-   Scule-Echipamente Service (https://forum.4tuning.ro/528-scule-echipamente-service.html)
-   -   Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc (https://forum.4tuning.ro/528-scule-echipamente-service/119818-vand-polizor-dublu-masina-gaurit-coloana-electromotor-u650-alternator-u650-etc.html)
iulian2476 01-05-10 08:29
re: Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc
Multumesc frumos pentru raspuns. In mare este suficient ce mi-ati spus, insa pistonul de frana la rotile din spate trebuie concomitent rasucit si impins. Mai mi-ar trebui un disc de 35 mm diametru, care sa aibe 2 stifturi, care se imbina in orificiile pistonului, atunci cand rasucesc si imping.
ellaghe72 08-05-10 08:48
Re: VAND STRUNG PROF.,COMPRESOR IND.,SCULE AUTO PROFESIONALE,,DRAPER''ANGLIA
VAND:
-Polizor trifazic(380V) dublu PD 500-----450ron
-Dulap metalic tip fiset-----------------250ron
-Dulap metalic 2 usi--------------------400ron
-Masina gaurit cu coloana(380V)-------1400ron
-Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit-----400ron
-Element filtru ulei avion(inoxidabil)---------------------------40ron
-Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron
-Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------370ron
-Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg-----------175ron(pentru FREZA FUS22)
-Placute Widia--------------------------------------------------5ron/buc
-Reductor presiune acetilena------------------------------------100ron
-Reductor presiune oxigen---------------------------------------100ron
-Trusa pentru sudura oxiacetilenica------------------------------350ron
-Pompa picior(1cilindru)------------------------------------------12ron
-Pompa picior(2cilindrii)-------------------------------------------22ron
-Presostat compresor profesional(220v/10A;Pd-10bar:Pc-7bar------120ron
-Manometru presiune0-250atm.--------------------------------------10ron
-Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc
-Cutite strung widia10x10----------------------------------------5ron/buc
-Presa profesionala pivot-capete de bara((copie Draper)------------90ron
-Stativ magnetic ceas comparator--------------------------------120ron
SCULE PROFESIONALE DRAPER-ANGLIA
-Clichet Reversibil(Reversible Ratchet)250mm1/2''Stock no.34398----53 Eur
Legenda:
Stock no.303.......reprezinta numarul index din catalogul DRAPER 2008/2009
-Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--170 ron.
-Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)-----35ron,pret nou---30ron.
Telef.0722.121.520
ellaghe72 16-05-10 21:03
19 Attachment(s)
VAND:
Legenda:
-Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron.
Telef.0722.121.520
ellaghe72 20-05-10 17:40
Up....
ellaghe72 26-05-10 07:59
Up....
ellaghe72 04-06-10 18:12
Up....
ellaghe72 16-06-10 12:39
Up....
ellaghe72 12-07-10 12:56
Up....
ellaghe72 19-07-10 11:46
Up....
ellaghe72 23-07-10 19:31
Up....
ellaghe72 28-07-10 17:05
Up....
ellaghe72 02-08-10 19:12
Up....
ellaghe72 06-08-10 08:38
Up....
ellaghe72 14-08-10 14:49
Up....
ellaghe72 21-08-10 19:38
Up....
