-   PC Games (https://forum.4tuning.ro/510-pc-games.html)
-   -   Test Drive Unlimited (https://forum.4tuning.ro/510-pc-games/31114-test-drive-unlimited.html)
ANDR31 21-07-10 06:58
Re: Test Drive Unlimited
Intr-adevar chiar foarte frumos E36 :-) :!:
El_Nino 21-07-10 21:20
Originally Posted by b0b0 (Post 3528797)
Un nou si frumos m3 e36.
Vreau si eu varianta asta o poti urca aici sau imi poti lasa un link de unde as putea sa o descarc.Multumesc!
b0b0 23-07-10 16:55
Uite-l!
http://www.filefront.com/17139260/SLK_55.bnk
Distractie placuta!
prazvan 01-08-10 17:13
Salut!Am si eu o problema mica cu TDU,si anume mi-am facut profilul din greseala offline(am uitat sa bifez GameSpyId) si as vrea sa stiu daca exista vreo modalitate in care sa il editez, sa il fac online dar in acelasi timp sa nu imi pierd salvarea(am facut cam 30% din joc, si chiar nu as vrea sa pierd tot ce am lucrat acolo :(( ).Daca stie cineva si ma poate ajuta si pe mine, as ramane dator.
enter 01-08-10 19:17
cam tirziu, acum apare TDU2. uite aici o metoda. ia vezi si hai sa facem niste curse in gasca.
Offline to Online Profile Conversions:
What this is: This method will convert your offline profile into an online profile.
The purpose: Allows you to repair a profile that has somehow lost its online capability (in other words, the game believes you're no longer on Gamespy)
What you need: A backup of your saved files (I hope you backed up regularly!) OR Your "broken" profile, untouched.
STEP 1
Make a new folder on your computer and copy your backup in there. If you haven't yet deleted your broken profile in frustration, then copy that profile. Do not just move the profile, as we'll be working on it and you want to preserve an original somewhere.
STEP 2
Start the game. Delete your broken profile and create a new one. Register it online with Gamespy (the name you use doesn't matter - it can be the same name or another one entirely.) You will need to fully complete the tutorial sequence, which means:
a) Rent a car
b) Buy your house
c) Beat the rookie race
d) Return to your home, enter and exit it.
You should, at this point, be back in freeride mode, with the ability to use the map and travel wherever you want to. You can now exit the game.
STEP 3
Next, you will need a "Hex Editor". This will read the unreadable characters in your profiles and allow some form of "interpretation" (loose term here. You'll still be looking at gibberish, but at least it'll be recognizable characters!)
As per kadettgte's suggestion, do a Google search for Hex Workshop and install that with the default settings (in other words, you don't need to configure anything)
STEP 4
Now, you are ready to repair your profile. Open up Hex Workshop, maximize its window so you can better see what's going on, then go to Tools > Compare > Compare Files. In the window that appears, you get to select two files to open. Your source file will be the offline profile. Your target file will be the online profile. "Source" and "Target" are a convention - the order doesn't actually matter. We'll begin with the files playersave file. They can be found in [profilename]\playersave\.
For the options just below in the window, make sure Resynchronizing Compare is selected. You can now press OK.
Two windows will appear. At the top will be the offline playersave. At the bottom will be the online one. There will be highlighting here and there. Disregard it.
STEP 5
Now that your files are open for comparison, go to the online file, on the bottom. In the menu bar, go to Edit > Goto. Input 50 as the offset, and select Dec as the measurement (it's below the text box). Also make sure you choose From beginning of file.
Press OK. Your cursor will be placed before the 50th byte of the file. Select all the data from the beginning of the file 'till the 50th byte. Go to Edit > Copy.
Next, use Goto again to go to the 50th byte of the offline file, select from the beginning 'till the 50th byte again, then go to Edit > Paste.
You have finished patching this file. Save (say "yes" to making a backup, as screw-ups happen) and then close both files.
STEP 6
We're almost there. Using Windows Explorer, go to the online profile: My Documents\Test Drive Unlimited\savegame\[profilename]
Delete its contents.
STEP 7
Using Windows Explorer, go to the offline profile you just patched, copy its contents and paste them into My Documents\Test Drive Unlimited\savegame\[profilename]
STEP 8
Lastly, in this newly pasted profile, go to the playersave folder and copy its contents. Paste them into playersave2 This way, both the "current" save and the backup are marked as online, with all your goodies in it.
STEP 9
You are now ready to play. Fire up Test Drive Unlimited, connect and drive around a little bit to make sure you have everything you used to have and all the bits and pieces are in their correct place.
STEP 10
BACKUP! We don't want to lose this profile we just fixed.
PARENTHESIS
What we just did, is tell the offline profile that it's really an online profile. We preserved all the data and goodies that were in your offline profile, cars, houses, money and all, and simply replaced the little "offline" flag with an "online" one, which we salvaged from the temporary online profile you had just created.
postul tot il gasesti aici : http://forum.tdu-central.com/showthread.php?t=3299
prazvan 01-08-10 22:41
Mersi frumos, dar tot nu merge.O sa imi fac alt profil si de data asta nu mai uit sa bifez si GameSpyId, o sa stau sa fac iar cursele si toate alea, si apoi va caut sa facem o cursa mica :)
andreye30 03-08-10 13:07
sal all.sunt nou aici..la ce ora va gasesc pe server si unde?:D:)
enter 03-08-10 14:19
hey hombre, ai auzit de xfire? este un messenger al gamerilor. instaleaza-l si baga id-ul meu. roenter.
insula este mare si sunt sute de gameri la un moment dat. te gasesti greu daca nu ai xfire.
andreye30 04-08-10 12:49
Te-am adaugat:D
andreye30 04-08-10 13:07
Originally Posted by b0b0 (Post 1988078)
M-a prins radaru ieri cu 135 in localitate :D...
Si inca o poza!
salut.cum ti-ai facut numarul de inmatriculare?
andreye30 04-08-10 13:35
Originally Posted by dolb (Post 2261129)
daca te duci la alfa romeo si iei alfa GT o sa descoperi loganul. E posibil sa iti pice jocul pt ca daca vrei sa pui masini in joc trebuie sa folosesti Djey's magic map. Bafta
Am bagat Loganul,m-am dus la tuning cu el,i-am pus kit-ul 3 si s-a transformat in Sandero:| Ce are? [am pus mai demult Sandero in joc si era tot Alfa..azi am pus Logan si ai vazut mai sus ce s-a intamplat]
taz1vas 04-08-10 20:32
=))))))))) lololol
dolb 05-08-10 02:40
Originally Posted by dolb (Post 2333935)
Am reusit sa fac calitatea mai mare si sincronizarea mai buna! Mai jos aveti fisierul necesar! Daca ceva nu merge bine ( desi ma indoiesc ) nu va faceti griji .. am eu backup original al fisierului ! .
Atentie! am tradus doar pentru KILOMETRI. In MILE l-am lasat in engleza pt ca noi romanii nu prea folosim MILE. Deci daca va zice "your destination is in half a mila away" sa nu ma injurati. In rest totul e ok !
Vocea este cea din IGO 2008 - Ioana mai exact :D Have fun!
Nu uitati de GPS-ul in lb romana facut de mine, si nici de :
http://forum.tdu-central.com > unde gasiti 99.9% din modurile existente !
Bafta!
b0b0 05-08-10 10:25
Fisierul Alfa GT (netunat) este Alfa_GT.bnk si Alfa_GT_I.bnk. Si cand o tunezi sunt alte fisiere -> Alfa_GT_SP.bnk si ALFA_GT_SP_I.bnk
Deci tbuie sa inlocuiesti Alfa_GT_SP.bnk si ALFA_GT_SP_I.bnk cu loganul.
Bafta!
expres 07-08-10 18:43
si a bagat cineva megapack pe jocu pirat ? daca da chiar sunt curios:
oricum vreau sa imi iau jocu original , primul tdu deocamndata ca 2u nu stiu daca imi merge :))
daca e cineva de treaba si poate sa imi dea add sa vorbim : madness_edy93 YM!
sa ma mai lamureasca si pe mine ...
