-   Alte Hobby-uri si Pasiuni (https://forum.4tuning.ro/654-hobby-uri-pasiuni.html)
-   -   Staţii CB (tip TIR) şi antene pentru maşină [discuţii generale] (https://forum.4tuning.ro/654-hobby-uri-pasiuni/215117-statii-cb-tip-tir-antene-masina-discutii-generale.html)
davay 10-06-12 14:44
Re: Staţii CB (tip TIR) şi antene pentru maşină [discuţii generale]
Salut.
O singura intrebare am,cati km bate configuratia urmatoare?
1. TTi TCB 550, statie radio auto
Functii:
40 Canale
Frecventa: 26.965MHz-27.405MHz
Benzi multiple
Putere iesire: 4 Watt
Operare: AM/FM
Ton bip: ON/OFF (activat/dezactivat)
Carcateristica T.O.T (Timer Our Time) - cu ajutorul acestei caracteristici puteti regla durata unui apel
BacKlight Dimmer - mod intunecat
Scan
Keypad Lock & Remote Lock - blocare tastatura
Canal de urgenta
Luminozitate albastra
Specificatii tehnice:
Power Output: 4Watt @13.8V DC
Modulatie: AM : from 85% to 95%
Frecventa: 300Hz to 3000Hz
Impedanta: 50 ohms, Unbalanced
Harmonic Suppression : Less than -36dBm
Current Drain: AM Full Mod. 1.6A Max.
Receiving system : Dual conversion superheterodyne
IF Frequencies: Double Conversion 1st 10.695MHz
0.5uV for 20dB SINAD in FM Mode
Audio Output Power @10% THD : 2.0W @8 Ohm
Audio Distortion : LESS then 8% @ 1KHz
Image rejection: -53dBm
Rejectia canalului adiacent : -53dBm
Conducted Spurious: More than 60 dB
Frequency Response: 300 to 2500Hz
Speaker incorporat: 8 ohms,round
Squelch : Adjustabil
2.Antena TL-H 100 cu baza magnetica
Caracteristici generale
Denumire Antena CB TL-H 100
Producator TL-H
Tip antena Antena magnetica
Specificatii Frecventa: 26.5-28 Mhz
SWR: ....................<1.2:1
Putere max. : ..............200 w continua ........ 600 w perioada scurta
Banda la SWR 2:1.............800 KHz
Impendanta.....................50 ohm
Lungime spic....................900 mm
Lungime cablu..................RG58/157"
Polaritate........................Vertical
Baza magnet................100 mm
Conector........................PL-259
Material..........................Cupru si otel inoxidabil
spike1507 31-07-12 20:44
Bună ziua! De cateva zile am achiziţionat o staţie TTI-TCB 1000 + antenă TTi CB-X14S (foto). Bun...am montat-o, am mers şi am calibrat antena, şi surpriză...pe squelch automat pare să fie acelaşi lucru ca şi cum ar fi pe manual la minim. Meşterul care mi-a calibrat antena a zis că mai poate face aşa şi din cauza caniculei . Ţin să menţionez că în momentul când am calibrat antena, aceasta era montată în colţul din stânga spate a plafonului. Ulterior am pus-o pe centru şi acum bârâie cât bârâie până când recepţionez pe cineva. Am recepţionat şi am emis din oraş şi la 4-5 km, căteodată am prins chiar mai departe, de obicei în staţionare şi cu motorul oprit (nu ştiu dacă are vreo legătură). Pe manual aceeaşi poveste, la minim, unde chiar dacă zgomotul de fond e mare, ar trebui sa recepţionez cel mai bine (din câte ştiu), însă majoritatea semnalelor pe care le prind se confundă cu zgomotul de fond şi nu înţeleg mare lucru, plus că volumul "bârâitului" e mult mai mare decat a celor care ar trebui să ii aud, la fel şi pe ASQ, şi e denanjant zgomotul, mai ales că trebuie să dau volumul destul de tare să aud câte ceva.
Am fost cu un prieten care are un Storm Discovery 2 + o antenă de 1450 mm (nu mai ştiu de care), şi la el merge perfect pe autosquelch, nici un zgomot în plus nimic, plus că recepţionează/emite destul de departe. Acum ştiu că şi antena mea e mică şi nu poate face mare lucru (că deh, nu m-am documentat un pic înainte), dar nu mi se pare normal să facă aşa, mai ales pe ASQ.
Mă bate gândul să încerc cu antena prietenului ăsta al meu, să văd dacă tot aşa face.
I-am dat şi reset, iar acum după numărul canalului am un I, presupun că e pe banda de Italia acum...
Aştept ceva păreri/sfaturi.
O zi faină să aveţi!
P.S.: Ţin să precizez că la calibrare mi-a scos acel banuţ, acea chestie rotundă de pe spic, cică ar provoca pierderi (am văzut şi pe forum undeva).
http://www.auto100.ro/images/products/img_13703_2.jpg
meghitz 01-08-12 09:36
Tu esti genul care isi ia nevasta virgina si dupa ce se insoara cu ea incearca sa vada daca e buna in pat sau nu!!
Asa ai facut si cu astea!!
Antena aia nu e buna de nimic!! Putin dai, putin face. Acum ai sa cumperi si a doua oara si insumat ai sa dai cu mult mai mult decat trebuia.
Asadar, ca sa nu cumperi de vreo 3-4 ori antene (stiu cazuri concrete), documenteaza-te f bine intai. Daca vrei sfatul meu de vanzator de echipamente CB, ia-ti direct un Sirio sau un Midland care sa aiba aprox 1.5 metri inaltime.
In cazul in care vrei sa te ajut mai mult, da-mi un PM.
Bafta.
GTA 01-08-12 13:44
Eu am o antenta Wilson Litle will de 1m si sunt multumit de ea...nu am dat-o jos de pe masina nici asta iarna,doar am curatat-o o data si isi face treaba rezonabil.
22VIN 05-08-12 17:03
Salut!
De niste ajutor as avea si eu nevoie va rog, ca-s "noob" in ceea ce priveste statiile CB.
Se da urmatoarea situatie: am 400roni si m-am gandit ca ar fi bine sa-mi iau o statie. Nu pot sa zic ca-s pasionat de CB, o vreau pentru ca-i utila si ca-i buna cand mergi singur la drum, mai omoara plictiseala. Deci as vrea ceva ieftin si decent, nu sa bata la 20km dar nici sa nu inteleg nimic de la 1km nu vreau.
Daca as fi avut 530 ar fi fost mai usor, ca-mi luam direct un Midland Alan 100 Plus B, o antena Midland ML145 cu magnet si mergeam la sigur. Indicat ar fi sa nu depasesc bugetul, inca-i vara si mai am si alte planuri :-). Mentionez ca as vrea ceva nou, cu garantie (in principiu ma uitam pe eMAG sau alti retaileri de gen).
Din ce am citit pe aici am inteles ca e foarte important sa ai o antena buna si cu inaltime in jur de 150cm. As ramane pe Midland ML145+picior sau Sirio ML 145+ picior dar asta inseamna ca-mi raman 200lei pentru statie si nu prea cred ca gasesc ceva decent in banii astia.
Asa ca daca ati putea sa-mi dati cateva sugestii de producatori ok ca sa stiu spre ce sa ma uit si cum sa ma orientez in bugetul asta ar fi super :D
Daca as combina un TTi TCB-660 cu Midland ML 145 + magnet (e pachetul 440lei pe emag) ar fi nasol? Sau 400lei cu antena PNI ML70 dar din cate am vazut ca ati zis asa ceva nu-i prea ok.
22VIN 05-08-12 18:34
Nu mai pot edita: am gasit Midland Alan 100 Plus + antena CRT ML145 + picior la 380 roni. Sunt si pachete mai ieftine/in aceiasi bani cu Alan 100 sau cu TTi 550/660/1000 dar cu antene PHP.
E buna de ceva antena asta? Cele PHP cum sunt?
22VIN 05-08-12 19:06
Iarasi nu pot edita:
Am inteles ca ar fi foarte bune pentru auto antenele Wilson Little Wil. Cica ar fi singura antena scurta care se poate compara cu una de 150cm.
M-ar tenta sa "cuplez" asa ceva cu un Maxon CM10 sau TTi 550/660.
Am inteles ca o antena de calitate mai rar are nevoie de calibrare. Adevarat?
Stiu ca pun o groaza de intrebari dar pe masura ce vizitez mai multe site-uri descopar mai multe modele si sunt si mai nedumerit :))
fasso 05-08-12 20:11
Am eu cuplate Midland Alan 100 cu Wilson Litle Will si sunt extrem de multumit de combinatie. Le folosesc de mai bine de 2 ani fara niciun fel de problema ;)
22VIN 05-08-12 20:21
Mersi de raspuns dar cica tot Midland/Sirio ML145 ar fi mai recomandat... Proprietarii de asa ceva spun ca aveau SWR de sub 1.1 de la inceput.
Asa ca m-as baga la TTi TCB-660 cu Midland ML145.
Foloseste cineva TTi? Sunt ok?
tabokubmw 05-08-12 20:26
Ce statie buna pana in 1000 lei mi-ati recomanda?
SOLENZAXJG 06-08-12 12:28
President orice model si antena la fel pentru bani la care esti dispus sa ii dai pe ele.Recomand President
meghitz 06-08-12 13:08
President Johnson 2.
22VIN 07-08-12 10:59
Gata, mi-au ajuns TTi TCB-660 cu Midland ML145 :D Trebuie sa montez mufa de bricheta la statie si ne auzim pe drumuri :D
speedy-mouse 09-09-12 20:09
Buna seara. Am cumparat si eu de curand o statie Storm Matrix 20 w , si mi-au dat o antena Megawatt de 1.50 inaltime. Problema este ca nu receptionez prea bine si nici nu emit , sa ma exprim asa , va rog , puteti sa-mi spuneti care din cele doua sunt de vina , sau chiar amandoua /:))).Mentionez ca nu este inca , calibrata. O seara frumoasa si drumuri bune !
PS. ce antena imi recomandati la tipul acesta de statie daca este din cauza ei ?:rolleyes2
22VIN 09-09-12 22:30
Antena e Sirio, e foarte buna. De regula antenele astea sunt calibrate de la bun inceput dar pentru 20 lei merita sa vezi cum sta treaba.
Intotdeauna cand iei antena noua o calibrezi inainte sa emiti pentru ca exista riscul de a strica statia. Zic si eu din ce-am auzit de la altii care lucreaza cu asa ceva.
Big-brother.ro 09-01-13 07:43
Aș vrea o părere despre ”Statie President Randy II Mobile plus antena magnetica President ML145 Black 1500 mm”. Sau cineva care măcar folosește Randy II, ne neapărat ”combinată”cu antena asta! Cred că stația asta se poate folosi și inafara mașinii. Mă inșel oare?
Big-brother.ro 30-01-13 21:32
Pana la urma am luat un Alan 42 Multi, antena Midland, si o baza magnetica de 160 mm. Baza e superba, foarte mare si are o "atractie" :D deosebita pentru plafonul masinii "M-a rezolvat" "meghitz", foarte multumit de achizitie. Din partea mea o bila alba pentru "meghitz"!
meghitz 30-01-13 21:47
Senq man !! :D
1nightwish 01-02-13 11:41
Salut baieti,
Am intrat si eu ieri in lumea CB.
Statie President Johnson 2 ASC
Antena Sirio Megawatt 4000
Talpa magnetica ML145,diametru 157mm
Am calibrat-o cu reflectometru si am pe canalul 1-1 / 40-1.1 / 22-1.05. Practic era calibrata bine, doar am masurat valorile, in camp deschis cu usile inchise.
1.Ce parere aveti de configuratia asta ? Am luat-o la recomandarea unor prieteni.
2. Cam pana la ce viteze sta magnetul prins? Cei de la magazin mi-au garantat pana la 200km/h ( O am montata pe un BMW si mai ating viteza asta pe autostrada )
3. Aproximatie cam la ce distanta bate ? ( stiu ca tine de relief, vreme, etc...)
Din ce am testat-o ier se aude foarte bine, azi am sa o testez la un drum lung ~200km.
O zi buna va doresc.
22VIN 01-02-13 12:01
Asta depinde de multi factori.
Spre exemplu, eu am talpa de 120 si antena Midland ML 145 (1600mm). Am mers cu ea pusa pe portbagaj cu 160km/h si n-am avut probleme, dar unora le-a cazut acelasi setup de 1600 + 120 de pe plafon si la 130km/h (asa ca nu depasesc nici eu viteza asta cand o pun acolo).
Antena ta are 2m, eu as zice ca e riscant sa mergi cu 200km/h cu ea pusa pe plafon. Se poate sa nu cada in conditii optime, dar daca bate vant mai puternic e foarte posibil sa se duca. As recomanda 180km/h maxim.
Ca sa fii sigur ca n-ai probleme as zice sa-ti iei una 3*180.
meghitz 01-02-13 12:03
Alegere: F buna, atat statie cat si antena.
Calibrare: Buna. Poate ar trebui sa incerci sa mai scadzi SWR-ul pe canalul 40, poate obtii un 1.0:1 si acolo. Adica, ar trebui sa mai bagi vreo 2 mm spicul mai jos... dar ai grija sa nu-ti creasca SWR-ul de pe canalul 1.
Viteza: Presupunand ca talpa este de firma, adica de la Sirio sau de la Midland de ex....eu m-as opri pe la viteza mentionata de tine. Daca aveai antena de 1.45 sau 1.6 metri as fi mers si peste..!! Totusi antena ta este destul de grea si chiar daca ai talpa de 16 cm, tot nu ar trebui sa exagerezi!!
Daca talpa este vreo chinezarie, uita de vitezele astea!!
Eu de ex am mers cu 225 km/h (pe autobahn desigur :D) cu talpa de 16 cm de la Midland dar cu antena de 1.45 metri (un Sirio Turbo 2000 Blue Line), mult mai usoara decat a ta.
1nightwish 01-02-13 12:27
Ms baieti de raspuns.
Talpa este originala Sirio MAG 145PL diametru 157mm, nu e chinezarie.
Cei de la magazin mi-au garantat ca tine pana la 200km/h, evident daca bate vantul cu vreo 30km/h, ramai la 170km/h.
Pe durmurile tarii asteia nu merg mai mult de 150-160km/h, doar cand mai ies pe afara, sa nu zboare.
Aveau si Performer ZG 917 ca si talpa magnetica, cu 3 magneti, dar mi-au zis ca nu imi garanteaza pana la 200km/h, ca e mai buna SiriO.
1nightwish 01-02-13 17:14
Testata astazi, sta bine pana la 180km/h, mai mult nu am mers.
M-am ales cu o zgarietura frumoasa pe plafon, nu e mare, cam 2cm, nici adanca. Ce folie as putea pune sa nu interfereze cu magnetul ? Este ceva special ?
Ps: Consum scazut cu ~ 0,5l/100km ( economie 1L ) Asa e daca poti merge constant nu tot scazi la 50 in sate.
Numai bine.
22VIN 01-02-13 19:13
Se gasesc protectii in genul asteia http://magazin-statiiradio.ro/acceso...magnetica.html
meghitz 01-02-13 21:23
Orice adaugire sub talpa magnetica iti modifica SWR-ul !!!
Eu nu inteleg totusi cum o talpa magnetica noua a putut sa iti zgarie masina?!!
fasso 01-02-13 22:07
e deajuns sa prinda un fir de nisip sub magnet, ca s-a rezolvat vopseaua ;) sunt patit, de atunci fara autocolant sub magnet nu mai umblu, poate sa se modifice si ma'sa :lol:
1nightwish 01-02-13 22:11
Pai drumul era ud, sarea mizerie de la cei din fata, si pe haionul masinii ( antena era sus pe masina ) era mizerie.
Cand am luat-o mi-a alunecat un pic din mana si am zgariat cu o pietricica, cred ca era.
Ce mi-ai aratat mai sus ii de 150mm, talpa mea are 160mm, ma gandeam la o folie transparenta sa o pun pe haion. Au in jur de 150microni grosime foliile, sa modifice asa mult srw ? As vrea sa pun o folie mai mare 250mmx250mm transparenta ca sa nu mai intampin probleme de genul.
Antena e destul de grea, magnetul tare, mai si balangane si e riscul sa mai atingi plafonul unde este mizerie.
1nightwish 01-02-13 22:12
@fasso imi recomanzi ceva autocolant care sa tina, sau o folie ceva ?
Sa tina si la spalat cu spume active
fasso 02-02-13 09:40
Da, cel mai pocnitoare autocolant care-l gasesti la magazin, 5-6 lei metrul, si poate ai norocul sa-l gasesti si in culoarea masinii. Il am de vreo cateva luni lipit pe plafon si inca nu s-a deteriorat. Pana la urma nu conteaza ca e protectie special destinata sau inventie proprie, oricum de vazut nu-l vede nimeni...
1nightwish 02-02-13 19:18
Ms de raspuns.
Am sa merg luni sa caut ceva.
Ma gandeam la o folie de policarbonat, dar daca merge si cu autocolante mai ieftine.
1nightwish 07-02-13 18:04
Revin cu detalii.
Am pus o folie de la ORACAL, Oraguard stone guard film 270, de 150 microni pe plafonul masinii.
Daca inainte aveam SWR:
Can.1-1.0 / Can.40-1.1 / Can.22-1.05
Acuma am:
Can.1-1.1 / Can.40-1.0 / Can.22-1.05
A crescut pe canalul 1 si a coborat pe canalul 40. Din ce am testat-o la drum nu am observat nici o diferenta. Se aude la fel de bine, la o proba care am reusit sa o fac cu un prieten dintr-un oras vecin ( 10 km ) ne auzeam perfect.
Mai departe nu am avut cu cine sa fac o proba.
Sa mai scot un pic spicul de la antena ? Sau sa o las asa, ce sugestii imi dati.
Ms
MiTzA- 26-02-13 19:46
Salut,
Am si eu nevoie de o parere. Ce ziceti de : h ttp://www.cbmania.ro/promotii/statie_bytrex_pro-m4_+_antena_wilson_little_wil.html?gclid=CImQ8s2F0 rUCFQtY3godhFEA_w
agh057 21-04-13 12:14
Buna ziua,
as dori sa-mi cumpar o statie CB de 4W si o antena mai mica de 110 cm, bugetul l-am stabilit pe la 450-500 RON. Ma gandisem la o antena Wilson Little Wil si o statie INTEK M 60 PLUS.
Aveti o idee mai buna, alte sugestii?
Mersi frumos
crazy_ghi2000 03-07-13 13:15
salut. vreau si eu sa imi achizitionez o statie CB. M-am hotarat la Statie CB President Harry III ASC+Antena President ML145, 5 ani garantie. E ok? Cam ce parere aveti?
csl_89 16-07-13 22:33
puteti sa mi spune-ti ceva despre aceasta statie: jopix omega?
gen caracterstici si ce face butoanele? ca nu gasesc nicaieri un manual....
Bogz02 14-08-13 13:37
Best choice, nu ai nimic mai bun in banii aia. ;)
csl_89 27-08-13 23:03
salut,
mi am luat si eu o statie tti dar am urmatoarea problema....
Cand il pornesc si radioul e oprit merge perfect, cum pornesc si radiou l(nu e stock am un kenwood, masina e un passat b5.5) statia incepe sa haraie mai tare si trebie sa dau Squelch mai tare sa dispara...
Am incercat sa mut antena in alt loc poate interferea cu antena de la radio dar nici un semn, plus ca eu ascult muzica de pe stick direct, daca pun radioul in standby la fel face... deci e ceva pe alimentare cred eu... ce pot face?
22VIN 27-08-13 23:48
De unde ai tras alimentarea statiei?
csl_89 28-08-13 14:34
De la panoul de sigurante, pe circuitul cu contactul... cum iau contactul se opreste
22VIN 28-08-13 17:29
Statia se alimenteaza direct de la baterie. Trage-i cablu.
