Re: Tuning Parts ROMANIA
poti sa imi spui daca ai kit de camber
Multumesc frumos |
pentru honda civic 1994 am uitat sa mentionez
pret pentru suspensie reglabila de golf mk1?
Suntem mai mult orientati pe partea tuning motor/performant |
Proaspat Livrat! La Cluj
Power Steering Оil Tank TA42 Material: Aluminum Color: Polished Aluminum Pret: 251.00 RON |
2L tank Lăţime: 210 mm Grosime: 110 mm Īnălţime: 95 mm Material: Aluminiu Culoare: aluminiu lustruit Pret: 164.00 RON |
Proaspat Livrat! La Braila
Filtru de aer Apexi Power Intake Dual Funnel Air Cleaner Diametru al bazei: 160 mm Diametru superior: 120 mm Īnălţime: 125 mm Diametru de intrare: 76mm Culoare: Roșu Pret: 190.00 RON |
Proaspat Livrat! In Bucuresti!
Fender Reforming Tool N.W.: 7.5kg G.W.: 8.5kg Use for fender collision repair or fender flaring or to increase fender clearаncе ; Fit most cars and light trucks with 4 or 5 lugs; Simple and easy to use ; Roller works on the fender from inside wheel well; Attached hitch pin allows for wide or narrow angle; Adjustable arm has second telescoping arm with roller that allows for 180 degrees wheel swivel Pret: 631.00 RON |
NOU! Costuri de transport reduse cu 50%. Va asteptam!
salut. un pret pt ceas afr cu sau fara sonda
52mm Analog Wideband AIR/FUEL RATIO Gauge with Warning and Peak mode Display Color: Super WHITE & AMBER Oxygen Sensor: Bosch LSU4.9 ( NOT indluded) Working range: 10-20AFR Mounting diameter: 52mm 150cm Power Wire Harness 200cm Control Unit to Gauge wire Harness 300cm Sensor to Control unit wire Harness Highly visible numbers Clearly visible needle design Inclusive Of Full Fitting Kit And Instructions Bosch LSU4.9 NOT included Pret: 831.00 RON |
Wideband A/F Sensor Bosch LSU4.9 Pret: 663.00 RON |
sau
Ratie Aer/Combustibil (AFR) 2 culori: Alb, Albastru Diametru: 52mm Producator: ProSport Pret: 299.00 RON |
| All times are GMT +2. The time now is 12:38. |
