Re: Weineck Cobra - 780 cui Limited Edition
caut caut :D am gasit unu de 250mb mpeg pe emule ;)
Alte informati:
Bad Gandersheim, Germany, is the home of Weineck Engineering, manufacturer of the world's most powerful, strongest and best accelerating road - legal car. Highly visible: The gigantic airscoop of the engine bonnet is really a necessity since it and the engine bonnet cover V8 with a cylinder capacity of 780 cui (or 12.9L). The first turn of the key activates a gigantic high-pressure fuel pump. To tromp and release the accelerator pedal means more than half a litre of finest nutrition (fuel) have arrived inside the ultra high-performance carburetor system to feed the devil, that is Weineck's custom milled V8 engine. The next turn activates the gigantic starter motor to spin the crankshaft resulting in an latent idle of 1,000rpm. Even up to 4,000 rpm, the Weineck Cobra 780 cui Limited Edition accelerates faster than any other supercar when fully driven. The accelerator pedal always has to be operated very gently and with respect. The world's most powerful, strongest & best accelerating road-legal car and its absent of aids from the digital era like ASR, ESP, ABS etc. Above 5,000rpm the engine delivers its world record torque of 1300 ft.lbs (1,760 Nm) at 5,600rpm. It's more like Sol 5 on Starship Enterprise! The rev. limiter is set to cut in at 8,000 rpm and the engine reaches its maximum power of 1,100 hp at 7,000 rpm. Infact, the engine revs faster than the classic Smith instrumentation can follow! From 0-300 km/h (186 mph) in just 10 seconds! That is, of course, not only possible by using the strongest, naturally aspirated engine ever built for a road car. Power is nothing without control! That's why the Weineck Cobra 780 cui Limited Edition is being built using a MIG welded, self-supporting tubular frame with a 4inch diameter to absorb very high torsion forces created by the engine. Additionally, its body is deep drawn from carbon composite materials for maximum rigidity. Single wheel suspension including a continuously variable coil spring system in conjunction with a specially engineered Brembro brake system guarantees an individual set-up suiting individual driver's preferences resulting in high-precision driving and braking. The 4-speed extra high-performance gearbox, driveshafts and rear axle (equipped with a 75% limited slip differential) are designed for more than 2,000Nm of torque! The interior of the Weineck Cobra 780 cui Limited Edition will be designed individually to meet any customer's wishes. Normally, finest British leather is being used for the upholstery of the seats. All colours, pipings and sewings can be individually chosen. The rest of the passenger compartment is finished by using velours carpets. For the dashboard, classic Smith instruments are being used. In case of rain, the car is equipped with a soft top to protect both the driver and the interior. If requested, a fixed hardtop is also available. Each unit of the Weineck Cobra 780 cui Limited Edition is a unique masterpiece of German Engineering. Only 15 lucky individuals worldwide will be able to share the experince of 780 cui! Story by Weineck Motorenbau In Detail engine All Aluminum Donovan V8 w/Weineck Pistons, Crank, Heads position Front Longitudinal aspiration Natural displacement 12782 cc / 780 cu in compression 11.5:1 power 820.3 kw / 1100 bhp @ 7000 rpm hp per litre 86.06 bhp per litre torque 1760 nm / 1298.1 ft lbs @ 5600 rpm drive wheels RWD w/75% LSD body / frame Carbon-Composite Body over 4 Inch Steel Ladder Frame front brakes Brembro Discs rear brakes Brembro Discs front tire size 255/40 ZR18 rear tire size 315/35 ZR18 steering Power Steering f suspension Adj Suspension w/Coi Springs transmission 4-Speed Manual gear ratios 2.741:1, 1.778:1, 1.15:1, 0.863:1 final drive 2.70:1 |
:peace: am mai dat de unu de 73mb e mai bine asa? :p
ce mai astepti ? :) urca-l in mai multe volume
sau macar direct linkul...
Al am pe ala de 73mb dar nu e tot documentaru encodat, pentru cei care inteleg germana va fi de folos ca eu unu nu inteleg, este interesant, e practic un documentar nemtesc despre masina, cum sa construit si nu pot sa zic decat ca e practic BRUTE OLD SCHOOL POWER!! Cand vad la ce stare sa ajuns in ziua de azi cu 10,0000 de senzoruri si calculatoare la bord mie sila, masina e pentru aia pasionati de putere bruta si sunet de CAI BRUTI nu de formula sau rice, exotic sau mai stiu eu ce, just RAW POWER, adica in mare la toti ne place berea rece dar la uni le mai place si un Jack Daniels :peace:
Cel de 250mb am cam 175 din el deja, sint curios daca va fi intreg si ce calitate va fi fata de asta de 73mb, sa vad unde il bag acum :D |
Fac upload :D I LoVe GoOgLe ;) Cred ca in 15 minute e gata....
Pe google video nu a vrut sa treaca de 24mb nu stiu de ce, in fine lam pus pe rapidshare..... http://rapidshare.de/files/13024901/...COBRA.MPG.html
nu inteleg de ce nu lai pus aicea ...era mai simpu ...in fine ...
Pai aici e limita de 30mb
daf : ca sa il iau de pe situl care lai pus imi cere ceva cont ... :( |
nu cere, e rapidshare, dai click pe free si porma ai sa vezi cum numara ca trebui sa astepti nustiu cate secunde si dupaia apare 3 cifre care trebui sa le bagi acolo si dai download :D
| All times are GMT +2. The time now is 07:26. |
