara insulte asupra amplificatorului din al doilea clip :D Stiu ce diaree e, mam convins https://www.youtube.com/watch?v=TvHxznMpjZ0&feature=plcp https://www.youtube.com/watch?v=xwo6E...2&feature=plcp |
Hop si eu :D
8 Attachment(s)
Hai sa imi arat si eu mandria mea din casa !!!
PLACA FIREWIRE : TRENDNET External Ports 3 x IEEE 1394 FireWire Ports (6-pin) Standard 1394A Transfer Rate 400/200/100 Mbps 32-bit 33Mhz host interface compliant to PCI Specification 2.2 Supports PCI-Bus Power Management Interface Specification 1.1 Compliant with IEEE1394A Standard and Backward Compatible with IEEE 1394-1395 Devices Provides Software Interrupt Control Supports up to 63 FireWire Devices Supports Plug & Play and Easy Installation PLACA SUNET EXTERNA : INFRASONIC DEUX 2-in/4-out FireWire audio interface 2 balanced inputs with 1/4 inch TRS phone jack 4 balanced outputs with 1/4 inch TRS phone jack Supports fully balanced I/O Supports up to 24-bit/96 kHz Small footprint with a heavy duty aluminum case 1 x FireWire (IEEE 1394a) port FREEMIXER support (Driver version 2.0 or later) ASIO2.2, WDM, DirectSound and CoreAudio support DIFUZOARE : INFRASONIC BLOW 5 2-way bass-reflex bi-amplified 5 inch near field studio monitor Flat frequency response (짹1.5 dB, 58 Hz to 20 kHz) and wide passband frequency (50Hz ~ 22kHz) 90 watt rms (40 watt HF and 50 watt LF) Full discrete power amplifiers with servo-loop and perfect protections. 0.75" natural silk dome High frequency transducer 5.25" Polymer coated paper fiber cone low frequency transducer Full magnetic shielded enclosure and independent amplifier room XLR and 1/4"TRS phone jack balanced/unbalanced inputs EASC (Enhanced Acoustic System Compensation) Technology Input sensitivity control High frequency 3-step tilt controls switch Acoustic space control switch Bass cut-off frequency control switch 5th order active crossover network Front Illuminant Logo lamp and protection indicator High-strength cabinet constructed MDF composite with radius edges CABLURI : CORDIAL CFM 10 FP Cordial professional micrphone-cable can 220 3000cm XLR female/jack NEUTRIK-plugs Black |
si la mine e totul stock si tot la pc sunt legate asa ca cearta-ma!!! :lol:
| All times are GMT +2. The time now is 19:34. |
